Old 06-17-2013, 04:32 PM   #1
Carwhisperer
Drives: A lot of supercars.
CEL P0456
Evaporative Emission Control System Leak Detected (Very
Small Leak).
Has anyone else had this problem?
Carwhisperer is offline   Reply With Quote
Old 06-17-2013, 05:57 PM   #2
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Tighten your gas cap. Sounds silly, but that's usually all that will be.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
Carwhisperer (06-17-2013)
Old 06-17-2013, 05:59 PM   #3
256brz2013
Drives: 2013 white brz
Probably gas cap?
256brz2013 is offline   Reply With Quote
The Following User Says Thank You to 256brz2013 For This Useful Post:
Old 06-17-2013, 06:12 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
^^^^X3
Yup, I've seen this code before and all that needed to be done was retighten the gas cap to make it go away...
The Following User Says Thank You to Lonewolf For This Useful Post:
Old 06-17-2013, 06:28 PM   #5
Carwhisperer
I made sure it was tight, reset the code and drove it around, no cel yet. But, I was curious and loosened up the cap and drove it again and no CEL popped up. I'm going to drive it around tomorrow and see if it'll pop up again with the cap loose.
Old 06-18-2013, 06:16 PM   #6
Carwhisperer
So today I got the exact same CEL again after work right when I started up the car. Its not my gas cap. Its tight. I drove home and I went through almost 2x as much gas as I normally do ( 12 mile commute ) and went through almost a gallon of gas. I've had DI seal issues in the past. Wondering if this is related. Nothing is leaking to the ground which is worrysome.
Old 06-18-2013, 06:19 PM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Anyone get P0451 codes?
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
whataboutbob (10-31-2013)
Old 06-18-2013, 06:52 PM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
Well the easy solution isn't the answer this time...
On my stepmom's bmw it was a $1,000 repair to make this cel go away...
Time for another dealer/warranty visit
Old 06-18-2013, 06:55 PM   #9
Carwhisperer
awesome..
Old 06-18-2013, 07:44 PM   #10
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Check any vacuum lines. Last time I had that code it was due to a pinched vacuum hose line after installing a cai. Different car though.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Carwhisperer (06-18-2013)
Old 06-18-2013, 08:12 PM   #11
Carwhisperer
I do have a perrin CAI, ill check around again.
Old 06-18-2013, 10:31 PM   #12
Carwhisperer
My engine has been lifted out 2 times for DI seal replacements. Would that have anything to do with a possible vacuum hose line if it was related to how the mechanic put it back in?
Old 07-08-2013, 09:52 PM   #13
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Did figure this out
Old 07-08-2013, 10:19 PM   #14
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Originally Posted by whitefrs View Post
Did figure this out
do you have this CEL? are you with FI?
