Old 07-08-2013, 01:45 PM   #29
SilentAngel
Guest
Posts: n/a
If i remember right, the manual says break in period is the first 1,000 miles. Says do not keep the revs consistent but to keep them moving, so basically a lot of city driving. do not exceed 4K RPM until after the first 1,000 miles. I don't believe the manual says anything about an oil change at 1,000 miles, but i did one anyway.
This is exactly what i did for my car, I've had it for a year and 1 month today, with approx. 16,550 miles on it. I have had no issues other than condensation in the taillights, and the normal cricket noise every so often.
Hope this helps! :happy0180:
Old 07-09-2013, 02:59 PM   #30
MyGT86
Drives: 2013 M/T Asphault FRS
I am currently at 700ish miles on my FRS. So far I have followed the owners man keep shifts under 4k. I have jumped on it a few times "emergencies" no issues. And if you want to follow the owner man then you can set a shift light and beep to keep you under or at 4k for your shifts. Have fun
MyGT86 is offline   Reply With Quote
Old 07-09-2013, 03:17 PM   #31
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Break-in procedures are pretty controversial topics so many people have there own ideas as to what is best for the engine. But the general consensus for the FRS/BRZ is what the manual says, don't go past 4000 RPM for the first 1000 miles but don't baby it through it either otherwise some things won't wear in. Also alot of people said to change the oil a bit early at the 1000 mile mark because there are metal shavings floating around in the oil pan after the break in which is normal, then proceed to normal maintenance schedules.
Old 07-13-2013, 01:32 AM   #32
tCsonfrs
Drives: 10 Series FR-S #207
Don't have my car yet but I have a quick questiom; how often should I be varying the RPMs on a 75 mile highway trip?
And whats "too long" to stay at one speed on that same trip?
tCsonfrs is offline   Reply With Quote
Old 07-13-2013, 01:33 AM   #33
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i had the same question when i bought my car, so i would just go between 65-80mph on and off again lol.
bkblitzed is offline   Reply With Quote
Old 07-13-2013, 01:35 AM   #34
tCsonfrs
And you have to do that for the first 1000 miles? Thats gonna be a pain, by the time break in is over crusie control is going to be a luxury to me lol.
Old 07-13-2013, 02:15 AM   #35
TheEradicator
Drives: Scion FR-S (Raven)
Trust your gut, either follow the cars manual or the person trying to discredit the manual by saying something amazing like "that manual was written by lawyers... Trust this guy on the web he has pictures of pistons...."
I personally went with the manual.
TheEradicator is offline   Reply With Quote
Old 07-13-2013, 02:24 AM   #36
bkblitzed
is better than you
bkblitzed's Avatar
no only for 500 miles. For every 100 miles i passed, I would rev it up 1k more rpm. So by 7-850miles I was shifting around 7k rpm.
Old 07-13-2013, 02:25 AM   #37
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
http://www.mototuneusa.com/break_in_secrets.htm
20k not one issue other then the ECU swap.. Countless trackdays and autoX.. Both my gixxers ran in the same way, 84k on my race bike with not a problem, stock other then exhaust and AF with a power commander, the 2011 gixxer 750 has 24k not a issue with either.. Also the 03 600 put 112 to the wheel after 54k so I didn't have a issue running three engines in with the motune method
Gixxersixxerman is offline   Reply With Quote
Old 07-13-2013, 02:28 AM   #38
5th 86
Drives: 2013 BRZ SPORT TECH
Originally Posted by oldpueblo View Post
It's my understanding that it's not just for the engine, all the systems need to break in. I'm sticking to what the manual says, that's its job.
Yep after about 1600km the suspension broke in and felt much better, just set the shift light to 3800rpm and have fun
5th 86 is offline   Reply With Quote
Old 07-14-2013, 05:50 PM   #39
TRD4life
Drives: 10 Series FRS #1525
Can someone explain what it means to "keep the RPM varied" during a drive? Like, how long is sitting at a single RPM too long? Does just taking your foot on and off the throttle count as varying the RPM, or must I actually shift gears?
TRD4life is offline   Reply With Quote
Old 07-16-2013, 01:32 AM   #40
troek
troek's Avatar
Drives: 2012 Toyota 86
i broke in my car by driving full throttle on the toyo turnpike. so far so good.
troek is offline   Reply With Quote
Old 07-16-2013, 02:02 AM   #41
lexusb3
Drives: FRS
I got the car broke it in 1500 miles then I boosted it 400++ hp later no problems and 13,000 miles
lexusb3 is offline   Reply With Quote
Old 07-16-2013, 03:45 AM   #42
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Here's what I did to break in the car:
I drove it from Denver to Los Angeles in one day.
-alex
BRZ Engine Break In Brahsbrah BRZ First-Gen (2012+) — General Topics 10 06-17-2013 04:31 PM
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 06:41 PM
Seriously...what's the first thing to break??? Supermassive Forced Induction 19 12-05-2012 02:21 PM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 05:41 PM
Oil change after break in? oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 08-03-2012 01:09 AM
