Drives: Scion FR-S
Injectors installation
Is it me or is there absolutely no information on how to install injectors on our car?
Is it just really simple so no one is making a guide? I've looked all over for it! |
#2 |
Boostin'
Drives: FRS-T
Super simple, as soon as visconti sends me my tune i ll install them and i ll do a diy
#3 |
NASA SpecE30 Racer
Here is my simple guide:
Passenger Side: 1. Unbolt injector driver ECU 2. Unbolt metal sound deadening cover 3. Unbolt fuel rail 4. Unclip injectors 5. Remove injectors 6. Install new injectors 7. Bolt fuel rail back down (depending on injectors, might require spacer as well) 8. Clip in injectors (depending on injectors, might require wiring adapters) 9. Reverse of removal Driver Side: 1. Disconnect both fuel lines with a fuel line removal tool (will be smallest one available at local parts store and is a plastic tool that goes in the end of the fuel line) 2. Disconnect the fuel vent hose which is held on with a standard clip 3. Unbolt metal sound deadening cover 4. Unbolt fuel rail 5. Unclip injectors 6. Remove injectors 7. Install new injectors 8. Bolt fuel rail back down (depending on injectors, might require spacer as well) 9. Clip in injectors (depending on injectors, might require wiring adapters) 10. Reverse of removal
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#4 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Are you asking about the port injectors or the direct injectors...?
#5 |
Sideways and Smiling!
Drives: Scion FR-S
Someone got a guide for both port and direct injectors?
#6 |
Boostin'
Drives: FRS-T
Direct injectors will require a special tool
#7 |
Drives: Scion FR-S
#8 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
It will require a special tool to replace seal.
Why would u replace DI? The only ones to replace are Port with bigger injectors
#9 |
Boostin'
Drives: FRS-T
#10 |
Drives: Scion FR-S
#11 |
Love Boost!!!!!!!!
There is no higher glow Direct injectors
But there is port injectors
#12 |
Drives: Scion FR-S
Watch out when you reinstall the injectors & their power connector.
My problem was that one of the power connectors was rubbing on the side so it short circuited and the car wouldn't start. |
#13 |
Also the direct injectors have 3 different part numbers based on their stratified flow number. So they need to be removed for inspection before ordering and replacing which makes it a total bitch when their is a 30-60 day lead time to get parts
#14 |
I asked this on the DT flex fuel thread but thought I would put the question here as well:
Need some advice here: I'm installing the DW700cc injectors along with my DT flex fuel kit. I upgraded to the fuel injector adapters that connect between the DW injectors and OEM connectors. But now I can't fit the drivers side metal cover over the injectors because the adapters are in the way. Is it okay to leave the the metal cover off? Should I trim the metal cover (which would be a bitch I imagine)? Or have I angled the injectors incorrectly. I feel like I tried every combo. The passenger side metal cover was a tight fit but I managed. |
| So what exactly will aftermarket feul injectors do to my frs | Frsexxxy | Engine, Exhaust, Transmission | 8 | 03-10-2013 12:28 PM |
| Deatschwerks Injectors - Released | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 0 | 09-08-2012 04:20 PM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 06:29 PM |
