#43 | |
Grumpy Old Man
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Would I expect to pay more for a version of the AS1 which includes forced induction and makes more power? Of course, to think otherwise would be foolish. Do I want it to be AWD, absolutely not, if I did, I'd just buy another STI, (I miss mine quite a bit). Nor am I saying that the vehicle should ONLY be available as FI, both versions could have their place. It seems that a lot of people think that forced induction must be complicated. Lets list what a FI car has that a naturally aspirated version doesn't. Not what parts are different, just what is "extra". 1. Turbo or supercharger 2. Oil lines to and from the turbo, (some SC units are self contained for lubrication) 3. water lines (not all turbos use these, supercharges as far as I have seen, do not at all) 4. Bypass valve (blow off valve) 5. Intercooler (again, not all FI systems use these, but most modern ones do) 6. Intercooler piping (several superchargers do not require these, as the intercooler is mounted to the SC) So at a maximum six things, at a realistic minimum with a self oiling, intercooled SC, three things, which are all typically packaged together. Obviously the tune is different, the exhaust manifolds for turbos are different, the injectors are typically of a higher flow rate, the pistons are often a different material, the cams of a different profile, the fuel pump a different flow rate. Suspension components are typically different to support higher weight transfer due to more power. Compression is lower. But, the NA engine still has all of these things, albeit typically of less expensive materials in many cases. In fact, the DI PI fuel injection system on this car is more complicated than ANYTHING on an AE86, and more complicated than a typical single turbo system. If anything, vehicle cost and complexity could have been left out, as well as some additional weight by sticking to a single injection method. I guess the point I'm trying to make is that this car seems to quickly be garning the love of the same type of people who say that putting an LS1 in an RX7 ruins the "soul" of the car. If this car sells well in it's first year or two, there WILL be forced induction versions, and I would be nearly willing to bet that the 1.6 DIT engine on display next to the FA20 at the Tokyo show will be the one to go in it. I will still buy the NA version when it comes out in the spring, and I'm sure I will LOVE it in stock trim. I will however, trade in or sell it when the factory FI version is available.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
#44 | |
Delights in pure handling
Drives: Zoom Zoom
For me NA is always more fun than turbo, even if it has less power. If you want turbo power just add it yourself. If you want turbo RWD from the factory get a GC. Just not sure Subaru will offer the BRZ with turbo. Depending on how you read Subaru's comments, either there will never be a turbo offering or there won't be for some reason. I just don't see the need for Subaru to offer to make the car successful. They don't need to. The AE86 didn't need it. The rest of the car and it's design should speak for the AS1. |
#45 | |
Drives: Zoom Zoom
#46 |
Drives: Toyota
Me too I hope NA. There are many other better turboed cars out there for those that want turbo. New WRX? Anyway most of us are not professional drifters so no need turbo for the BRZ.
#47 |
hp for hp a turbo brz is going to be faster and cheaper than a n/a brz
#48 |
Drives: Zoom Zoom
#49 |
Drives: Zoom Zoom
#50 |
if you couldnt care less about hp then why are you commenting on a turbo brz topic? i dont understand why people think turbo isnt fun. also the gt500 is probably in the neighborhood of 15k more.
#51 | |
Drives: Zoom Zoom
Fatoni, could you please capitalize when you write. It makes it much easier to read. Thanks. |
#52 | |
and besides, if you dont care about horsepower great. the fact still remains that a turbo car is going to be cheaper at basically any hp rating. i would like my affordable sports car to remain affordable |
#53 | |
Drives: Zoom Zoom
Edit: I should note a 2.0 NA vs a 2.0t. |
#54 | |
i really dont want a turbo car either but i just dont like to judge a car by its means instead of the end. my msp is more responsive than my miata |
#55 | |
Drives: Zoom Zoom
#56 |
| Turbo FR-S | Mino | Engine, Exhaust, Transmission | 24 | 12-16-2011 08:42 AM |
| turbo yes | BMWDAD | BRZ First-Gen (2012+) — General Topics | 79 | 12-06-2011 12:58 AM |
| Turbo or Suppercharger or none | xc | Engine, Exhaust, Transmission | 12 | 11-17-2011 05:40 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
