Old 12-22-2011, 05:08 PM   #29
Sasquachulator
Pavement Grey
beh just compare it with cars with similar power/weight.
Previous gen Celica GTS was low 7's can break into the 6's. (180hp/2500lbs)
Civic SI i think i around 6.5 seconds (200hp/close to 3000lbs?)
Volkswagen GTI is i think around 6.5 or low 6's (200hp/3000lbs?)
My Corolla XRS is supposedly around mid/low 7's, can break into the 6's with bolt ons (170hp/2700lbs)
I expect the car to be around 6.5
Old 12-22-2011, 08:22 PM   #30
Itgb
Drives: 2003 BMW M3, 2006 Scion xB
Don't forget in addition to power/weight ratios, gearing has a substantial effect on acceleration times too.
2003 BMW M3 | 2010 Audi A4 Avant | 2006 Scion xB | PAST - 1986 MB 190E 2.3-16, 2005 Volvo S60 2.5T
Itgb is offline   Reply With Quote
Old 12-23-2011, 12:21 AM   #31
fitftw
Drives: 1996 Mazda Miata 2,000lbs
I'd say 5.8-6.7 seconds. I used this http://www.060calculator.com/
167hp at the flywheel (15% of 197hp) 2,600lbs = 6.5 if I did that wrong and it really is 197 at the flywheel, then it's 5.8 seconds.
It has similar numbers to a 2.0L Civic Si and that car hits 60 around 7 seconds...
0-60 times are hard to pin down anyway. Google any car 0-60 and you'll find a good 5 or 10 wildly different numbers...depends where you are in relation to sea level, temperature etc.
fitftw is offline   Reply With Quote
Old 12-23-2011, 12:41 AM   #32
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
hp rated at the crank is same as flywheel..then subtract around 15% from that from drivetrain loss to the drive wheels..
Flywheel HP = 197
Wheel HP = 167
WingsofWar is offline   Reply With Quote
Old 12-23-2011, 01:42 AM   #33
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Flywheel HP = 197
Wheel HP = 167
We get an extra 3hp no?
tranzformer is offline   Reply With Quote
Old 12-23-2011, 02:08 AM   #34
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I think that's just journalists not realizing that there's a difference between PS and hp. And that's not even accounting for the differences between SAE J2723 and JIS D 1001 testing standards
old greg is offline   Reply With Quote
Old 12-23-2011, 02:51 AM   #35
gamma6
Drives: 03 ep3
Originally Posted by 86'd View Post
It's really easy to get caught up in 0-60 times, and while I find this a cool exercise in trying to find out what the actual time is, all I know for certain is that it will be more than enough power for me on a daily basis.
It's significantly faster than my daily driven Civic SI and I still have fun in that.
In any case, I'm sure the car will hit mid to low 6's...
I hear you on that... my sc-ed si is so much fun and i should be pushing around 230 so i hope this would be just as fast stock!
gamma6 is offline   Reply With Quote
Old 12-23-2011, 10:12 AM   #36
tranzformer
Drives: Zoom Zoom
USDM gets a less restrictive exhaust that supposedly sounds better and bumps power to 200hp.
Old 12-23-2011, 11:21 AM   #37
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Source?
Old 12-23-2011, 11:28 AM   #38
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Where did you find that 'fact'?
It wouldn't make much sense for them to do this here and not in the other markets.
Homemade WRX is offline   Reply With Quote
Old 12-23-2011, 12:49 PM   #39
tranzformer
Drives: Zoom Zoom
Source?
Geesh you guys need to read more about the car and spend more time on here
Tada said it. I will get you your source. Better flowing (3hp) and better sounding. We talked about this on here extensively a few weeks back.
Old 12-23-2011, 01:02 PM   #40
tranzformer
Drives: Zoom Zoom
Source?
Also, that engine will be rated at 200 hp in the U.S., Tada says. U.S. models will get a unique, less restrictive exhaust to bump them from 200 PS (197 SAE hp) to a full 200 SAE hp. It also adds a better exhaust note, says Tada.
http://www.ft86club.com/forums/showthread.php?t=2856
Boom, steak, dinner.
Old 12-23-2011, 05:04 PM   #41
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^^ win.
Sport-Tech is offline   Reply With Quote
Old 12-23-2011, 05:46 PM   #42
fitftw
GT5 would be exactly correct.
200hp
2,800lbs
0-60 in 6.05 seconds
0-60 mph - forget handling ability for 5.9 seconds ahausheer Scion FR-S / Toyota 86 GT86 General Forum 227 04-04-2012 01:23 AM
