Old 06-14-2013, 09:02 AM   #15
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
After reading numerous pieces of advice from pros to "anonymous internet soothsayers", I have developed my own checklist for winter prep. Since I live in southern Michigan, my storage interval is from late October/mid November to mid/late March. See attached file.
Note: Dumping a full tank of fuel and not using it in a week's time (after storage) seems superfluous to me. For what purpose will it be used??? A five to six month old fuel with Sta-Bil does not hurt the engine. The purpose of Sta-Bil is to "stabilize" the fuel.
Winter Storage Prep.doc
BRZfan is offline   Reply With Quote
Old 06-14-2013, 09:36 AM   #16
BRZfan
BRZfan's Avatar
I suggest you just use an electric blanket (king size). Also don't you mean hypothermia?
Originally Posted by ramiram1984 View Post
I put blankets on it and a heater next to it to keep it from hyperthermia
The Following User Says Thank You to BRZfan For This Useful Post:
ramiram1984 (06-14-2013)
Old 06-14-2013, 11:46 AM   #17
5th 86
Drives: 2013 BRZ SPORT TECH
Your goingto miss out of a ton of fun if you park it in winter. Snow tires with nannys off is extremely entertaining.
What i learned from old cars is dont put a cover on if you parking outside cause the cover will scratch the paint from wind blowing/moving the cover around.
5th 86 is offline   Reply With Quote
Old 06-14-2013, 01:23 PM   #18
qts
Drives: 94 Celica and Firestorm
Does remove battery for winter will reset the ECU? Some members suggest using battery maintainer, which one is better?
qts is offline   Reply With Quote
Old 06-14-2013, 01:25 PM   #19
gily25
Drives: Silica BRZ 6MT
Use wheel choks instead of setting the e-brake ($5 each at harbor freight), click the "interior air circulation" button before turning the car off. I didn't have time to research a good trickle charger before it got too snowy so I did the shovel in front of the garage 2 feet, run the engine, pull her back in method. Worked fine for the first year, will work fine if your garage doesn't have power. Vacuum really well and take out anything such as gum or medicines, I put a few moth balls here and there. I used a parachute dust cover from ebay. As others said, oil change, full tank, wax, tire inflation are things I saw on all major car forums when I was looking.
gily25 is offline   Reply With Quote
Old 06-14-2013, 01:26 PM   #20
qoncept
qoncept's Avatar
Yeah, your ecu will be reset if you pull the battery. I would think either pulling the battery or maintaining the charge would be fine. You just want to make sure it doesn't get completely drained and die.
qoncept is offline   Reply With Quote
Winter drive or store? Rob_g CANADA 99 11-21-2014 06:45 PM
Anyone here rob a convenience store in NJ? Chimpo Scion FR-S / Toyota 86 GT86 General Forum 27 02-22-2013 01:06 AM
Our New Online Store! Doug@WGP Announcements, Contests, Giveaways 3 11-26-2012 10:26 AM
Store help.. tintumz22 Southern California 5 07-18-2012 12:58 AM
