Old 02-18-2019, 06:11 PM   #57
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by ermax View Post
The spring I am referring to is also in the Lexus unit. It looks identical actually.
Oh, there you go! That spring sets the preload for the contact between the gears. I missed that. The rubber ring must just function as a damper for that mode.
darksnyder (02-21-2019), ermax (02-18-2019)
Old 02-18-2019, 06:52 PM   #58
ermax
ermax's Avatar
That was my interpretation but I’m afraid the plastic gear is worn to the point the spring is pushing the worm to the limits of the casing. I’m still going to give it a shot because as I said I’ve actually made it worse now.
The Following 2 Users Say Thank You to ermax For This Useful Post:
darksnyder (02-21-2019), Ultramaroon (02-18-2019)
Old 02-21-2019, 08:24 AM   #59
darksnyder
Drives: 2013 Toyota 86 (Hot Lave)
*Finger crossed* Nice work though, I hope you find a solution for all us. Your name will go down in history! Keep a camera handy if you resolve it.
darksnyder is offline   Reply With Quote
Old 03-01-2019, 11:05 PM   #60
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I have the same steering rattle/clunk on uneven roads and I know of several other 86/BRZ owners here in the Philippines who have the same problem. Others were lucky enough to have the dealer replace the EPS assembly under warranty. Mine is a 2013 and way out of warranty so I just bought a used EPS, spent yesterday afternoon installing it and now the rattle is gone. I still want to fix my original EPS unit since my car only has 19,000km so I went ahead and inspected it.
The rubber ring under the round pop cap @ermax replaced was still intact on my unit. What I found was that the green rubber piece inside the plastic piece that looks like a ship's steering wheel was completely disintegrated. This piece is in between the motor assembly and the worm assembly. This is the same thing that is causing problems on the Hyundai EPS units and is available separately although they use a pure rubber piece instead of a plastic/rubber combo like in the JTEKT unit. I think this may be the source of my EPS clunk, as I couldn't hear or feel any rattle or play when wiggling the worm like in the Russian video.
HRTROB is offline   Reply With Quote
The Following 3 Users Say Thank You to HRTROB For This Useful Post:
ermax (03-02-2019), Outlander (06-28-2020), Ultramaroon (03-03-2019)
Old 03-02-2019, 05:24 AM   #61
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, have anyone from you instead of fixing tried retrofitting newer EPS? IIRC for MY2015 or MY2017 it was fixed, as in even with heavy use on track on slicks didn't overheat and shut off.
Old 03-02-2019, 12:48 PM   #62
ermax
ermax's Avatar
Neither could I. I’m tempted to pick up a used on and overhaul the old one as you are. I can’t see a use one lasting long before it’s doing the same thing. If I get a used one I will open it up before hand to get a look at that rubber part to so what it looks like before it is destroyed. Maybe something similar could be sourced to replace it.
On thing I don’t look forward to is pulling the unit out of the car. Looks like a pain in the ass.
Old 03-03-2019, 05:34 AM   #63
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The rubber part looks similar to the Hyundai rubber bushing. I went ahead and ordered one since it looks similar, hoping it might fit, or be trimmed to fit. Taking the EPS unit out of the car wasn’t as bad as I thought it would be. You pop off the radio dash piece, then the bezel around the cluster. Remove the steering column cover, unplug all the connectors. Remove the lower dash panels including the knee airbag. Look for a philips screw holding a thin cable that tethers the steering wheel side of the column to the motor side assembly. Once you remove that, there’s only two nuts holding the steering wheel side of the column to the car. Remove those then you can pull the whole steering assembly out. All that’s left is a single bolt that holds the motor side of the assembly to the car (you unscrew this bolt from the left side, right beside the brake light switch), and the bolt that mounts the steering shaft to the EPS unit.
bcj (03-03-2019), sato (03-10-2019), Ultramaroon (03-03-2019)
Old 03-14-2019, 05:21 PM   #64
Rhyuk
Drives: 2013 FRS
I'm having the same issue. I've changed struts/endlinks nothing ;( Any updates?
Rhyuk is offline   Reply With Quote
Old 03-14-2019, 05:43 PM   #65
ermax
ermax's Avatar
I haven't had a time to work on this. Maybe this weekend. Maybe @HRTROB has made progress on his.
Old 03-16-2019, 02:52 AM   #66
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I just got the Hyundai bushing today. It’s a perfect fit on the joints but there is some trimming that still needs to be done. The worm side of the joint has a protruding area in the center and that’s why the original bushing has a bigger hole in the middle with a second rubber bushing (the piece that is shaped like a gear) that slides over. I’ll try trimming the little round nubs on each spoke of the Hyundai bushing. I don’t want to enlarge the center hole because it might compromise the strength.
The Following 4 Users Say Thank You to HRTROB For This Useful Post:
bcj (03-16-2019), ermax (03-16-2019), T0rt0r0 (03-16-2019), Ultramaroon (03-18-2019)
Old 03-16-2019, 01:23 PM   #67
ermax
ermax's Avatar
Man great update. Can’t wait to see if it fixed the rattle.
Old 03-17-2019, 12:28 PM   #68
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I sure hope it does! Although It’ll be a couple more weeks before I can test it out. Currently renovating and moving in to a new house and that is taking up a lot of my free time. You can try it if you have the chance. It’s only $8 for two bushings shipped from Amazon
Old 03-17-2019, 12:49 PM   #69
ermax
ermax's Avatar
Yeah I figured you wouldn’t be in a rush to put your original EPS back in the car seeing how your used replacement fixed your noise. I just placed an order for this rubber part. It should be here Monday. Maybe I will have some time to work on it next weekend. If only it was easier to access the EPS. I will be sure to get lots of pictures as I work on it.
The Following User Says Thank You to ermax For This Useful Post:
T0rt0r0 (03-17-2019)
Old 03-18-2019, 11:06 PM   #70
QuickieSilver143
Is this a part that we could possibly print with a 3D printer?
QuickieSilver143 is offline   Reply With Quote
FS: OEM Electric Power Steering Column, with Motor and Module MicheleAbbate Interior Parts (Incl. Lighting) 12 12-31-2018 04:47 PM
Recall for Electric power steering (EPS) tm86 AFRICA 36 05-16-2017 08:04 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 09:19 AM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 09:38 PM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 11:11 AM
