Old 04-21-2019, 08:38 AM   #827
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
For those that cant renew registration in california until the recall is done..... have you considered the whole Montana LLC thing?
Old 04-21-2019, 10:46 AM   #828
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
To counter my own point though I will say that I would never of had it done right from the start even if there had been zero failures from repairs. If your springs were going to break they would have already so why fix what ain't broke?
My BRZ is at 30,000km (not miles) and is running insanely healthy, should mine go in as it's too early to tell if the engine will have valve spring issues?
scottryan is offline   Reply With Quote
Old 04-21-2019, 02:37 PM   #829
Ultramaroon
not playing cards
Ultramaroon's Avatar
Why do you say it's too early to tell. None of us will ever really know. Valve spring on your Ford Focus might fail. No matter how good techs get at doing this job, the fact remains that the probability of failure due to the intervention is orders of magnitude greater than that of the original concern.
Old 04-21-2019, 03:01 PM   #830
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Don't do it.
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-21-2019, 07:18 PM   #831
msaikhan
Drives: frs
Originally Posted by ermax View Post
Hate to tell you but yes bearing material is flaky like that. I’m amazed you aren’t knocking like crazy if you have chunks of bearing large enough to break in your fingers.
Here's a video of the flake.
It's not knocking, but i did hear very light ticking occasionally. Can it be left over material from last engine? I saved the oil and filter.
msaikhan is offline   Reply With Quote
Old 04-21-2019, 09:19 PM   #832
Teseo
Drives: frs
This should be on 1st page
Old 04-21-2019, 09:40 PM   #833
OnlyAllegedly
I just got my car back two weeks ago and I just noticed today that it's leaking oil out of the driver's side of the engine (not puddles, but definitely leaking and it never did before) and I see bits of RTV when I pull the dipstick. I plan to bring it back to the dealership ASAP.
Is there anything I should do in particular regarding this? I feel like there's a good chance the motor will be trash sooner or later if RTV is making the rounds. I'm documenting everything as best as I can with pictures and e-mails to the shop manager (for paper trail of when the problems occurred). I also saved a paper towel from when I wiped the dipstick with bits of RTV on it.
OnlyAllegedly is offline   Reply With Quote
Old 04-22-2019, 08:40 AM   #834
msaikhan
Drives: frs
Originally Posted by msaikhan View Post
Here's a video.
Just cut open my oil filter. Found some rtv inside.
Old 04-22-2019, 08:42 AM   #835
ka-t_240
Bag and tag that thing!
ka-t_240 is offline   Reply With Quote
Old 04-22-2019, 11:07 PM   #836
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Anyone see Scotty Car Repair's video on this subject?
[ame]https://www.youtube.com/watch?v=oVjQQj8Rx98[/ame]
shiumai is offline   Reply With Quote
Old 04-23-2019, 12:01 AM   #837
Teseo
Drives: frs
Yes. I asked in his life stream and turns out the next few days made the video. Shocking, right?
Old 04-23-2019, 12:21 AM   #838
ybotspawn
ybotspawn's Avatar
I would say his views are a bit biased and frankly subjective. While tearing apart the motor, as we've seen, has been problematic this issue could have happened to any manufacturer. His belief that it's just Subaru fail isn't helped by his eccentric behavior.
Old 04-23-2019, 01:02 AM   #839
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Old man Scotty hates every car unless it's a corolla of course . Good for general info bout cars that's It .
mswbrz is offline   Reply With Quote
Old 04-23-2019, 07:35 AM   #840
Oh that guy. I made it a record 2 seconds and 74 hand waves into the video until I decided I had better things to do.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
