go_a_way1
Old 06-27-2013, 04:04 PM   #85
CSG Mike
CSG Mike's Avatar
Originally Posted by derek1ee View Post
1. what's your tire temperature difference (outside/inside of front/rear) on track and on street? is 10F difference outside to inside on street driving to much?
2. what's your tire temperature difference front to rear? I have rear temp higher than front, ~5F, normal? how can i make them even?
thanks!
Temps depend on the tire used and the rims (width) used. We're optimized for 225/235 tires on 9" rims at the moment, with a spread of 5-15F depending on run time and ambient temps. With 8" rims, outer edges are generally way hotter than the inside and centers.
Higher rear temps isn't a bad thing... I struggle with higher front temps.
10F difference street driving means you probably don't have enough camber for on-track use. Street driving, our car is "warm" on the inside, and cool center and outside. This is purely due to sidewall flex from camber; we run 0 toe front/rear.
Old 06-27-2013, 04:11 PM   #86
ayau
Drives: Some rust bucket
Is 17x9 on 225 too much stretching in your opinion? Not worried about the wheel popping off the bead? 225 tires are rated with max wheel width of 8.5'', but it's almost impossible to find wheels in 8.5'' 5x100. Any suspension parts rubbing on 17x9?
What's the hotness in track tire at the moment? Rivals? RS3?
Old 06-27-2013, 04:59 PM   #87
CSG Mike
CSG Mike's Avatar
I may be guilty of running 225 on a 9", but these are with tires that are known to run wide...
My tire of choice is still the RS3.
Old 06-27-2013, 05:41 PM   #88
kster1
kster1's Avatar
In the Miata world, running a 15x9 with a 225 tire is a very popular setup with the track guys.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
amram (03-28-2014)
Old 07-03-2013, 01:07 PM   #89
CSG Mike
CSG Mike's Avatar
Bump. I know there's gotta be more questions
Old 07-03-2013, 01:43 PM   #90
troek
troek's Avatar
Drives: 2012 Toyota 86
ok heres one. im going to tsukuba in a couple weeks. gona be my first time at a track. any tips?
troek is offline   Reply With Quote
Old 07-03-2013, 01:46 PM   #91
CSG Mike
CSG Mike's Avatar
Take it slow, keep the car under control. Tsukuba has walls...
Make sure you got good brake pads and fluid. Otherwise, have fun!
amram (03-28-2014), troek (07-03-2013)
Old 07-03-2013, 01:52 PM   #92
sw20kosh
Drives: 2013 Black FR-S
How softly do you grip your steering wheel?
Do you, at all, "hang on" to the steering wheel during hard cornering?
Old 07-03-2013, 02:05 PM   #93
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Do I need a full face helmet or will my open face helmet suffice?
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 07-03-2013, 02:08 PM   #94
CSG Mike
CSG Mike's Avatar
I used to. I had to force myself to relax... constantly remind myself to just hold the steering wheel enough to keep in control. Eventually, it becomes natural.
sw20kosh (07-03-2013)
Old 07-03-2013, 02:09 PM   #95
CSG Mike
CSG Mike's Avatar
That depends on the organization and track; you'll want to check with the organizer of your particular event.
overlookedx (07-03-2013), sw20kosh (07-03-2013)
Old 07-03-2013, 04:57 PM   #96
sw20kosh
I think this is why I am so bad at correcting for a spin... I grip the steering wheel and hold on for dear life when the tail end is comin round.
Old 07-03-2013, 05:58 PM   #97
CSG Mike
CSG Mike's Avatar
I got into a (bad) habit of just letting go of the steering wheel, and catching it when the car's balance "feels right".
I really have no idea where I picked it up, but from what I'm told, it's a drifter thing?
In the s2k, If I do this, it's almost 100% guaranteed that it'll result in an overcorrection and a spin in the other direction, but with the FRS/BRZ, I can unwind and recenter at will.
amram (03-28-2014), WillRacer1jz (07-03-2013)
Old 07-03-2013, 06:03 PM   #98
ayau
What senses do you rely on when you track? Can you rate them from most important to least important?
eg., visual, feedback from steering wheel, etc.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
