Old 12-26-2011, 01:36 AM   #71
Kostamojen
Originally Posted by tranzformer View Post
Now the H6 would be interesting if it would fit but it would probably throw off the handling a bit since it couldn't be mounted as far back.
Won't be that much different, and the added power/torque can help keep the rear end rotated when needed.
Originally Posted by fatoni View Post
you have to admit that you cant know if that is because of the turbo and not because of the demographic buying the cars or even the boxer design
Hundreds of cars, hundreds of customers, different model years and engines, every different demographic you can think of...
My conclusion: No thanks.
Old 12-26-2011, 02:05 AM   #72
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by chulooz View Post
Just make the turbo engine an option, N/A guys can have their performance wants and the turbo guys can get their performance desires.
Originally Posted by subatoy View Post
EXACTLY!
simple as that.
When has Subaru offered engine choices for their WRX STI? That is the closest car I can't think of as an example for the BRZ STI. Sure you can offer engine choices in Legacy and Forrester cars due to volume. But a specialty car like a BRZ STI? I doubt it. I don't want a tubo BRZ STI to take away from my chance at a light weight NA car.
tranzformer is offline   Reply With Quote
Old 12-26-2011, 02:32 AM   #73
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I didnt realize this topic was about the BRZ STI model. That would be a specific model so it would have to be either one or the other, I understand.
In that case, Subaru's Turbo engines have awesome performance capabilities, both new and in the aftermarket... if you want N/A enjoy the N/A model. I couldnt see Subaru Technica International having any other REALISTIC option for this car.
Im betting that BRZ's with boost will blow away any N/A variants in performance abilities.
chulooz is offline   Reply With Quote
Old 12-26-2011, 09:41 AM   #74
Levi
Drives: Toyota
Only if you get 350 PS or more from the turbo, in all other cases not really. A 300 PS NA 2.5l H4 would be as good and lighter.
Levi is offline   Reply With Quote
Old 12-27-2011, 08:13 PM   #75
NastyNate
Drives: 05 MazdaSpeed Miata
Stock compression is really high for FI but like any motor, whether it was built with boost in mind or not, there is one thing that will make or blow the motor... TUNING.
Fast in the straights is for everyone else. Fast in the corners is for me.
NastyNate is offline   Reply With Quote
Old 12-28-2011, 05:32 PM   #76
Scubynubie
Drives: 2003 WRX
Man, I go away for a couple of days and this thread has exploded.
It is interested that this has slanted into a Turbo vs. NA vs. Godzilla thread.
I love turbos, I just don't love turbos on engines that came NA, and especially not with 12.5:1 compression.
My main reason in starting this thread was actually because of the realization that the Turbo version of the BRZ is going to have to cost more, and most likely thousands of $$$ more than the NA BRZ, and that bump in price is what pushes it out of the range that I think really makes sense to spend for this kind of car.
FWIW, if the BRZ came with a 1.8 L Turbo engine stock, and still only made 200 hp, that would be a completely different car at $24,000. And I'd still be all over it.
I think I have also decided that the ultimate STI version of the BRZ would only have about 30 hp more, but will also weigh 200 lbs less...
230hp + 2400 lbs... That would be pretty awesome.
Okay back to your regularly scheduled programming...
Scubynubie is offline   Reply With Quote
Old 12-29-2011, 06:31 PM   #77
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
I agree with you completely, but 2400lbs these days is a bit of a stretch; even more so on a 2-4 vehicle =/. With the stringent safety standards that vehicles need to meet these days I don't see that happening on an already lightweight vehicle.
I mean, that's stepping into lotus territory and if you're familiar with the elise and exige you know what they needed to do to make the vehicle as light as it is (if there's anyone that isn't familiar with them google the interior on both cars and you'll see what I mean)
SVTSHC is offline   Reply With Quote
Old 12-29-2011, 06:58 PM   #78
Max Schnell
Drives: Lexus GS350 F-sport
If kids do to these what they do to Honda civics you may see a few in the 2400lb range. No interior, holes in the bumpers, Pepboy power adders...oh yeah.
Max Schnell is offline   Reply With Quote
Old 12-29-2011, 07:00 PM   #79
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Nothing like compromising the structural rigidity of your chassis to really make you feel like a racecar driver
Old 12-29-2011, 09:54 PM   #80
fatoni
lighter? maybe. just as good? no. and thats not even considering the cost...
Old 12-29-2011, 10:18 PM   #81
Scubynubie
Drives: 2003 WRX
They're called speed holes man. Get with the times...
Old 12-29-2011, 10:40 PM   #82
fatoni
thank you
Old 12-30-2011, 02:11 AM   #83
chulooz
Registered you sir
chulooz's Avatar
Originally Posted by lfawishes View Post
this car is designed around lightweight, even with a car like the sti its a fair challenge to loose weight on a street car. A car like the brz already designed for lightweight, I doubt it will be cheap or easy and maybe not even possible to loose much weight, definitely nothing worth 100hp or even 50
If you mean lb instead of hp, then I must disagree: bumper beams, battery, wheels, and exhaust should do the trick to meet that request(might not be cheap, but easily possible).
I do agree that this car will already have many components that have been developed with weight considerations.
Old 12-30-2011, 03:59 AM   #84
Quantum
Drives: Infiniti G35
All I want is 10lbs per horsepower. I don't care if it's 240hp at 2400lbs or 220hp at 2200lbs.
I'll be removing as much weight as reasonably possible for a daily driven street car. My last 'car' was less than half the weight of an Elise.
-Hong
Quantum is offline   Reply With Quote
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 08:42 AM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 12:58 AM
Turbo or Suppercharger or none xc Engine, Exhaust, Transmission 12 11-17-2011 05:40 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
