Old 06-17-2013, 12:27 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by retrosmiths View Post
Could you link me to more info about this symptom? :eek:
Sent from my Galaxy Nexus using Tapatalk 2
See below. It does not look exactly like what you describe, but similar.
You can hear it "pop" at the dips.
[ame="http://www.youtube.com/watch?&v=450Pov98STg"]BRZ bad idle + misfire, no CEL, stock engine - YouTube[/ame]
Old 06-17-2013, 03:33 PM   #16
retrosmiths
Drives: Scion FR-S Whiteout
I'm at work so I'll be brief.
[ame="https://www.youtube.com/watch?v=-poHI8jVc1I&feature=youtube_gdata_player"]Clunk - YouTube[/ame]
Mine is more like a clunk than a pop, I realize. Happens when stopping hard or accelerating quickly. Could it be a dangling piece of something in the engine bay?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 06-17-2013, 03:43 PM   #17
rx3
Originally Posted by ottopilot
A leaky fuel injector would still leak fuel, as it would be damaged right? Thus the poping we hear when they're damage. I don't know if this applies to the OP here though.
That's doubtful since the seal between the cylinder head and the valve is primarily affected and not the valve itself (and there's no plastic seal within the valve itself which could be molten away or something).
Also, if that valve was broken, it would just dump fuel in and around the combustion chamber which would probably not ignite (and if it would, the car would eventually catch fire and possibly burn down).
rx3 is offline   Reply With Quote
Old 06-17-2013, 04:04 PM   #18
FirestormFRS
That is weird....but it's not muffled like a suspension clunk would be. Damned if I know
FirestormFRS is offline   Reply With Quote
Old 06-17-2013, 04:22 PM   #19
radroach
Drives: car
Sounds like the clutch or torque converter is messing up when he stops, is there any feeling behind the clunk going to your pedals?
Old 06-17-2013, 04:32 PM   #20
retrosmiths
No, just an audible pop-clunk from the front passenger side. Last night it sounds like a rubbery pop but today when I started driving the car cold it sounds like something metal.
2013 Scion FR-S
Old 06-17-2013, 04:43 PM   #21
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I had this noise after I installed rear subframe bushings in my car. When backing out of my driveway, with the steering wheel rotated to the left near lock, but not at lock, it would clunk. After installing rear differential bushing inserts and solid steering rack bushings, sound has gone away, and vibrations are very tolerable, besides being quite enjoyable haha.
JDKane527 is offline   Reply With Quote
Old 06-17-2013, 04:50 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Sounds vaguely like you're stomping on the clutch, mine makes funny noises like that too.
Just the impression that I get.
ineedyourdiddly
Old 06-17-2013, 05:16 PM   #23
Dezoris
Dezoris's Avatar
What mods do you have done up front in terms of suspension, under the hood and exhaust, wheels brakes etc?
Old 06-17-2013, 05:33 PM   #24
retrosmiths
Nothing, it's bone stock save for the headlight retrofit.
2013 Scion FR-S
Old 06-17-2013, 05:39 PM   #25
retrosmiths
Nah, I have the clutch fully disengaged when I braked hard in the video. The clunk is heard right after stopping, right when your body is pulled forward by the sudden lack of motion of the car.
2013 Scion FR-S
The Following User Says Thank You to retrosmiths For This Useful Post:
strat61caster (06-17-2013)
Old 06-17-2013, 05:42 PM   #26
Dezoris
Dezoris's Avatar
When did this start? Did it happen after your bumper removal and re-install?
It sounds like something popping in and out of place.
Check anything that would be loose from your install.
Also check your wheel lug nut TQ. Make sure they are tight as that can cause clunks.
Could be something suspension related as well loose or worn out but thats a dealer trip, impossible to tell without getting under the car.
Old 06-17-2013, 06:20 PM   #27
retrosmiths
Just yesterday when I took it for a long drive.
I'm pretty anal when it comes to screwing the bumper back on because with my previous car, the fender sidewalls gave out on a freeway ride and got shredded to pieces by my tires, so I don't think I missed any screws.
What's the proper torque for the lug nuts (and how much is a good torque wrench)?
2013 Scion FR-S
Old 06-17-2013, 08:57 PM   #28
strat61caster
It should be in the manual, fastest way to find out.
ineedyourdiddly
Sway Bar Popping Sounds? fareastbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 03-28-2020 01:23 AM
Anyone heard any loud popping? Kimsey47 BRZ First-Gen (2012+) — General Topics 103 07-30-2013 10:27 PM
Light popping sound when I steer, even when parked. Jar Issues | Warranty | Recalls / TSB 2 06-01-2013 06:27 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 07:58 AM
The number 86 popping up everywhere.. CSSM Off-Topic Lounge [WARNING: NO POLITICS] 19 06-19-2012 12:15 PM
