Old 04-14-2018, 11:15 AM   #71
JMon85
JMon85's Avatar
Drives: 2019 WRX
Thanks for the write-up!! plan on installing these today. Bilstiens have been on back order for some time now & don't know when I'll be lowering. Do these affect ride height?
JMon85 is offline   Reply With Quote
Old 04-14-2018, 12:53 PM   #72
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Ride height won't change.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JMon85 (04-14-2018)
Old 04-14-2018, 06:50 PM   #73
new2subaru
Weight Weenie
Drives: 15 FR-S
I installed these today. It makes an amazing difference!
I took the tires off and snugged up a floor jack onto the diff. All work was done from the side of the wheel well. I unbolted all of the bolts 10 turns so the subframe would come down as even as possible. Then I lowered the jack just enough to get the bushings in the rear. I then removed the drivers side rear bolt added the bushings and reinstalled the bolt. The subframe wants to drop more with the bolt out and at an angle. It just needed to be pried forward slightly to get the bolt to hand thread again. The rest were the same. Only slight tweaking was needed and all bolts were started by hand.
I was dreading doing this mod and it was done in an hour. I've had them for 2 years! I'm relieved...
The Following 5 Users Say Thank You to new2subaru For This Useful Post:
Chimera (05-15-2018), Plumbus (01-12-2021), sroby (08-14-2019), Trueweltall (07-15-2018), Yoshoobaroo (04-14-2018)
Old 04-14-2018, 07:48 PM   #74
Yoshoobaroo
TRACKBREAD
I need to get them on too lol. I've had them since August.
Old 04-14-2018, 07:56 PM   #75
new2subaru
Weight Weenie
Drives: 15 FR-S
lol I was skeptical, but they really do make a difference. I think I'll do the diff bushings next and work my way forward.
http://www.whiteline.com.au/product_..._number=KDT925
The Following User Says Thank You to new2subaru For This Useful Post:
Old 04-30-2018, 09:30 AM   #76
Yoshoobaroo
TRACKBREAD
DIY - Whiteline Rear Crossmember Mount Insert Bushings
Just got mine on yesterday. Didn't even take the wheels off
They make such a difference! I admit to being skeptical before, but the subframe feels almost bolted to the seat! No more weirdness mid turn over a bumpy surface, less wandering at the limit, I love it!
I did notice a significant increase in tire noise. Need to make my exhaust louder now.
new2subaru (04-30-2018)
Old 07-16-2018, 10:47 PM   #77
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I followed your method, using 4 jack stands and myself. I managed to get it done in about an hour and a half. Getting the holes lined back up was rather easy, I was pretty worried about not being able to do this by myself. Along with the subframe bushings I did the differential, and the transmission. What a huge difference! The noise has increased a lot, gear noise that is(mostly first and second gear up to 2400 rpm). I think my rear toe is off now too, my rear tires are pointing inwards and this is the first time I have noticed that. Anyone else have to get an alignment after doing this modification?
Trueweltall is offline   Reply With Quote
Old 07-17-2018, 12:01 AM   #78
Yoshoobaroo
TRACKBREAD
No, the alignment is totally dependent on arms connected from the hubs to the subframe, not the body. You can't have messed up the geometry.
new2subaru (07-17-2018)
Old 07-17-2018, 12:19 AM   #79
new2subaru
Weight Weenie
Drives: 15 FR-S
I'm glad in worked out okay for you. By inwards,do you mean the top of the tire in more inside the fender? That would be camber gained, if so. I ended up with -2
I waited a week or so and then I added camber bolts up front. I'm currently running 1.5F and 2R. I will probably increase the camber up front but want to get some more track time under my belt first.
On the street you wouldn't need to do anything really IMHO.
Old 07-18-2018, 10:26 PM   #80
Trueweltall
My rear camber is now at -2 and 1-8 in the rear after installing these bushings. The toe looks off but I didn't measure that yet. Can't believe bushings change things this much.
Old 08-11-2018, 07:57 PM   #81
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
How do you suddenly get clearance between these two pics?
when I raise it 2" I still don't get enough clearance to place the upper bushing on top between the chassis and sub assembly. There is a gap but I cannot put my finger through/between it, let alone the bushing.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 08-11-2018, 07:59 PM   #82
Lakitu
Lakitu's Avatar
Bah, nvm. I am retarded. You lowered it, not raised it.
The Following User Says Thank You to Lakitu For This Useful Post:
MJones_RB (08-13-2018)
Old 08-11-2018, 08:28 PM   #83
Lakitu
Lakitu's Avatar
I'm still not getting this to work for me, its like the sub assembly is glued to the chassis or something. I lower, everything lowers. I raise, everything raises.
Old 08-11-2018, 09:03 PM   #84
Lakitu
Lakitu's Avatar
YESSS, got clearance with a crowbar! Woot woot
Yoshoobaroo (08-13-2018)
bushing, crossmember, diy, whiteline
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
Installed the Whiteline crossmember bushing(no pics sorry) gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-26-2013 03:00 PM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 10:23 PM
