Old 06-16-2013, 12:54 AM   #239
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Danbo is sad he can't fit in his 86
20130613-DanboToy86-014 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
PERRIN_Chris (06-17-2013)
Old 06-16-2013, 04:16 AM   #240
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by F1point4 View Post
Rexpeed Convex Mirrors
Picked these up Jeremy and Yo at @FT-86 SpeedFactory. Always stand up citizens in our community. Thank you.
No DIY on this. Jeremy has a great post about them here. http://www.ft86club.com/forums/showp...0&postcount=73
I bought these mostly because I hated getting flashbanged by the lowbeam headlamps of Lorries and Tall MPVs at night. Bonus add that I can see a whole lot more including my blind spot. The more information I have the better driver I can be. They are a bit expensive but I really hate getting flashbanged.
Flickr
Thanks for the post! Now I got another thing to mod on my car ^_^
stevo_12v is offline   Reply With Quote
Old 06-16-2013, 09:55 AM   #241
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Good post Victor. I definitely need to *look* into these.
Sent from my LG-E980 using Tapatalk 4 Beta
PhastekSport is offline   Reply With Quote
Old 06-16-2013, 07:30 PM   #242
F1point4
Photo Specialist
F1point4's Avatar
Something is coming
In preparation of installing an AFR gauge, I needed to add an O2 bung to my exhaust. I usually do all my mods myself, but I have no idea how to weld. After seeking recommendations from the Houston 86 facebook page, I chose to go with DD Performance Research.
Dave was pretty helpful getting me setup over the phone. When I got there, the place, although remote, was clean and full of MR2s. Looked busy so it was a good sign for me.
Overall I was impressed by the work done, their flexibility, and teaching me a whole bunch about cars in general and fabrication work. I had some other plans in mind which required custom brackets and they made them for me on the spot. Much better than I could have done with makeshift tools.
For the uninformed, the bung for the wideband O2 sensor should go after the merge collector in the exhaust manifold (header) and before the any catalytic converters.
Something tells me I'll be coming back in the future for fabwork.
Onto pictures!
Danbo is taking the opportunity to inspect the car while it's on the lift
20130614-DDPR-WidebangBung-063 by VictorN07, on Flickr
He's trying to figure out where a bung would go
20130614-DDPR-WidebangBung-073 by VictorN07, on Flickr
I was concerned about the bung location. Initially I was concerned there wasn't enough room on the front pipe in front of the cat, but the fabricator assured me it was plenty.
20130614-DDPR-WidebangBung-080 by VictorN07, on Flickr
I know adding a bung isn't hard but I did learn a ton about proper tools and technique when doing this stuff.
20130614-DDPR-WidebangBung-085 by VictorN07, on Flickr
The fabricator getting to work
20130614-DDPR-WidebangBung-103 by VictorN07, on Flickr
Super clean work. Looks like it came from Perrin that way. This is a 2.5" catted front pipe from Perrin performance. Shoutout to @PERRIN_Chris
20130614-DDPR-WidebangBung-147 by VictorN07, on Flickr
20130614-DDPR-WidebangBung-131 by VictorN07, on Flickr
The fabricator told me a good sign of welding is that the material doesn't go through to the other side. Had no idea so I took his word for it. Upon inspection that was the case so good job? haha. He was surprised I was so excited about a bung install
20130614-DDPR-WidebangBung-124 by VictorN07, on Flickr
Before
20130614-DDPR-WidebangBung-052 by VictorN07, on Flickr
After
20130614-DDPR-WidebangBung-151 by VictorN07, on Flickr
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
PERRIN_Chris (06-17-2013), SkAsphalt (06-17-2013)
Old 06-16-2013, 08:20 PM   #243
F1point4
Photo Specialist
F1point4's Avatar
Tuning!
Well...tuning of the wiring inside my cabin. Since I purchased Lola I have added a few gadgets to the inside. Traditionally I've been a fan of using add-a-circuits to the stock fuse box, but it is getting crowded and adding a gauge to the car would make things messier.
I decided to get a fuse block and clean up all my wiring because I believe in clean. Haha. It'll also make wiring the gauge a lot easier since I don't have to add a 5th add-a-circuit to my fusebox and add a 5th wire to the ground screw. Removing add a circuits also prevents my accessories from messing with the circuits i'm tapping into.
I have four accessories I planned on wiring up
Dashcam, Radar, AVO Throttle Controller, AEM Gauge
This is no DIY, just pure information. Please note there are a lot of ways to achieve what I did.
Let's go
The foundation of my system. BlueSea Systems 5025 Fuse Block.
The cover to the box can hold two spare fuses. A 15 amp fuse comes with it. The only thing I don't like is that the box is kinda big, and it uses the big ATO(?) fuses. I'd like if it was consistent but can't win them all. I also couldn't find a good fuse block on amazon so I kinda settled on this one.
http://www.bluesea.com/products/5025..._Bus_and_Cover
20130614-ProjectCleanupElectricals-017 by VictorN07, on Flickr
Cover off. It can support six circuits. Has a ground and positive bus. Supports 30A per circuit. I could add one of these under the hood for my lighting circuits
20130614-ProjectCleanupElectricals-022 by VictorN07, on Flickr
Before pictures
20130614-ProjectCleanupElectricals-028 by VictorN07, on Flickr
That connector on that white L plastic bracket has to move. Easy enough to unclip from the bottom.
20130614-ProjectCleanupElectricals-029 by VictorN07, on Flickr
It moves to make room for my mounting circuit. I chose this area because
1) I didn't find a good spot on the passenger side
2) I didn't want to run a wire directly to my battery. I didn't need that kind of amperage. The accessories that I was hooking up to the block are switched by ignition so I didn't need an always hot connection to the battery
3) This was close to the stock fuses, so I can tap into it for power for the block
4) I wouldn't have to run a ton of new wiring, or move all my accessory wires
20130614-ProjectCleanupElectricals-032 by VictorN07, on Flickr
Cluster of wires
20130614-ProjectCleanupElectricals-034 by VictorN07, on Flickr
Fuse box cover off. You can see I have four add-a-circuits here. Getting busy under there
20130614-ProjectCleanupElectricals-039 by VictorN07, on Flickr
20130614-ProjectCleanupElectricals-050 by VictorN07, on Flickr
I digress
People have asked me how I mounted the hardwire for the radar. Here are two pictures. Not the cleanest, but it can't be seen and it works
20130614-ProjectCleanupElectricals-055 by VictorN07, on Flickr
20130614-ProjectCleanupElectricals-060 by VictorN07, on Flickr
Going to work
Ground wire
20130614-ProjectCleanupElectricals-071 by VictorN07, on Flickr
Positive wire - It will tap into the fusebox on a non system critical circuit - cigarette power plug. I just put moderate sized fuse in it. 10A. Plenty to support what I will be using it for
20130614-ProjectCleanupElectricals-073 by VictorN07, on Flickr
Coming together
20130614-ProjectCleanupElectricals-077 by VictorN07, on Flickr
Before of all my accessory wires.
20130614-ProjectCleanupElectricals-065 by VictorN07, on Flickr
The after. I wrapped everything and shortened some wires.
20130614-ProjectCleanupElectricals-081 by VictorN07, on Flickr
Danbo showing off
20130614-ProjectCleanupElectricals-083 by VictorN07, on Flickr
Labeled cover
20130616-ProjectElectricalWrapup-001 by VictorN07, on Flickr
Much better. The fuse block is taped on with 3M Red double sided tape
20130616-ProjectElectricalWrapup-005 by VictorN07, on Flickr
I'm not totally finished with adding the gauge so I don't have final pictures of what everything looks like. What is there so far looks very very clean.
Hope this gives people some ideas on keeping stuff neat under there.
The Following 5 Users Say Thank You to F1point4 For This Useful Post:
FutureFT86 (02-09-2018), L3P47 (06-24-2013), michaelneal9900 (03-11-2018), Pointmutation (09-09-2018), radroach (06-20-2013)
Old 06-16-2013, 08:42 PM   #244
F1point4
Photo Specialist
F1point4's Avatar
Coming together
I did the exhaust modification and wiring cleanup to support this mod. More information to come.
AEM Wideband Failsafe gauge. Shows AFR and Boost in one gauge.
20130616-AEMWidebandFailsafeFinished-007 by VictorN07, on Flickr
20130616-AEMWidebandFailsafeFinished-019 by VictorN07, on Flickr
JDKane527 (06-17-2013), SkAsphalt (06-17-2013)
Old 06-17-2013, 12:04 PM   #245
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
This little guy is hilarious! Who is he? Was he made by Amazon?
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
F1point4 (06-17-2013)
Old 06-17-2013, 02:29 PM   #246
F1point4
Photo Specialist
F1point4's Avatar
he's from a character from the Japanese Manga series Yotsuba. I don't read manga, but have seen his picture floating around the internet. WHen I saw him in japan I had to buy him
http://f-bay.tumblr.com/post/5700962927/danbo
Old 06-17-2013, 02:41 PM   #247
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
This is my favorite build. Your doing almost everything I wanna do with my frs. Great job.
velin86 is offline   Reply With Quote
The Following User Says Thank You to velin86 For This Useful Post:
Old 06-17-2013, 03:07 PM   #248
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
For the AEM gauge did you have to use an adapter to fit the 60mm ATI pod? Most of their gauges I found were 52mm.
JDKane527 is offline   Reply With Quote
Old 06-17-2013, 03:11 PM   #249
F1point4
Photo Specialist
F1point4's Avatar
Yes I did. ATI makes an adapter for this.
Part Number: ATI 52/60-CONV
Old 06-17-2013, 03:13 PM   #250
JDKane527
JDKane527's Avatar
Cool, I went with the Defi 60mm gauge to fill the space. I do like the look of the 52mm gauge though.
The Following User Says Thank You to JDKane527 For This Useful Post:
Old 06-17-2013, 10:00 PM   #251
velin86
velin86's Avatar
Are you using the Perrin Transmission Support along with the Whiteline Gearbox one? Any Modification needed?
Old 06-17-2013, 10:02 PM   #252
F1point4
Photo Specialist
F1point4's Avatar
I'm only using the whiteline one. I did not make the modification needed for the two parts I had in my hand to fit.
I am not sure if either vendor made revisions to their products since my writing.
Hope that helps!
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 01:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 05:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 01:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 07:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 04:16 PM
