Old 07-10-2013, 01:01 AM   #43
ap1mikeo
Drives: whiteout
installed today! look amazing. I'm a little concerned about the tq spec. The tom's instructions dictate 20kgf cm which is 1.44 ft lb for the nuts. I followed their instructions and used the tq sequence dictated by the TSB for our car. Has anyone else taken care of this, or compared the gasket design to OEM? I hope TOM's hasn't overlooked any leak issues.
ap1mikeo is offline   Reply With Quote
Old 07-12-2013, 08:51 PM   #44
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Nice glad you like them!! And we also used the TSB for the torque and have not had any issues at all, nor did I notice any distortion in the metal so I think I did it right
Thanks again,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-13-2013, 02:00 PM   #45
schtebie
Drives: CBS BRZ Limited
Finally got around to installing mine this morning.
Just a tip: when re-pinning the harness, a sewing needle with a sharp point works REALLY well.
schtebie is offline   Reply With Quote
Old 07-18-2013, 08:03 PM   #46
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
installed mine. long story short I couldnt re-pin it so I just rewired the tails my own way. probably going to catch a lot of hate for this one but it works.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 07-19-2013, 10:04 AM   #47
RallySport Direct
Thanks this is good advise!
No problem there, if it works, it works!
Thanks,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
draggin_az (07-20-2013)
Old 07-23-2013, 10:33 PM   #48
sieeegel
Drives: rsx was stolen :(
Are you now selling USDM spec wiring so we dont have to repin? I am confused now.
sieeegel is offline   Reply With Quote
Old 07-24-2013, 05:38 PM   #49
RallySport Direct
The new tails we are bringing in will have the USDM wiring, so if you were to place the order now, you would not have to re-pin. Hope this helps
Thanks,
Rick
Old 07-28-2013, 11:06 AM   #50
Skurj
Drives: SOLD...
Got them installed today. Changing the pins was easy for 3 of the wires... the last left a little damage to the plug, so I will have to just keep an eye to ensure the pin doesn't creep out.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
The Following User Says Thank You to Skurj For This Useful Post:
chanomatik (07-28-2013)
Old 07-28-2013, 01:13 PM   #51
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
These tails look the best on WRB and SWP.
Old 07-28-2013, 03:07 PM   #52
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I found the pinning process pretty straight forward as I also had to do this on my previous Colin's. Only downside here is the OEM harness had to be re-pinned verses the actual tail light plug. Which DEPO in all their wisdom siliconed the wires into place for moisture protection I guess
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 07-28-2013, 07:32 PM   #53
FT86Dubai
FT86Dubai's Avatar
Drives: 2013 Toyota 86
Arent these lights plug and play?
2013 Toyota 86 (Sold it and regretting)
FT86Dubai is offline   Reply With Quote
Old 07-28-2013, 08:13 PM   #54
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
The new USDM ones they have coming in are completely plug & play. The previous models were JDM and required 2 wires on each tail to be switched. Not a big deal, it took like 5 minutes per tail, but your good to go on all the USDM ones
2URGSE
The Following User Says Thank You to JPxM0Dz For This Useful Post:
FT86Dubai (07-29-2013)
Old 07-29-2013, 11:40 AM   #55
RallySport Direct
Welp.. that settles it. I know my next mod for my WRB Simply stunning.
Thanks,
Rick
draggin_az (08-11-2013)
Old 08-30-2013, 09:23 PM   #56
tranat
tranat's Avatar
Drives: Subaru BRZ SWP Limited
Did anyone have a problem with the turn signals flashinh the first longer than the rest, like 0.5 seconds, everything after that works fine.
Will buying the Tapturn Flasher Relay resolve this problem? Also will the tapturn replace the LED Flasher Relay Module TOMS Provided?
tranat is offline   Reply With Quote
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 02:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 06:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 06:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
