#15 |
Drives: FR-S MT & FJ Cruiser
Shift knob...
Some will fall in love with life and drink it from a fountain That is pouring like an avalanche comin' down the mountain |
#16 |
Drives: BRZ(sold), STI
Meh, I have no interest in arguing.
Here's my position and I'll just leave it at that: 1) You warranty can't be voided. A claim can be denied. 2) If you're substituting non OEM-spec parts your claim CAN be denied. If you're running 20" rims with XXX/10/20-profile tires, your car is getting a crapload more viabration to the taillight housing. So your claim CAN be denied. It probably won't be when there are numerous other cases of leaky taillights with cars running normal wheels. If your rear window falls out (or some other vibration-caused failure that doesn't occur to other cars) - your claim CAN and is LIKELY to be denied because of the 20" rims. What constitutes "oem-spec" sometimes is clearly defined (in case of replacement service parts) sometimes is vague and manufacturers' warranty departments take stands on what they might be prepared to defend in court, should there be a need to. If your intake screws up airflow sensor reading and dupes the engine into running leaner - it's non-OEM spec and manufacturers won't have to prove that your engine went kaboom because of the intake, they just have to prove that the said intake CAN make the car run lean to prove reasonably that it's not done to OEM spec. After proving the latter there's no need to prove causality. 3) Bringing up M-M (because a lot of people out there mistakenly believe that whatever crap they install on their cars the dealer/manufacturer have to prove something) when you have an uncooperative dealer due to your mods -- is an almost surefire way to get them to cooperate less even if your problem is widespread among non-modified cars. 4) So my best advice - forget M-M completely, it doesn't apply to anything enthusiasts do to their cars. If you have a common problem - argue that the problem is occurring to non-modified cars. If you bought a new just-released car, modify knowing that you run the risk of being screwed simply because there won't be enough data to claim that the problem is common on non-modified cars. |
#17 | |
Drives: Moped
#18 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Not if the dealer can prove that because of the non-OEM spec knob you can shift faster, thus damaging the transmission. Of course, that is if your window hasn't fallen out first from the faster-than-normal shifting!!
Actually, there's a lot of logic in dsgerbc's posts. Just not sure how much logic really matters in most warranty cases. Some dealers will try to deny every claim while others will go the extra mile to keep a customer satisfied. And I find that a lot of what they will and won't do for you depends on how you approach them with a problem in the first place.
"You'll never know if you don't try" - Shinroko Momose |
| The Following User Says Thank You to Clembo For This Useful Post: | Lonewolf (06-20-2013) |
#19 |
Drives: 2013 BRZ Sport Tech White Pearl
Thanks for all of the replies guys. Got quote heated as it is a very debatable topic.
I'm thinking about getting a nameless axelback, which I could swap the stock back on before any servicing. Definitely staying away from an intake as I've had a seized engine denied due to an intake alone. Thoughts on the axelback? |
#20 |
Drives: Asphalt AT
#21 |
Unemployed DIY Ninja
Drives: 2013 SWP BRZ, 1983 MB SD300
I don't understand why the dealerships are such assholes sometimes... Don't warranty-related fixes cost them nothing?
2013 SWP Subaru BRZ - Panda'd
FS: BNIB WORK 11R 17x9 +38 [Custom] 5x100 PCD [Custom] 56.1 Bore |
#23 |
(=^・ェ・^=)
Drives: 2013 FRS, '08 GSXR 600
Some of the dealerships around where I live actually have shops that do modifications to some of their cars and will throw on whatever you bring to them. I've been told some dealers throw superchargers on to tundras and there are usually a hand full of FJs, Tacomas, and Tundras with full lift, winch, and light bar treatment all covered under warranty. If they can install the part it's covered by them. Some of the larger dealerships sponsor some race/show cars but I have yet to see one lol
#24 | |
In dealing with the manufacturer the dealer should be your friend/first line of defense. A lot will depend on how the dealer reports your case to the manufacturer. If you piss-off your dealer to begin with you might have to spend waaay more time on the phone with the manufacturer, even if your case is fairly strong. |
#25 | |
#26 | |
Drives: Asphalt FRS
#27 |
Drives: 13 Whiteout
Will a blown strut/shock be coverd if the owner is over weight?
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
| Will A Tune Void My Warranty? | Apex Chase | Engine, Exhaust, Transmission | 12 | 07-13-2015 02:19 PM |
| Will TRD parts void brz warranty? | lavisxice | BRZ First-Gen (2012+) — General Topics | 16 | 06-26-2014 12:24 PM |
| Will e15 void the warranty? | dawnst3ar | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 12-05-2012 02:59 PM |
| What Will Void My Warranty ? | ScionFR-S | Issues | Warranty | Recalls / TSB | 6 | 11-10-2012 12:36 AM |
| Will This Mod Void My Warranty? | Apex Chase | Engine, Exhaust, Transmission | 7 | 07-17-2012 12:38 PM |
