Old 10-17-2015, 07:47 PM   #253
jort88
jort88's Avatar
Drives: 2014 WRB BRZ
I dont feel bad anymore running 15s with my Prius tires....
jort88 is offline   Reply With Quote
Old 10-17-2015, 07:53 PM   #254
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
I ran 15.01@98 Wednesday night. Good ol prius tires. Lol
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 10-17-2015, 08:16 PM   #255
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
98mph is pretty good! That's low 14's and possibly hitting 13.99999.
hmong337 is offline   Reply With Quote
Old 10-17-2015, 08:54 PM   #256
itsjustdavep
That's what I keep hearing
Old 10-17-2015, 10:16 PM   #257
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by Rockz222 View Post
https://drive.google.com/file/d/0B2I...p=docslist_api
Finally got a run in.
Mods: Perrin crank pulley, OFT Stage 2 OFS EL tune, HKS EL header, Tomei overpipe, Tsudo full 2.5" exhaust.
Tires: 245/35/18 Bridgestone Pole position S-04.
Full interior, with tools and babyseat in car. No change to tire pressure. I think my car is slow.
14.659@93.75
I managed a 14.6 1/4 mile bone stock including Primacy's. My best run but I still lost to an all engine Civic SIR lol.
That said, I'm only 50ft above sea level, was playing with tire pressures and took all weight I could easily remove out of the car all of which will account for a lot. I'd love to get some better rubber, an exhaust and a tune, feel like I could break into the 13s.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Mike Brz (11-25-2015)
Old 10-18-2015, 01:08 AM   #258
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
15.88. I suck.
Packofcrows is offline   Reply With Quote
The Following User Says Thank You to Packofcrows For This Useful Post:
funwheeldrive (05-07-2016)
Old 10-19-2015, 01:16 AM   #259
itsjustdavep
ran again today, 14.4 @ 98.1.
i hate my shtty tires. literally cant get out of its own way off the line
Old 10-20-2015, 10:37 PM   #260
jort88
jort88's Avatar
LOL I was trapping the same speed/tires. I ran full pressure though, should of let some air out.
Old 10-20-2015, 10:39 PM   #261
itsjustdavep
Doesn't do much. The tires won't flatten they concave.
And I actually realized these may be WORSE than the prius tires.
Firestone Firehawks. Kill me
Old 11-25-2015, 08:32 PM   #262
Mike Brz
Hey guys. I run a 13.75 second 1/4 mile with a 60ft of 2.0xx and a trap speed in 3rd gear at 99mph at the moment.
Thinking of switching out the 26&1/2 tall slicks for a set of 24&1/2 tall drag radials
Mike Brz is offline   Reply With Quote
Old 11-25-2015, 08:35 PM   #263
Mike Brz
Originally Posted by FRS Justin View Post
13.47 run bad video but still a video
1.79 60ft
13.47 qtr
101.40 mph
Thats really good. What tires do u run in the rear? And what size tires?
Old 12-10-2015, 02:20 AM   #264
FT86RGV
Really need help on improving my times guys. I'm on the right side in pic below.
Mods are sprintex 210 intercooled, 69 mm pulley, flex fuel (79% ethanol).
Tires are 265/35/18 Michelin pss on the rear on stock suspension. 30psi tire pressure and just did quick burnout to clean them up. temp was in 70s and dropped throughout the night. Low humidity.
For the life of me I can't get a good launch. launching at 3k rpm or higher results in wheel spin through 1st and 2nd with a lot of rough tire hop in some instances. anything around 2.4k-2.7k results in car bogging down and taking off like a snail (what happened in pass below). I tried rolling off the clutch slowly but the ecutek launch control automatically disengages and lets the rpms climb and still results in wheel spin. I also had one almost good run where just chirped tires on launch and hooked resulting in a 2.0xx 60' but then the tires lit up at the top of 1st and into 2nd resulting in a 13.5xx time @ ~106.
Any ideas are more then welcome. I would love to touch the 12s.
FT86RGV is offline   Reply With Quote
Old 12-10-2015, 11:34 AM   #265
Lynxis
Lynxis's Avatar
Sounds like your tune may be getting in the way and making launching more difficult. I've heard other people complain that launch control is actually not as fast as launching yourself so I'd see if you can disable it. Besides that, you might do better with partial throttle to get your rear tires to hook up quickly then give it the beans.
Also, shifting technique plays a big part too. Gently push the shifter towards the next gear (not hard enough that it goes to neutral) then kick the clutch to get the shifter to move to the next gear. This is a very quick shifting technique. You can also try powershifting which is the same technique except that you keep your right foot flat on the gas while you shift. Note it is extremely hard on your car and you might break something but it's the fastest way to shift.
Finally, better tires are a good idea. I know PSS has good lateral grip but no idea about traction. They're a fairly hard compound so I doubt it's great. Something like RE71r will probably hook up better but I honestly know next to nothing about drag tires.
Old 12-13-2015, 04:48 PM   #266
FRS Justin
Drives: 2013 Asphalt FRS
Don't use launch control feather the gas, then quickly and controlled let the clutch out roughly 1 to 1.5 seconds to full release. When clutch is going out gas should be going down.. Rpms for you I would guess between 3000 and 4k would be a good range to feather at. Drop tires down to 15 to 20 psi and drive thru the water onto dry pavement burn them until they smoke let off brake during burn out half throttle burn out until it hooks then stage. The perfect launch you will be scrubbing the tires thru first gear if they do spin it shouldn't more than 5 ft
Like this
[ame="https://www.youtube.com/watch?v=CCFOM4fuWSM"]13.58 sec. Delicious Tuning and PPE Header N/A FRS Breaks 100mph in the 1/4 mi - YouTube[/ame]
I can launch at 7800 rpm on drag radials and pull a 1.8 60ft time doing this method just takes practice.
[ame="https://www.youtube.com/watch?v=WzLqo6-VYR8"]13 47 frs - YouTube[/ame]
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
NyC Zn6 (12-21-2015)
Scion's free 2 year/25K mile maintenance plan? whtchocla7e Scion FR-S / Toyota 86 GT86 General Forum 25 06-06-2012 04:26 PM
La Times reviews BRZ Sport-Tech BRZ First-Gen (2012+) — General Topics 7 05-18-2012 12:11 PM
He lives his life 1 quarter mile at a time ucla bruin Other Vehicles & General Automotive Discussions 8 12-21-2011 08:04 PM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Louie Southern California 1 10-11-2011 01:31 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Louie Southern California 2 03-20-2011 06:17 AM
