Old 12-07-2013, 08:23 AM   #85
Burrcold
Drives: Subaru BRZ Limited
Originally Posted by etherealfall View Post
`1
Cool, thanks.
Old 12-07-2013, 11:27 AM   #86
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Getting the flasher mod disconnected/reconnected is deceptively challenging...my right hand received 3 bloody scrapes before I finally succeeded
Old 12-24-2013, 07:59 PM   #87
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Thanks for the write up. That flasher relay was the worst part, but not impossible. I also had a bunch of connectors tied to it from my previous foray when installing the LED side mirror turn signals. I found it easier to deal with if you remove the two bolts attached to the plate that covers the "neck" of the steering column.
The Following User Says Thank You to chanomatik For This Useful Post:
RallySport Direct (12-26-2013)
Old 12-25-2013, 09:16 AM   #88
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Thanks for the detailed write-up, looks like Santa left me a set last night. Mine have an SAE and DOT cert on the housing so I assume these would be plug n play?
Still want to get the Prova D steering wheel once the dust settles from Christmas!
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 2 Users Say Thank You to Deep Six For This Useful Post:
chanomatik (12-26-2013), RallySport Direct (12-26-2013)
Old 12-25-2013, 12:44 PM   #89
Deep Six
Deep Six's Avatar
Install was just a 15 minute job and they work perfect out of the box. The flasher relay comes out very easy if you insert a straight blade screwdriver into the slot above while sliding the unit towards the seat.
[SIGPIC][/SIGPIC]
chanomatik (12-25-2013), RallySport Direct (12-26-2013)
Old 01-05-2014, 09:16 PM   #90
jsc1234
i have a USDM tail light and my car is in asia but my toms dont light up right?
jsc1234 is offline   Reply With Quote
Old 01-07-2014, 10:47 AM   #91
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
What is happening exactly? Do they light up incorrectly or not at all? If the car is the JDM model and you are using the USDM specific tail lights you will want to re-pin the connectors so everything lights up correctly.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 02-02-2014, 02:11 PM   #92
rgt
Drives:
Question - i have searched multiple threads and can't seem to find the answer - but when the LED bulbs eventually go out inside the tail light housing how do you replace them?
rgt is offline   Reply With Quote
Old 02-02-2014, 05:10 PM   #93
jlugo711
Drives: 2014 GT86
Was wondering the same thing but wasn't sure where to ask!
jlugo711 is offline   Reply With Quote
Old 02-02-2014, 06:22 PM   #94
Burrcold
I'll admit that I have had the same concern.
Old 02-02-2014, 06:44 PM   #95
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Same thing you do with the stock tails (if you're not under warranty)
It's not an LED bulb, just LEDs.
You would have to replace the whole thing.
The Following User Says Thank You to Andrew025 For This Useful Post:
chanomatik (02-03-2014)
Old 02-03-2014, 11:50 AM   #96
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Pretty much. If they go out in a few years outside of warranty, it's up to you to determine if they're worth purchasing again or not. I see it all the time with the Audi headlight LEDs. I wonder what they do when they go out? I would NOT want to purchase a new Audi headlight. However, these tails for around $450 wouldn't be the worst repurchase if I rocked them for several years with no issue except for dead LEDs.
That's probably just me, though. I expect electrical things to be replaced frequently, OEM or not. Mechanical things, less so.
Old 03-12-2014, 11:36 PM   #97
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
Installed mine in my brand new BRZ when it was les than a day old. Not too challenging, but I do have some cuts.
What I'm concerned about is the gaskets. I don't have a torque wrench but tightened the studs up as tight as I felt comfortable without risking cracking the plastic. There seems to still be a little slack in the gaskets though and I'm nervous about water making it through.
Have we come across any issues thus far?
The Sentinel is offline   Reply With Quote
Old 03-13-2014, 11:40 AM   #98
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
@Beyer Subaru and I discussed it in his build thread, I believe. The best thing to do is to order the 2014 BRZ gaskets because they're revised and thicker. I plan on doing it soon. This came up because we both have experienced condensation, although nowhere near as badly as the stock tails. When removing my stock tails there was TONS of gunk and water buildup in the gaskets. I did get a quote from Toyota for the 2014 FR-S gaskets, assuming they were revised also. I was quoted $22 each side.
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 02:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 06:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 06:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
