Old 06-14-2013, 09:06 AM   #155
radroach
Drives: car
I had lots of 3rd gear syncro feel for a long time, but it seemed to stop after 10,000 miles. Shifts great now.
Old 06-14-2013, 05:24 PM   #156
Carwhisperer
Drives: A lot of supercars.
Same with my 4th gear exactly after 10k miles. Interesting.
Carwhisperer is offline   Reply With Quote
Old 06-14-2013, 05:25 PM   #157
OrbitalEllipses
Drives: Attitude
My 3rd gear synchro has been acting up again.
Old 06-14-2013, 05:59 PM   #158
Chee-Hu
Chee-Hu's Avatar
I just passed 10k as well and noticed the shifting a little more smoother.
Chee-Hu is offline   Reply With Quote
Old 06-14-2013, 06:15 PM   #159
Carwhisperer
Seems like a noticeable pattern for the transmission. My 4th gear used to be scary going into for the first time and if I went into it again it would be okay. But since 10k miles I'm good. Downshifting 6th to 5th (going 70 mph+)will grind sometimes unless if I do it extremely slowly as of right now.
Old 06-14-2013, 07:43 PM   #160
86KEEBS
DRIFT
Drives: Raven FRS 6mt
I havent had any problems downshifting (try to rev match when I can) but the odd time it is tough to get into first gear while stopped. Happened more in the winter due to the cold, but still happens now on warm days. Ive had a couple cars that I would have to bump second to get into first smoothly, but doesnt work with the frs... It does not grind into gear, just tough and takes a bit of playing sometimes. Hot, cold, doesnt seem to matter. Also, second gear actually grinded a couple times trying to 1-2 shift.
I heard thinner trans oil has helped some ppl with similar problems up here in cold Canada. thoughts?
86KEEBS is offline   Reply With Quote
Old 06-14-2013, 08:01 PM   #161
vgi
Drives: frs
for those who haven't seen this thread i think it's worth reading, make your own judgment
http://www.ft86club.com/forums/showthread.php?t=16604
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
448hpsti (09-02-2013)
Old 06-22-2013, 04:14 PM   #162
Cal3000
Drives: Panda FR-S
This exact same thing is happening to me. I took it to the dealer for them to check it out. They said they ordered the parts and will fix it. That was a month ago. I'm still waiting for their call.
Cal3000 is offline   Reply With Quote
Old 09-02-2013, 02:30 AM   #163
asianCHAU
asianCHAU's Avatar
Drives: 2013 Whiteout FRS
Did yours have a crunch when you shifted into 3rd while barely accelerating? Mines fine if I accelerate a decent amount, perfectly smooth. I hope mines stops at 10k miles...I currently have 2700 miles.
asianCHAU is offline   Reply With Quote
Old 09-02-2013, 10:51 PM   #164
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i have that crunch in 3rd as well if i'm light on the gas. Mine seems to change all around how it feels every so often. At the moment, i have 2nd feel real rough downshifting from any gear at any rpm and 1st often gets stuck half way in at a dead stop with the clutch in for a few seconds. No grinds though. I dunno what its deal is. i'm at 4500 miles
abutterman is offline   Reply With Quote
Old 09-03-2013, 10:41 AM   #165
radroach
Drives: car
Yes, I sometimes feel an uncomfortable click when shifting to third at the wrong speed. I think it also has to do with shifting technique - these days I hold the shifter in my hand while putting it in gear, rather than just throwing it in gear like I used to. The gearbox is temperamental, sometimes it wants to be held and rowed, and sometimes it wants to be thrown.
Old 09-03-2013, 10:51 AM   #166
radroach
Drives: car
Same problems here, 1st gear gets stuck halfway in- not a huge problem but it is a fault.
Sometimes the car is such a breeze to drive, and is very smooth going between gears and getting to speed without fussing and puts a big smile on my face- and then other days the car seems so jarringly rough and unsettled and is hard to drive. Not sure if I just suck at driving or if the car has hidden bugs in it that make the car difficult to drive.
The Following User Says Thank You to radroach For This Useful Post:
BRZkitty (10-05-2013)
Old 09-03-2013, 10:53 AM   #167
abutterman
abutterman's Avatar
exactly what i have going on. today going to work it felt great... right up until i was stopped at a light, put the clutch to the floor aaaaand 1st gear stuck half way in. took 3 tries to get it to go in
Old 09-03-2013, 11:15 AM   #168
radroach
Drives: car
What's worse is when you don't realize you missed putting it in 1st, so it pops right back out of gear or starts grinding. -cringe-
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
