#71 |
Its finished finally I will have a big update in the next two weeks.
| The Following User Says Thank You to Dezoris For This Useful Post: | MaXimus (02-10-2013) |
#72 |
Drives: Whiteout FRS
Is there any way to cover up the open spaces on the sides? I am going to do an install today and noticed that there is a considerable amount of open space on either side.
| The Following User Says Thank You to ike44 For This Useful Post: | Yobiwan (02-09-2013) |
#73 |
Meh!
Drives: Satin White, 86, Manual
Updated, do not use solid core cat5e when it comes to soldering. I've f#^ked up my pcb and I need to wait for replacement to come from Japan.
Ike44 - one thing that I didn't take in to account, make sure you dremel enough that the physical buttons are not pressed. I only found out the hard way going around a corner. Dash flexs a lot. Dezoris - I sure you have a lot to comment on dashboard flex n sound :P, nice part 2 video. I'm sure you got a lemon and scion should replace it. Cheers, Sam |
#74 |
Drives: Focus ST
#75 |
Drives: Focus ST
Is there any update on the software
#76 |
Meh!
Well, small update. After F#&king up a head unit I bought myself a new one and thought I would just hack away behind the dash.
Here are some photo's of whats involved. ![]() ![]() As I'm about to cut out the last little bit, the Dremel broke, Yay! So if you are going to use a Dremel with flex arm attachment you'll probably break it since its to tight to get in for long period of time. Get yourself a right angle attachment. How I've got to replace my friends tools. ![]() I really want to put together a new thread once I have everything complete, who knows when that will be as Murphy keeps kicking me in the nuts! Cheers, Sam |
| The Following User Says Thank You to MaXimus For This Useful Post: | CxG (04-01-2017) |
#77 |
Drives: Whiteout FR-S
@Dezoris I'm looking to do the same setup as you but I'm really lost on the tablet mount. Can you share any more info/pics on the actual tablet mount?
#78 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
#79 |
Meh!
It's basically pinned by the bezel n where the bezel clips in.....don't worry you can push quite hard nothings going to happen.
#80 | |
Mine is pinned into the bezel by the head unit bracket behind, very simple. I will get more pics tomorrow.
#81 |
Drives: Hot Lava
Can you post pictures on how you powered the inverter in the glove box? Or describe how to power it?
#82 |
There is a 12v outlet hidden in there. However when I get this finished I will hard wire.
#83 | |
Drives: BRZ Limited DGM Automatic
#84 | |
Drives: argento frs; 90 mustang gt
what the frs has:
| Nexus 7 Tablet | Lefty | Electronics | Audio | NAV | Infotainment | 63 | 06-13-2015 02:18 PM |
| Tablet Install Build Diary | Dezoris | Electronics | Audio | NAV | Infotainment | 98 | 03-13-2014 01:40 PM |
| Longo Scion Demo Build Journal - Car arrives next week | xravexboix | Member's Car Journals | 12 | 06-15-2012 01:00 AM |
