Old 11-11-2015, 05:59 PM   #3655
mscamp02
Drives: 2013 FRS
So got it running and driving but I have an issue and not sure where to start.
It run great up till about 4psi or 5k ish rpm then it cuts out. Doesn't stall or or did just cuts off abruptly. Tune issue or is there a hose or something loose somewhere?
Sent from my VS985 4G using Tapatalk
mscamp02 is offline   Reply With Quote
Old 11-11-2015, 06:00 PM   #3656
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Could be the bypass valve or tune related. I'd check the lines going to the bypass valve and make sure those are clamped.
Freeman is offline   Reply With Quote
Old 11-11-2015, 06:01 PM   #3657
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Have you tried switching to map 2? Possibly the valet mode on map 1?
Sent from my Nexus 6 using Tapatalk
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 11-11-2015, 06:01 PM   #3658
Freeman
Freeman's Avatar
Also check the Evap solenoid under the intake.
Old 11-11-2015, 06:15 PM   #3659
mscamp02
Drives: 2013 FRS
Nothing on the maps. What am I looking for on the evap solenoid
Old 11-11-2015, 06:17 PM   #3660
Freeman
Freeman's Avatar
Make sure the lines are still attached. The motor isn't designed for boost so those lines pop off sometimes. I had to clamp mine on. I believe there's a thread on the forums about it. Something like "check this before going FI."
Old 11-11-2015, 06:42 PM   #3661
mscamp02
Drives: 2013 FRS
edit:
I popped the evap hose by barely pulling on it so I'm assuming it was already 99% off or just stuck on something else. Can't get it back on yet due to engine being to hot but thanks for all the quick feedback Freeman.
Old 11-11-2015, 08:10 PM   #3662
mscamp02
Drives: 2013 FRS
So I got that reconnect but now im sure I just popped it off by mistake because I have the exact same issue. Runs fine up to 4 psi/ 5k ish rpm then has a hard cut off. I've been running over all of my lines and cant find anything. I may try hooking my air compressor and push 10psi of air through the hose connecting to the intact to see if I hear any leakage.
Also did a check to see if I missed anything and on my work bench I did have 2 parts from the kit not installed. Not sure how I missed it I went back through the entire install manual and didnt see anything at all listed. Also not sure where they would go(pic below).
[IMG][/IMG]
Another thing I just want to check myself on is when the instruction said take off all of the intake and associated hosing/tubing I took off everything including the tubing running to the firewall by the battery where the rotrex oil canister is located. Does this sound right
And one final though is that maybe my fuel is not keeping up but it should have been fine. I'm on 93 octane on stock injectors/fuel pump with the c38.
As you can tell I'm new to FI but I can't see how things can run so smooth and well up to the exact same cut off of 4psi and 5k rpm.
Old 11-11-2015, 08:23 PM   #3663
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Glad we checked this, just sent the revised tune without the valet mode
But definitely secure the line under the plenum for the evap solenoid. We've been pulling the solenoid off to make this easy with the kraftwerks kit since the blower doesn't allow our long reach pliers to get in there. Or you can pull the AC compressor out of the way, that's pretty easy as well. Either way no need to pull the intake plenum off.
Xero-Limit is offline   Reply With Quote
Old 11-11-2015, 08:30 PM   #3664
mscamp02
Drives: 2013 FRS
Mike, I just got your email too. I was going to try a bunch of little things to make sure I was good on my end before harassing you about the tune. And after seeing how easy it was for me to pop off the one hose I'm going to get some clamps and secure them in the coming days. Just glad to know it was something simple
Old 11-11-2015, 09:04 PM   #3665
mscamp02
Drives: 2013 FRS
Enirely new car, it's absolutely amazing with the added power! And for everyone who says this is how it should have come from the factory is crazy, that would be way to much for the everyday driver or random kid. Thanks mike for the kit and all the support !
Old 11-11-2015, 09:36 PM   #3666
Freeman
Freeman's Avatar
Glad it got sorted out! Enjoy the boost!
Old 11-18-2015, 04:08 PM   #3667
D-VO
Drives: Whiteout FR-S, Evo 8 RS
What are you guys doing to keep the IAT temps and engine bay temperatures down?
D-VO is offline   Reply With Quote
Old 12-02-2015, 06:00 PM   #3668
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
Hello everyone! I got my kraftwerks c38 installed and is 100% complete. Running 409whp on a mustang dyno E85. Haven't been on the forums in months but if anyone is Interested in knowing my build my name on YouTube is AZBRZ520
AZbrz89 is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
