#1289 | |
Your writing style shows incompetence. I’m not even sure what you post is trying to accomplish. Have you even read this thread at all? You do know that Toyota does not own dealers right? You do know what actually causes the failures right? It isn’t the valve springs that’s for sure. If someone wants a legitimate class action it will be related to the insufficient oil supply to the #2/3 rod journals. Those bearing failures are related to a design flaw rather than shity labor by privately owned dealers. |
#1290 | |
Considering it’s #4 every time my bet is they are using too much packing and blocking the main that feeds #4. That is the most venerable place for overuse of packing. Actually I take that back. This location is between the block halves which they wouldn't touch if doing a new short block. |
#1291 |
Drives: 13' Lightning Red Brz
I do have the invoice in my car, I'll take a picture later tonight and provide that information. But after the new short block, I definitely still have a louder than usual knock and also when driving I have a loud ticking noise I want to say on the passenger side. Tough to hear with the exhaust but when listening closely enough it's there and loud enough to worry.
#1292 | |
Drives: 2013 frs
Again, the fact that Toyota and Subaru don't own dealerships does not mean they cannot be found liable for problems that occur at the dealership level or from work stemming from the dealership. I believe it all depends on the details. For example, if Toyota accidentally gave wrong instructions, omitted instructions, failed to warn technicians about an issue, improperly trained technicians, or knowingly hid certain details about an issue from dealers and their technicians they could be found at fault (if proven) or jointly at fault (along with the dealer). Just because the dealerships do not belong to them does not give them an iron wall defense or resolve them of every and all responsibilities from issues which arise at the dealer level. Didn't Toyota change their instructions early on in the wake of the J02 recall after a few FR-S' started blowing? (or was it before?, can someone confirm?) I think most of us understand that the replacement of the valve spring itself is not the root cause, however, I think what we are seeing is that the work that is performed during this recall is increasing the likelihood that the actual problem reveals itself. The fact remains that whatever the real problem is, the valve spring recall has allowed the problem to surface exponentially and is, in some way, directly or indirectly, contributing to the blown engines and I would argue most likely the fires as well. |
#1293 | |
The cause of the failures is well documented and not a mystery. It is directly related to improper clean up and/or installation of the sealant. This is why the FA20 engines are having issues whereas the other Subaru engines involved are not since they use a different procedure to change the springs. The failures have nothing at all to do with the changed springs but the method in which the engine was accessed to get to them. Yes, Toyota did change the instructions after the first few failures but all they did was include a warning to the techs to ensure that they cleaned up all the loose sealant. The issues did not reduce after that since techs that leave a mess still do so even when warned not to. Trying to blame Toyota directly is grasping at straws.
#1294 | |
#1295 |
Drives: 2019 Mazda Miata RF
#1296 | |
If people are going to rely on the internet documentation of this situation then it has to be considered for both the supporting and the non-supporting points. Misrepresenting the issue will not help with any claims. There is a pile of info we don't know. Right off the bat we don't even have a basic grasp of how many failures there were where the dealers didn't step up and fix the issue they caused. Many of the people that reported the failure and said the dealer were looking at it never came back and said if they ended up having it covered.
#1297 |
#1298 | |
Hell, we never even found out the cause of the reported one. There is a such thing as coincidence and jumping to the conclusion that fire is directly related to the recall could be a total red herring.
#1299 | ||
Drives: 2013 frs
There have been more than one documented on NHTSA I would also like to point out that Subaru's have been affected as well. You can check out the same NHTSA site under Subaru BRZ and find a handful of blown BRZ engines post recall as well. Also, if you do a quick google search you can find a BRZ's with the same issue as FR-S' post recall. SO, there may be more to it than failure to follow instructions, an added warning, or shitty labor. Like ermax stated, it could also be in conjunction with a design flaw, or a design oversight. Maybe the oil channels are smaller than previous designs or smaller than what should be the tolerated specification for this particular engine set up/design which in turn causes high oil pressure when blocked by certain sized particulates wheres if the oil channels were larger the same sized particulates would freely flow to the filter screen? You are basically stating and in agreement with what I stated earlier. We know the J02 recall and changing the springs is not the root cause, however whatever is being done during the recall is contributing to the problem we now see. I wouldn't go as far as to state that we know 100% without a doubt the entire mechanism and root cause of the problem, but we have enough evidence to make a few guesses and understand an overview of what is going on. |
#1300 | |
There were at least 30 know spun bearings on the 2013s well before the recall ever happened. These were on brand new unopened engines. I preached then that it was due to blocked oil passages right from the factory but nobody wanted to believe it. Now THAT would be an opportunity for a class action.
#1301 |
Well that was a fun read!
There is nothing in either statement that shows the recall work was the cause. It is just assumptions. What both do have in common was that they had been driven hard for a prolonged period at the time the engine went and caused a fire. Not that that is an excuse but would be a good indicator why they had fires and nobody else of the 80 relevant complaints did. "SEVERAL WEEKS LATER, ON MY WAY TO MY REGULAR MECHANIC TO HAVE THE REPAIR INSPECTED (DRIVING ON A PAVED ROAD ON PRIVATE PROPERTY AT SONOMA RACEWAY IN SONOMA, CA), I EXPERIENCED A BANG AND KNOCK IN THE ENGINE." "2 WEEKS OF DAILY COMMUTE TO WORK WITH NO ISSUES, THEN ON FEB 17, 2019, I WAS DRIVING UP HIGHWAY 1 FOR A COUPLE HOURS," I am amazed that the majority of the complainants seem to think that the NHTSA is some sort of consumer advocacy group that will make Toyota pay. They are not. They are a safety agency and that is all they will address. Of course more complaints will make them look into the safety aspects but that is where it will end. The number of current investigations into the issue is telling all on it's own. It was also interesting to read the complainants statements as to Toyota's response when they contacted them. It was almost unanimously "it is up to the dealer to resolve". Go after the dealer and you stand a much better chance of getting resolution. An initial consult with a lawyer is usually free so at least check it out and don't expect NHTSA or a class action to do the work for you.
#1302 | ||||
Drives: 2013 frs
You assume the common denominator is that they were driving hard. But were they?, how do you know? Did you go through the other 80 complaints to see (assume) if they were driving hard or not? I would argue that 2 fires out of 80 is a very reasonable number. Do all engine failures lead to an engine fire? No of course not, but an engine failure increased the likelihood of an engine fire. It depends on a variable of factors. On the flip side, it could also be possible that they were indeed driving hard which not only resulted in the engine failure (from either sealant, or design flaw/oversight) but also an engine fire, wouldn't you agree? Quote:
In the second quote, the fact that he was driving for 2+ hours, again, does not equate to hard driving. Quote:
If people choose to go the class action route, let them, and stop shitting on DJ72 we should be here to support each other and help solve problems not call each other shills and defend companies which in the past have cut corners and knowingly hid information which cost real lives. |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
