View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-08-2013, 03:06 PM   #2213
Vmax911
Drives: WRB BRZ
Originally Posted by Nevermore View Post
So, I've been told by two different people (one a good friend that loves to work on cars and knows a lot about them, the other a relative that owns an auto shop and does work on cars every day all day) that the crickets should be coming from the rear of my car, not the front, as the fuel pump should be located back there, not under the hood. The noise is quite clearly coming from under the hood and has gotten worse over time. Can anyone confirm the location of the fuel pump for this car? And why, if the pump is in the back, the noise comes from the front? Could it be the injectors instead?
Electric fuel pump is in the tank, high pressure mechanical fuel pump is under the hood.
Vmax911 is offline   Reply With Quote
Old 07-08-2013, 03:07 PM   #2214
HunterGreene
Hail Magnet
HunterGreene's Avatar
Please take a service manual and/or diagrams with you when you talk to these two people and show them that the High Pressure Fuel Pump is located in the engine bay, on the driver's side. There is a pump by the tank, to my knowledge, but it is not the focus of the chrips.
Neither of these guys have ever worked on an FR-S, obviously.
Old 07-08-2013, 05:12 PM   #2215
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Yea also known as the injector fuel pump. The normal fuel pump in the tank pushes the fuel the length of the car, the HPFP then gets it up to the pressure required for the injection system. If you have ever heard an old inductor or dewatering pump it basically makes that sounds just at a much higher frequency. they should just wrap it in dynomat lol
JDM FRS is offline   Reply With Quote
Old 07-08-2013, 06:52 PM   #2216
Tromatic
Originally Posted by HunterGreene View Post
For me, the best solution at this point is to just leave it be. A couple users have mentioned that once they get up there in miles (most >10k), the crickets simply disappear. Patience appears to be a virtue in this case
Mine chirps, don't care. When there is a fix, I'll get it fixed. Meantime, e-free gas.
Old 07-08-2013, 08:15 PM   #2217
SilentMike
Drives: 2013 FR-S 6MT Asphalt
Hmmmm. Has anyone tried acoustically insulating the pump? I wonder if a wrap or enclosure would cause the pump to over heat?
Mike
SilentMike is offline   Reply With Quote
The Following User Says Thank You to SilentMike For This Useful Post:
JDM FRS (07-08-2013)
Old 07-08-2013, 11:33 PM   #2218
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
went to have mine repaired for a second time and they told me that Toyota is aware of the problem and they are working to fix it and not to repair mine.
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 07-09-2013, 01:17 AM   #2219
Yellow_Jacket
Drives: Whiteout FRS
I had the cricket for a while now and taking it in this Friday to get it replaced. The chirp seem to be getting louder so needless to say I've been listening closely for that noise lately. Tonight when I pulled into my garage I heard the chirping again, only this time it was much louder and a different interval. So I popped my hood for a closer listen, but figured out the sound was way too much on the passenger side to be the fuel pump. Only then did I realize it was a real cricket on my garage floor Toyota could have picked a better animal sound for our engines to imitate...
Yellow_Jacket is offline   Reply With Quote
The Following User Says Thank You to Yellow_Jacket For This Useful Post:
thill (07-09-2013)
Old 07-09-2013, 01:40 AM   #2220
thill
That is hilarious!
Old 07-09-2013, 02:01 PM   #2221
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
Originally Posted by DylanFRS View Post
It has been pretty well proven throughout this thread that ethanol-free gas fixes it. Problem is that most people do not have access to ethanol-free gas.
I would have to disagree.
As I mentioned earlier, I have been using Shell 91 V-Power with no ethanol since day one and I have had crickets. There are also comments from others using e-free that they have crickets too.
But mine are not always there, but usually on hot days after lots of driving.
So either some of the Shell stations I go to are BS'ing about the no ethanol OR it is an intermittent issue that comes and goes so people are thinking no ethanol works.
EL_to_TBD is offline   Reply With Quote
Old 07-09-2013, 02:15 PM   #2222
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Fair enough, maybe I spoke out of turn, I didn't see that there were some people using ethanol-free on every fill up and still getting the chirps. I started putting ethanol-free in my car and haven't had a single chirp in thousands of miles. Temperatures here have been getting up to 105* in the afternoon on my long drive home.
DylanFRS is offline   Reply With Quote
Old 07-10-2013, 02:43 AM   #2223
Silver86
Silver86's Avatar
Drives: Argento FR-S
I have been running E0 for over 4k miles now with no chirps. One day I was low on gas and had to put some ethanol gas in so I could make it to the E0 pump.
Chirps came back the second I started my car after putting in the ethanol gas.
Later that day after I had burned that gas away and it was running on the E0 gas the crickets were gone.
Its the ethanol dude.
Shell is BSing you.
Silver86 is offline   Reply With Quote
The Following User Says Thank You to Silver86 For This Useful Post:
DylanFRS (07-10-2013)
Old 07-10-2013, 03:52 AM   #2224
5th 86
Drives: 2013 BRZ SPORT TECH
Maybe if we put nuff ethanol in and get those crickets laid they will shut the f up
5th 86 is offline   Reply With Quote
Old 07-10-2013, 12:28 PM   #2225
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
As posted in the other chirping thread, I thought this would help anyone who's dealer is giving them problems.
Interesting article on MotorTrend's long-term BRZ in the August 2013 issue.
" Over the past few months the BRZ had been making an irritating noise, most noticeable at idle with the windows down... the noise was a continuous small squeaking or chirping- a cricket held up to a microphone."
" After describing the noise, the manager hesitated only for a second before saying, " it's the fuel pump.""
mwjcyber is offline   Reply With Quote
Old 07-10-2013, 12:46 PM   #2226
Tromatic
Do some of you not understand that the pump itself is either poorly designed of has some defect that causes the chirp? Until the re-design or permanent fix, odds are your pump will chirp, no matter how many you try.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
