Old 07-10-2013, 10:56 AM   #939
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Interesting article on Motortrend's long-term BRZ in the August 2013 issue.
" Over the past few months the BRZ had been making an irritating noise, most noticeable at idle with the windows down... the noise was a continuous small squeaking or chirping- a cricket held up to a microphone."
" After describing the noise, the manager hesitated only for a second before saying, " it's the fuel pump.""
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
BareZ (11-19-2014)
Old 07-10-2013, 11:50 AM   #940
thill
^^ Good. Maybe this will help force the issue and get a true fix. Now we just need the DI seals on the Motortrend car to fail
Old 07-10-2013, 01:27 PM   #941
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Why can't there be an electronic HPFP!?!
Old 07-10-2013, 03:59 PM   #942
Sportington
Sportington's Avatar
Drives: 2013 Aquamarine FR-S
Electronic? The pump still needs to physically move fuel - electronics don't apply.
Sportington is offline   Reply With Quote
Old 07-11-2013, 02:21 PM   #943
JRANGER
JRANGER's Avatar
Drives: Hot Lava FR-S
Had it diagnosed today and they said it was not a functional issue and no foreseeable fix but a case was logged with Toyota about it. BLAH!!! Ive been trying to get ethanol free gas and all the stations near me are out all together other then 89 ocatane..F***!!!!!!
JRANGER is offline   Reply With Quote
Old 07-14-2013, 02:40 PM   #944
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
I just did a 350 mile round trip with no crickets! Before we left I ran my 93 tank to as low as I could and filled up with 91 Ethanol Free and almost immediately the crickets were gone. I couldn't believe my ears! The ethanol free gas is the only way to go. Luckily they are plentiful around Madison, WI.
This website has a pretty comprehensive list if anyone wants to check out their area.
http://pure-gas.org/
Kill crickets with ethanol free gas
MadFRS is offline   Reply With Quote
Old 07-14-2013, 02:50 PM   #945
FR-S Matt
Most of these are not in major cities is the problem. I'd gladly fill up with ethanol free gas if it wasn't 30 miles away. The ethanol causes that lubrication issue with the pump which makes it chirp like that. I've noticed the Chevron by where I live has the lowest mix of ethanol compared to the Shell 93 octane which makes me chirp like hell. I still get the chirp with Chevron, but not at idle... just slightly above it. Kind of a trial and error with gas stations but it could change the next time the station gets fuel.
Old 07-14-2013, 05:10 PM   #946
Smokinbuffalo
BRZ Owner
Smokinbuffalo's Avatar
Drives: SWP Ltd MT BRZ, Scion xA
I had the green dot HPFP installed, but the crickets came back after few tanks. I switched back to ethanol free, and no more crickets.
Buy the ticket, take the ride
Smokinbuffalo is offline   Reply With Quote
Old 08-18-2013, 12:09 PM   #947
Kauf
Drives: 2014 SSM BRZ
Attachment 43612
I saw this too. Thanks for sharing it. I hope it puts more awareness on the undesired crickets sound and helps bring about a solution.
Kauf is offline   Reply With Quote
Old 08-18-2013, 02:45 PM   #948
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
When you bought the car new. In the owner manual there is a card to report complaints and problems about your car. Fill it out and send it in. This way by passing your local dealer and getting in to area mangers and corporate hands. More noise we make the sooner they will really fix the problem. And if you can, take the car in as many times as you can and complaint about the same problem. In fact bring up any and all problems, make sure it is documented and get and keep copy's of everything.
skye67 is offline   Reply With Quote
Old 08-18-2013, 03:39 PM   #949
mike the snake
I've read that adding a cap full of 2 stroke synthetic oil per tank of gas is good for HPFP's.
My old BMW 135i had HPFP issues and I read there someone suggesting that adding a cap full of 2 stroke oil per tank of gas would help keep the HPFP from going bad (at least on the 135).
If the chirping on our cars is lubrication related, maybe this might help?
I posted this same info on another chirping thread, and someone said it might affect the octane rating, not sure about this.
Old 09-10-2013, 11:43 PM   #950
Dino451
Dino451's Avatar
Drives: Scion FRS/Whiteout/OEM spoiler
1350 miles got the chirps. Went to dealer and they swapped the fuel pump with no hassle. Will see if it comes back. 91 octane same brand since new
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
Dino451 is offline   Reply With Quote
Old 09-11-2013, 04:42 PM   #951
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Had this replaced on mine around 7,000 miles. I'm now over 8,000 and they are back. I called Scion to issue a complaint. The "local" dealer (45 min drive) asked me to come in next Friday to let him hear it. Ok, you guys heard it once and replaced the parts, I had to make 2 trips for that, I'm not doing it again. I should hear back within 24 hours from a specialist.
Have we confirmed that Toyota is just using the same Parts as before?
HuntingtonFRS is offline   Reply With Quote
Old 11-10-2014, 12:00 PM   #952
babydriver
Hit the road and I'm gone
babydriver's Avatar
Originally Posted by xpicer View Post
Finally, the fix has been posted on Toyota TIS. Time to schedule your visit to the dealer!!!!
Thanks to another member we now have the suby version as well!!! enjoy guys!!!
http://www.teknikrayon.net/docs/BRZ_fuelpumpTSB.pdf
Any word on whether Toyota has extended this fix to the 2015 models? I see that they have service bulletins on 2013 and 2014 models.
I tried the suggestion of using Chevron premium and it seems to have greatly reduced the volume of the chirping or at times eliminating it altogether. I plan to switch back to Shell after this tankful is gone and see if the chirping returns.
Slip, slidin' away.
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 01:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 11:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 10:57 PM
