Old 07-03-2013, 06:46 PM   #29
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Yeah, understandable about the inspections, always best to double check and play it safe And I agree that these are the BEST looking lights on the market by far!
Thanks guys,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-04-2013, 01:20 AM   #30
Panman
Panman's Avatar
Drives: 86 GTS
I have them, and agree they are the best looking lights out there (no buyers remorse here!)
Fortunately in Australia the wiring is "correct"
Panman is offline   Reply With Quote
Old 07-04-2013, 01:28 AM   #31
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by loogs View Post
yeah ill probably pass on the Toms and get some other brand. too many issues
Any lights you buy that are set up for JDM, EUDM, AUDM are pretty much bound to have the same problem. What would be clever would be someone coming up with a harness converter that plugged between the USDM harness and JDM lights, and put a reflector sticker in the box and charged say $10.
No re-pinning, convert back to stock any time you like. Maybe an idea out there for someone?
Wouldn't you buy that?
Maybe the importer just packs them with every set of lights.
The Following User Says Thank You to Panman For This Useful Post:
loogs (07-04-2013)
Old 07-05-2013, 07:51 AM   #32
Pretender
Drives: Toyota GT-86
What happens if you don t use the led flasher relay that comes with the tail lights?
Sent from my GT-I9300 using Tapatalk 2
Pretender is offline   Reply With Quote
Old 07-05-2013, 08:12 AM   #33
Burrcold
Drives: Subaru BRZ Limited
Your turn signals will blink really fast.
Old 07-08-2013, 07:56 PM   #34
makalaka
makalaka's Avatar
Drives: 2013 Sonic, 2013 BRZ ltd
I installed mine today and I lurve them!
I couldn't get the relay off so I just plugged the new one into the wire and left it hanging.
makalaka is offline   Reply With Quote
Old 07-08-2013, 09:45 PM   #35
RallySport Direct
Nice, glad you like them! And I thought about doing the same with the relay, but eventually I was able to get it off with a bit of gentle persuasion lol
Thanks,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
chanomatik (12-24-2013)
Old 07-08-2013, 11:38 PM   #36
vinh
Drives: a car
i am having some trouble re-pinning. do you put the pick on the side with a gap and then push the pick up ?
vinh is offline   Reply With Quote
Old 07-09-2013, 01:37 AM   #37
ap1mikeo
Drives: whiteout
IIRC some condensating cars came w/ the tails overtorqued? were those the housing bolts or others?
can anyone confirm a tq spec for these?
ap1mikeo is offline   Reply With Quote
Old 07-09-2013, 12:54 PM   #38
RallySport Direct
I am still waiting on a better picture/diagram on how to re-pin the harness, but I was able to whip this up really quick.
And yes, you will insert your pick/tool in the opening and down in the plug and just above the pin there will be a small plastic tab that you lift up as you are pulling the wire out from the back at the same time.
Hope this helps
The issues seem to be from the gasket and over torquing of the mounting bolts. There is a TSB listed specific for this where Subaru provides new nuts and a new gasket for the stock tails.
The torque spec for the mounting nuts is 4.5 Nm or 39 inch-pounds (3.25 ft/lbs).
Thanks,
Rick
JPxM0Dz (07-24-2013)
Old 07-09-2013, 01:07 PM   #39
swift996
swift996's Avatar
Can't you just lay on your back and get to the flasher relay? I remember doing it when I installed LED turn signals (although I removed them), I'm guessing it's the same relay?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-09-2013, 05:45 PM   #40
makalaka
makalaka's Avatar
I can get to it. Just cant get it off.
Old 07-09-2013, 05:49 PM   #41
RallySport Direct
I had to carefully take a very small flathead screwdriver and insert it between the plastic tab and the relay to free the relay from the plastic tab. I was not able to capture a good picture of that process unfortunately, but it came off with a bit of patience.
Hope this helps.
Thanks,
Rick
Old 07-09-2013, 11:06 PM   #42
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
you pull down on it and slide out. Was not hard really, just took a little thinking. Lay on your back, look under the wheel. Pull towards you on the relay, then push towards the front of the car. If that does not work, just yank on it. the plastic clip will unseat it self from the hole before you break the clip itself. Then you can transfer the clips and be good to go.
SOCAL INSTALL AND SELL-- HID KITS--LED LIGHTS--REVERSE LIGHT--PAINT TAILLIGHTS!! F-T Exterior Parts - Lighting 202 03-21-2016 02:02 PM
FS: FRS/BRZ Red OEM taillights 86design Exterior Parts (Aero, Lighting, Etc.) 4 06-26-2013 06:34 PM
New taillights youngy AUSTRALIA 7 04-14-2013 06:16 AM
Taillights idea adprokid Cosmetic Modification (Interior/Exterior/Lighting) 25 09-16-2012 12:40 AM
