Old 06-14-2013, 06:10 PM   #925
Carwhisperer
Drives: A lot of supercars.
Tried to see if this was asked through the past 2 pages since I'm lazy, but didn't see it. Would the stage 1 kit work with my Perrin CAI?
Carwhisperer is offline   Reply With Quote
Old 06-14-2013, 06:14 PM   #926
sw20kosh
Drives: 2013 Black FR-S
Yes. Any kit that uses the stock air box as an intake can use the perrin cai
The Following User Says Thank You to sw20kosh For This Useful Post:
Carwhisperer (06-15-2013)
Old 06-14-2013, 06:54 PM   #927
robispec
Drives: Black frs project
Exactly. But keep testing and tuning so I can get said money together.
Sent from my SPH-L900 using Tapatalk 2
I can do that for you.
robispec is offline   Reply With Quote
The Following 2 Users Say Thank You to robispec For This Useful Post:
Accurate Race Shop (06-14-2013), sw20kosh (06-14-2013)
Old 06-14-2013, 08:00 PM   #928
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Robi---how's the behavior in tight corners with your suspension/wheels/tires? Does it still want to step out gently or does it feel like it wants to swap ends?
Subzero is offline   Reply With Quote
Old 06-14-2013, 08:52 PM   #929
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
I'll be installing our GT Guard Trans rear diff next week. Should help with putting the power down. http://www.guardtransmissionllc.com/...differentials/
tom@kartboy is offline   Reply With Quote
Old 06-14-2013, 09:23 PM   #930
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
That has got to be a $2K+ diff..
Old 06-14-2013, 09:47 PM   #931
robispec
Very easy and predictable to drive it's like we put a V6 in the car and you want to backend to step out just start adding throttle. but it's nice and predictable there's no nasty power surge there's no uncontrollable kick. That is because it's making boost right from idle. Linear is the power curve.
The Following User Says Thank You to robispec For This Useful Post:
whataboutbob (06-17-2013)
Old 06-14-2013, 10:04 PM   #932
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
The dyno from down-under showed the torque dip still in the equation, just at a higher level of torque. Can that be tuned out? Or should we invest in a header to get rid of that?
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 06-14-2013, 10:46 PM   #933
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by invisage View Post
Here it is finally.... 3rd party Unicorn numbers 172KW / 230HP
Only has Perrin cat back (waiting for headers, overpipe etc to turn up) and is on an auto transmission. Intercooled kit with 75mm pulley.
Will take some drive by, in car ect ect over the weekend and post.
Forgive me but is this the inter-cooled or non? Im comparing this dyno to the Vortech, want to compare apples to apples.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-14-2013, 10:56 PM   #934
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
No, it shows a torque dip and a horsepower dip on the baseline.
There is no intersection here. The thick lines go together and the thin lines go together.
What he means is the thin lines are the baseline horsepower/torque. The thick lines are the supercharged horsepower/torque. There is no intersection because of the scaling on that dyno plot.
Your answer is in the post that you quoted. Jesus...
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
buckets (06-16-2013)
Old 06-14-2013, 10:59 PM   #935
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Thanks. I was wondering if the throttle had good depth and usability or just "snapped".
Old 06-14-2013, 11:00 PM   #936
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
It says inter-cooled with a 75mm pulley. It is also a totally different type of power dilivery than vortech.
Sent from my Q10
Old 06-14-2013, 11:14 PM   #937
akuhei
akuhei's Avatar
Ahh...confusing dyno is confusing. Guess I am used to seeing colors as a pair for one run, not having both blue being power and green being torque. took me a minute to figure out. thanks.
Akuhei's Blog
"Inconceivable"
Old 06-15-2013, 12:00 AM   #938
tom@kartboy
Not sure. We sent our full diff out to Matt so he could reverse engineer it.
I'll post some pictures. its a thing of beauty for sure.
Tom
The Following User Says Thank You to tom@kartboy For This Useful Post:
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
