Old 02-20-2012, 05:04 PM   #197
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Smile
Originally Posted by jayrod1980 View Post
I see over and over complaints regarding the power from a turbo and high compression. I'm not going to comment on disrupting the balance of the car as I'm a total noob when it comes to handling but direct injection turbos cars make great power with very little lag on high compression. My eco boost flex has over 12 compression ratio and just returned makes at least 420 crank HP... probably closer to 450. The car has no discernible lag that I can tell... stock it hits full torque from 1800rpm to something like 5600rpm and my retune mostly just raises peak boost... all on 93octane. The new Toyota/Subaru has direct injection as well. I know a twin turbo ford v6 isn't the same as a 2 liter boxer 4 but I believe VW gti's are pretty lag free with a decently flat torque curve. This tech would probably be more costly than a supercharger but if you are talking fi then its still something to consider.
Edit: A 2.0 inline 4 isn't a boxer 4 either but it is a least a small, four cylinder engine with a single turbo set up.
Excellent post in my view
Subaru Engineers already have stated the engine has sufficient strength to be tolerant of moderate boost - say up to 10psi
Tradewind is offline   Reply With Quote
Old 02-22-2012, 05:24 PM   #198
Dimman
Kuruma Otaku
Dimman's Avatar
A few questions about roots/twin screw SCs. Do they have compressor maps akin to those on centri/turbos? Pressure ratio on y, airflow on x, and efficiency islands but just different shapes? And do they have a calculation for drag on the crank power when running?
Edit:
Google, Dim, google...
Now need to convert m^3/hour into something familiar...
Because titanium.
Old 02-22-2012, 05:40 PM   #199
serialk11r
Drives: '06 AM V8V Coupe
m^3/hour divided by 60 is good for calculating the power requirement though
But the true power requirement would be after you subtract the work done on the piston by the compressed air during intake stroke, and that gets a bit annoying since the pumping loss is hard to find.
Old 02-22-2012, 06:08 PM   #200
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
16.67l/min X inlet flow?
1m3 = 1000L for reference...
Exage is offline   Reply With Quote
Old 03-03-2012, 01:54 PM   #201
SkullWorks
Drives: SSM LT MT BRZ
That was a long read,
I hope that in coming months more members of this board will come to realize what DI is all about, that 12.5:1 and a turbo get along great, that S/C's are heat pumps and not suitable for cars with a wide RPM range.
The fellow up top (this page) talking to DW injectors please PM me so I can personally tell you why to stop trying development with them, I have pictures that will make you cry
I Pre-Ordered a BRZ because I'm already making DI pumps and Working on Upgrade injectors for several other models, this will be my new pet...
Looking forward to see where we can take this car without sacrificing the DD aspect...I ruined too many S13's with too much power...so I'm gonna try balancing this one...for a while
SkullWorks is offline   Reply With Quote
Old 03-03-2012, 02:49 PM   #202
madfast
Drives: 2010 Evo X MR-T
care to explain this statement? have you kept abreast of the latest supercharger tech? and is a turbo supposed to be "suitable for cars with a wide RPM range"?
madfast is offline   Reply With Quote
Old 03-03-2012, 03:14 PM   #203
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Good to hear -- tell us more. Get this thing to a reliable DD with 250+ whp and people will be lining up for your kit.
Jordo! is offline   Reply With Quote
Old 03-04-2012, 02:56 PM   #204
SkullWorks
for example using the TVS 1320 (since it is the smallest available currently)
If you are shooting for 6 psi (~.4bar or 1.4 pressure ratio)
(1m^3 = 1000L, volume is per hour)
2L X 7400rpm X 60 (minutes in hour) X 1.4 = 1,243,200 or 1,243.2M^/hr
If you look at what that gets us, it gets us running on the lower side of good efficiency and still spinning those poor bearings into the high side of their range, (diagonal lines are Rotor RPM) and this Super charger is still too big for this application really, and it's 15" long and needs to be intercooled some how.
This is, to the best of my knowledge, the best super charger line up on the market currently. I don't want to talk about the vortec style or procharger what ever you want to call the half-turbo-parasitic-loss-lumps, those were designed because they are easier to install than turbos (for driveway tuning) and didn't have the same limitations for effective power band,
Turbo's overcome their RPM limitations by having Wastegates to alleviate extra exhaust flow that would exceed the turbo's safe RPM limits. they also allow tuning of the manifold pressure based on loud pedal position relative to the floor.
TURBO LAG...anyone who complains of turbo lag needs to go drive something with a new, properly sized, turbo. and the High compression and DI are only going to make the turbo spool faster. My track car (hpde time attack) is an S13 with a 9.0:1 SR20det and a Forced Performance gt2868 (billet 68mm wheel on a garrett GT28 Hotside/CHRA) it made 230 lb ft at 2700 RPM, and before i got the TiAl Vband housing and external wastegate it would hit boost cut at 6000 (well shy of redline) putting 341hp down on 19psi (boost cut value)
That is my idea of a perfectly drivable, MONSTER. I envision using the same turbo on this motor in this calendar year....shhh it's a secret...
Old 03-04-2012, 03:08 PM   #205
Dimman
Kuruma Otaku
Dimman's Avatar
^ Twin screws (Lysholm) still have better efficiency than the TVS Eatons, and approach the 'half-turbo' centris.
Plus is the R900 no longer available or not available yet or just temporarily out of stock? It would be a better example, given the sizing, rather than using an over-sized one.
That's kind of like saying turbos suck, if only the GT45's were available to turbo old Civics....
Because titanium.
Old 03-04-2012, 03:42 PM   #206
SkullWorks
I looked at the graph for that S/C aswell it is closer to a good fit but you are turning it pretty hard and still well below the peak efficiency of the unit, it is listed on their site as not yet available.
scion fr-s supercharger, subaru brz supercharger, super brz supercharged, supercharged scion fr-s, supercharged subaru brz, supercharged toyota 86, toyota 86 supercharged, toyota 86 supercharger
Toyota FT-86 @ VLN : report / pictures Michel Scion FR-S / Toyota 86 GT86 General Forum 312 10-31-2011 01:31 PM
Report: Toyota FT-86 Sedan Version Coming Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 09-24-2010 09:45 PM
Report: Toyota FT-86 will move up in price and age demographic ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 201 06-02-2010 03:36 AM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 07:41 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
