Old 06-26-2013, 05:23 PM   #183
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I didn't do LCAs or the bushings. I dropped the car then took it for an alignment a few days later and the specs were within range of what I found acceptable for my usage. I installed the coilovers myself, but if I had been having a shop do the work I probably would have opted for the bushings and had them installed at the same time. Then again I do not need a huge level of camber adjustment, my most important adjustment was the toe.
UnOvertime is offline   Reply With Quote
Old 06-30-2013, 04:32 AM   #184
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
You guys still have the Tarmac 2 Clubsport's in stock? If so how much would it be shipped to 93012. Thanks .
Touge86 is offline   Reply With Quote
Old 06-30-2013, 01:05 PM   #185
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If anyone needs the two Washers for the front Tarmac Zero's I have the pair sitting in my garage. I'll sell them for $5.95 (USPS Priority Mail Small Box). I ordered two sets because the original ones were taking forever and finally both of them arrived at the same time.
Old 06-30-2013, 08:50 PM   #186
Sportsguy83
Drives: Limited BRZ
RCE Tarmac 0 coilovers utilize the knowledge gained in the RCE Tarmac development process to bring an affordable and comfortable sporting coilover option to the Subaru BRZ and Scion FR-S aftermarket.
Did the install this weekend. I'm getting a slight "clunk" when going over speed bumps. I'm guessing I need to tighten the top nut (its on the front passenger side). I already tightened it and feel I can go more, but I'm afraid to over tighten and damage the threads. It happens rarely.
Should I try to tighten it a bit more? Is the clunk expected?
Old 06-30-2013, 09:06 PM   #187
Shouldn't clunk with stock tops. Call us.
- andy
Old 07-01-2013, 10:18 PM   #188
The main thing that has to be done is lower the perches all the way so there is no tension on the springs so you can secure the conical washer and top perch on the shock shoulder. Then tighten the top nut down. In the rear same thing, but that nut has a tq spec of 16ft lbs and its a double nut so secure them one at a time. A lot of times people try to push the helper spring down while securing the front and they dont get the washer over the shock shoulder stem area and then it clunks.
Myles
Sportsguy83 (07-01-2013)
Old 07-01-2013, 10:27 PM   #189
OrbitalEllipses
Drives: Attitude
Dude. Hurry up and get moar Tarmacs.
Old 07-01-2013, 10:58 PM   #190
Sportsguy83
Drives: Limited BRZ
Myles
I put the washer between the top perch and the top hat. About the bolded part, I dont know which is the shock stern area.
I did lower the perches all the way down. I still believe my problem is I need to tighten the top nut more, but still curious about the washer and bolded quoted part. Thanks for the help!
Two more questions:
Is there any way to know how far down/up you are getting the car?
Does the helping spring compression dictates how far up/down the car is lowered?
Maybe these questions seem obvious to other people, but I had never installed adjustable coilovers.
Old 07-02-2013, 08:46 AM   #191
FR-S Matt
Still waiting on some 0's as well?
Old 07-02-2013, 11:49 AM   #192
OrbitalEllipses
Drives: Attitude
I can neither confirm nor deny.
Old 07-02-2013, 12:14 PM   #193
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Just got mine installed last night. Still have to play with ride height as well as get alignment and add in rear camber bolts.
Some pics from the install:
Stock VS Tarmac 0
Stock Spring vs Included 225 Front Spring vs 350 Front Spring
Installed:
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 07-03-2013, 12:52 AM   #194
FR-S Matt
That spring clearance is sexy. Exactly what I need for my car because of my damn wide rims, lol. That stock spring is insanely wide. I can't wait to get mine on so I can start cornering hard again without worrying about the low trac coming on.
Old 07-04-2013, 05:20 AM   #195
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Yellows are 20mm drop, static. Tarmac Zeros are height-adjustable. Combined with the fact that the forces of the Zero are not adjustable and you don't mention interest in adjusting forces, the Zeros are probably the better choice for you. Also the Koni warranty process is some shit, but that's bad feelings on my part.
With a threaded-body/height-adjustable coilover you change camber as a side effect of lowering the car, which is incorrect. This is fixed by using an adjustable length lower control arm, which is also the incorrect way to adjust camber (as this arm changes toe angle AND camber angle with one adjustment). The Whiteline camber bushing adjusts the UCA position, which is the correct way since it doesn't alter toe. Bushing cost + labor on the install will cost you more than a LCA + labor (you can install the LCA in your garage when you do the coilovers, too!).
Good info on the UCA adj bushings, question however if one uses a quality LCA and also an example a WL adjustable toe arm, this would be "as good" as the UCA adjustable bushings from WL no??
Old 07-04-2013, 05:28 AM   #196
OrbitalEllipses
Drives: Attitude
You accomplish the same thing, but still have squishy bushings in the UCA. Ultimately, most people will end up with LCAs and toe arms if necessary as it's simply easier.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
