Old 07-04-2013, 03:06 PM   #351
topazsparrow
Drives: slow
Out of curiosity, what kind of costs would one face when pulling the DI's? How many shop hours?
topazsparrow is offline   Reply With Quote
Old 07-04-2013, 06:06 PM   #352
PSJohnDoe
I just got my first couple pops last night, I'm just over 9500 miles with crickets at idle. No CELs, so far. AT with TRD intake and exhaust.
PSJohnDoe is offline   Reply With Quote
Old 07-05-2013, 08:14 AM   #353
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Originally Posted by trueno86power View Post
Results are out, the upper seal of the DI Injector 1 look like crap and will be replaced. The lower one was just about to burn and will be replaced. No damage to the plug what so ever. Tomorrow it will be re-tested and everything should be fine. Already got my flash update from Perrin to correct the problem.
My car is now repaired all under warranty. Work great, I've put my new flash from Perrin too. Everthing seem perfect!
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-05-2013, 09:34 AM   #354
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by wootwoot View Post
I haven't seen anyone with out symptoms pull their injectors..... Why would they? The injectors you have seen pulled went bad.... That's why they were pulled.
Why would they? Well this issue has led to blown up engines, it doesn't always flash a CEL and we only have a 60k warranty. The symptoms are subjective. My engine is making a louder manifold exhaust leak sort of sound above 5k rpm. Do I pull the injectors? If I had the materials, time, and tools you betcha. Can I convince the dealer to? No. Dealers generally won't do any engine work without a CEL. The issue is a tough one.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-06-2013, 02:38 PM   #355
andrew20195
Drives: 2013 Subaru BRZ
To remove and replace, I would expect around 2.0-2.2 hours. To remove, reseal, and reuse the existing injectors I would expect 2.8-3.0 hours.
That's for all of the direct injectors. At the least, if you only have one bad seal it would likely range from around 1.7 to replace one bank (you have to take both injectors on one bank out at the same time), to 2.1 to reseal one bank.
andrew20195 is offline   Reply With Quote
Old 07-15-2013, 05:46 PM   #356
Dezoris
Dezoris's Avatar
Originally Posted by DJCarbine View Post
You will have to call/email these guys the part number as the tool is not listed on their website
Part# 09260-39020-01
sales@autotoolworld.com
1-877-570-6295
Holy shit that tool is $100!!!
Old 07-15-2013, 06:20 PM   #357
DJCarbine
Thupercharged
DJCarbine's Avatar
I've spent a lot more on special service tools.....
Doing VANOS on a BMW motor is no fun and requires several tools, some of which you can't even really get.
There are always shortcuts though, I'm sure someone could make a tool that works... but the trial and error on a direct injector is not really my cup of tea lol
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-15-2013, 06:32 PM   #358
Dezoris
Dezoris's Avatar
I ordered it, it was on there website now. Thanks for the link.
I am going to try and pull these bastards this weekend and see the status sick of worrying about it.
Doing a Vanos sounds like a horror movie.
Old 07-15-2013, 06:50 PM   #359
xjohnx
Grip>Slip
xjohnx's Avatar
Any chance you are going to be making a video/howto about it? Because that would be awesome. Your videos are always really high quality and well done.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
dabocx (07-15-2013), Sonolin (02-21-2014)
Old 07-15-2013, 07:06 PM   #360
Dezoris
Dezoris's Avatar
Yes, I will have video about that (DI), spark plug change and supercharger belt swap.
The Following 6 Users Say Thank You to Dezoris For This Useful Post:
ATL BRZ (07-15-2013), CSG Mike (07-15-2013), MaXimus (03-06-2014), Sonolin (02-21-2014), TemeCal (07-15-2013), xjohnx (07-15-2013)
Old 07-15-2013, 07:43 PM   #361
DJCarbine
Thupercharged
DJCarbine's Avatar
If you want you can just borrow my tool
Are you going to be replacing the seals or just checking them?
2013 FRS
Vortech V3 11psi
Old 07-15-2013, 07:47 PM   #362
Dezoris
Dezoris's Avatar
I have to check them first. I have all the seals if I need to replace anything. But also need to get the flow number off the injectors so I can order those if they are scorched.
I placed the order already unfortunately.
Old 07-15-2013, 09:16 PM   #363
xjohnx
Grip>Slip
xjohnx's Avatar
i think i'll end up buying one too, once i see your video to make sure i'm comfortable yanking them.
Old 09-28-2013, 09:42 AM   #364
kosoku
Drives: 2013 fr-s
any update on a video?
kosoku is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
