Old 06-15-2013, 01:37 AM   #939
vgi
Drives: frs
so is the kit offered for sale already?
Coming soon! Call or order today to be one of the first to have this supercharger system on your Scion FR-S or Subaru BRZ!
http://www.frsmod.com/products/innov...er-for-frs-brz
vgi is offline   Reply With Quote
Old 06-15-2013, 01:47 AM   #940
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
From what I was told at this time innovate is the only company selling these and no other company is an authorized vendor so beware of giving your money to anyone because they do not actually have any kits.
Sent from my Q10
Old 06-15-2013, 02:31 AM   #941
sw20kosh
Drives: 2013 Black FR-S
Update:
Car dyno'd and running strong. We got the expected performance from the kit.
Water/meth injection added 20 hp and extra torque everywhere from 3,000-7,500. It also flattened out the top end even more. Good results today. Robi's tuner worked his magic. It allowed 3 degrees of timing advance among other things. This is with the smaller nozzle (5gph 313cc/min) supplied with the kit. Will test the larger nozzle (7gph 440cc/min) down the road with a progressive MAF based controller.
Time to hit the track tomorrow and sunday.
The Following User Says Thank You to sw20kosh For This Useful Post:
whataboutbob (06-17-2013)
Old 06-15-2013, 02:34 AM   #942
sw20kosh
Originally Posted by Subzero View Post
Thanks. I was wondering if the throttle had good depth and usability or just "snapped".
Good depth and usability.
Subzero (06-15-2013)
Old 06-15-2013, 05:53 AM   #943
swift996
swift996's Avatar
Originally Posted by sw20kosh View Post
Update:
Nice, when can you share the dyno?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 06-15-2013, 10:22 AM   #944
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Update:
Where did you inject the water/meth?
Sellout is offline   Reply With Quote
Old 06-15-2013, 10:34 AM   #945
sw20kosh
Directly before the supercharger rotors. This was recommended by someone who has been meth injecting positive displacement superchargers for decades.
If you inject pre supercharger you:
1. Can inject 3-4 times as much as the rotors further help to atomize the fluid and the rotors actually take up a fair bit of fluid as they have large surface area compared to centri compressors on turbo and centri sc.
2. You cool off the hot rotors significantly increasing their efficiency (heat kills efficiency)
3. You soft-seal the rotors to each other allowing them to be more efficient at producing boost. You can typically gain up to 1-2 psi depending on application whereas with an intercooler you typically lose psi due to pressure drop across the intercooler.
* It allowed 3 degrees of timing advance among other things. This is with the smaller nozzle (5gph 313cc/min) supplied with the kit. Will test the larger nozzle (7gph 440cc/min) down the road with a progressive MAF based controller.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
Pete (06-15-2013), swift996 (06-16-2013), uspspro (06-16-2013)
Old 06-15-2013, 10:50 AM   #946
Sellout
Mr. Cranky Pants
Sellout's Avatar
Now I remember seeing it back a few pages... Yeah you're cooling the rotors, cooling the charge, and effectively adding octane. No doubt it's effective. I wonder if all the concern about rusted/pitted rotors is just internet BS, like so much other crap we hear on forums every day...
Old 06-15-2013, 11:41 AM   #947
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Curious--did you see more boost with w/m?
Subzero is offline   Reply With Quote
Old 06-15-2013, 12:17 PM   #948
sw20kosh
According to my guy Rodney at alcohol injection systems . Com there was a problem with one particular batch of roots blowers where the coating naturally de laminated from wear. A rumor got started from that and meth got blamed. He said he has never had a problem in decades.
Old 06-15-2013, 12:22 PM   #949
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
I think they are all hard anodized rotors. I didnt pull mine apart to see before installing it. I know a lot of the top fuel guys will have the rotors teflon coated for less friction. but then they replace them almost every round.
Glad to see more CA guys running this kit. Cant wait to hear your results from the track day.
tom@kartboy is offline   Reply With Quote
Old 06-15-2013, 12:27 PM   #950
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by jasper View Post
It says inter-cooled with a 75mm pulley. It is also a totally different type of power dilivery than vortech.
Sent from my Q10
I am comparing the two exactly because of the difference in power delivery. I like the twin screw better due low and mid range torque. Just wanted to overlay the torque charts and compare. Unless you are consistently driving in the very upper rev range this kit is superior to the Vortech.
Looks like a great kit.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-15-2013, 12:31 PM   #951
ahausheer
Re-member
No, it shows a torque dip and a horsepower dip on the baseline.
No, there is also a torque dip on the FI dyno, just at a higher rpm and its less significant, but its still there.....Jesus.
Old 06-15-2013, 02:09 PM   #952
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I was considering nitride coating mine to reduce fricrion but i have no idea if that can be done to this blower and what the downsides of doing it would be.... anyone have insight? Like has anyone here done this with a blower before?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 10:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 10:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 01:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 04:40 PM
