Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 06-13-2013, 09:40 AM   #1
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
Nassau County Mechanics
I don't have a regular mechanic and I need to get an exhaust installed... can anyone recommend a quality/affordable mechanic in the area?
Perihelion is offline   Reply With Quote
Old 06-13-2013, 09:44 AM   #2
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i had a couple things done at Real Auto Dynamics in Oceanside. @Kevin@RAD could get you set up
abutterman is offline   Reply With Quote
The Following User Says Thank You to abutterman For This Useful Post:
Perihelion (06-14-2013)
Old 06-14-2013, 08:36 AM   #3
DR1FT
Drives: MBC300
Yeah go to rad n tell them it was my old exhaust system lol
2012 BMW 650i
2011 BMW M3
2013 BRZ Limited-sold
2011 MB C300-sold
DR1FT is offline   Reply With Quote
The Following User Says Thank You to DR1FT For This Useful Post:
Old 06-14-2013, 09:12 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
That'll be about $100 in labor man, you sure you don't want to try doing it yourself? Exhaust is a relatively easy bolt-on upgrade. If you don't have the tools, I'm sure one of us on the island could offer some assistance. Where are you located?
The Following 2 Users Say Thank You to Foobar For This Useful Post:
myjobis2pimp (06-23-2013), Perihelion (06-14-2013)
Old 06-14-2013, 09:44 AM   #5
Perihelion
Perihelion's Avatar
Yeah I was trying to do it myself, but the bolts on the stock exhaust are quite rusted. Also, I bought this used and am missing nuts/bolts/gaskets. I bought some 60mm gaskets but I'm not too sure if they'll do the job.
It'd be great if I can do this without going to a mechanic. I'm in Hicksville, just a couple of minutes away from the train station.
Old 06-14-2013, 10:11 AM   #6
Foobar
SLO NO MO
Foobar's Avatar
Well you definitely want to make sure you have the right nuts/bolts/gaskets or you run the risk of having a leak at some point. Also if the stock bolts are rusted on, you'll probably need an impact wrench to make easy work of it. Did you try spraying some WD40 on it to let it soak in first?
Given your circumstances, an appropriately equipped shop might be the prudent thing to do. That said, if you're trying to save the $100, do you have all the necessary space/tools/jackstands to do this? I live about half an hour away from you.
Some local speed shops that you may want to consider if you go down that path: MR Performance in Westbury, Performance Auto Solutions in Deer Park, JMR Garage in Bayshore.
The Following User Says Thank You to Foobar For This Useful Post:
Old 06-14-2013, 12:11 PM   #7
p00mba
p00mba's Avatar
Drives: FR-S :)
i dont mind helping if you have the tools, or come to my house but it's quite a trip for you...
p00mba is offline   Reply With Quote
Old 06-14-2013, 01:31 PM   #8
Perihelion
Perihelion's Avatar
Yeah I tried WD-40 on them, but it wouldn't budge. I should have all the necessary tools... wrenches/ratchet/jack/stands.
I just emailed Invidia to see if they sell the nuts/bolts/gaskets separately or if they could provide the proper specs for them.
I'll wait to hear back from them before I decide whether or not to take it to a shop. Thanks for the help. I'll let you know if I need more
Old 06-14-2013, 01:31 PM   #9
Perihelion
Perihelion's Avatar
Yeah that's a bit out of the way. Thanks for offering though
Old 06-14-2013, 01:36 PM   #10
Foobar
SLO NO MO
Foobar's Avatar
Don't be shy to use some force on those stock bolts. Use a cheap wrench and smack it around with a hammer if you have to. Ideally, a breaker bar could be used but you won't have enough room without a lift. And if you've already got a lift, you probably have an impact wrench available so you could use that instead.
Anyway, let me know what Invidia says - if you decide to try it on your own and I can fit it into my schedule, I'd be happy to swing by and help out.
Old 06-14-2013, 01:47 PM   #11
p00mba
p00mba's Avatar
Drives: FR-S :)
if the bolts are being stubborn just buy a 3/8 breaker bar from harbor frieght, its worth the 7-8 dollars...
The Following User Says Thank You to p00mba For This Useful Post:
Perihelion (06-15-2013)
Old 06-15-2013, 04:17 PM   #12
DR1FT
Drives: MBC300
Wd-40? Try liquid wrench or pb blaster
2012 BMW 650i
2011 BMW M3
2011 MB C300-sold
Old 06-22-2013, 01:23 PM   #13
Foobar
SLO NO MO
Foobar's Avatar
WD40 a 2-ft breaker bar and a bunch of swear words took care of all his nasty stock bolts.
We had to double up on the gaskets between the mid and front pipes though, not sure what was up with that but even torquing the bolts beyond Invidia's specs left a gap with one gasket. It looked like the sides of the flange weren't completely flush, but I couldn't tell for sure. Anyway, 2 bucks and change later, a second gasket took care of the issue.
System sounds pretty good, even with the catless front - I was expecting a raspy note but it actually sounded like my Perrin before I added the front/overpipe.
@Perihelion - good meeting you man - love the cosmetic stuff you've done with the car, really pops on an SWP! Sorry we ended up taking more than the "worst case" 2-hour estimate I threw out there LOL. Let us know how you like the system now that you've driven it.
Old 06-22-2013, 03:23 PM   #14
DR1FT
Drives: MBC300
I really dont know whats up with doubling the gaskets cause RAD did te install for me. Anyways im glad the exhaust worked out for him. now just tell him to buy my 11R's and his ride will be ballin
2012 BMW 650i
2011 BMW M3
2011 MB C300-sold
Fairfield County CT/Westchester County NY itzo NY / NJ / CT / PA 40 06-03-2013 04:00 PM
anyone near essex county or bergen county? Noke NY / NJ / CT / PA 6 04-06-2013 01:22 AM
AutoX this Sunday 9/16 at Nassau Coliseum! NYC BRZ NY / NJ / CT / PA 17 09-20-2012 10:12 PM
BRZ/FRS Day - AutoX Event @ Nassau Coliseum 9/2!!!! NYC BRZ NY / NJ / CT / PA 74 09-11-2012 07:38 AM
NY Region SCCA AutoX at Nassau Coliseum 7/22!!!! NYC BRZ NY / NJ / CT / PA 1 07-18-2012 01:06 PM
