#365 | |
Benz Tech
Drives: 2017 BRZ Premium
Recalls are notorious for cutting the time payed on a warranty job. While replacing valve springs normally under warranty could pay 18 hours, now that’s it’s a recall they pay 12. That sucks, but that’s the game. You lose money doing a set of valve springs, then you make 6 hours replacing ball joints in 45 minutes. I’ve made 200 hours in two weeks, I’ve made 13 hours in two weeks. You have to play the game. |
#366 | |
Drives: 13 Subaru BRZ
Right, like I said, job pays differently, if I wasn't clear about that apologies. Thats my friends point, though. The hours being allotted are probably few enough that techs are rushing.... |
#367 | |
Benz Tech
Under a normal warranty repair you would get paid to remove the engine, drain/fill the ac, remove the cams, replace the springs, change the oil, etc etc etc. It adds up that way, and some creative writing skills can gain several hours on a big job. Recalls remove the "game" from flat rate. You do the work, it pays what it pays. Generally you break even or make a little bit. Sometimes you don't. It takes experience to move past that and do your job without rushing and being pissed off that you're losing money. You'll make it up next week. |
#368 | |
Initial G
Drives: 13 FR-S, 15 BMW 228i
2013 FR-S
2015 BMW 228i |
#369 |
2013 FR-S Whiteout / SSC
Does anyone have thoughts on how we should expect the gray gasket material to look on the outside of the valve cover following this job getting completed? I just got mine back from the dealer, and it looks like a lot of gasket material on the outside. It is giving me some reason for concern.
#370 | |
https://static.nhtsa.gov/odi/rcl/201...8V772-0191.pdf
#371 | |
Having rebuilt my own engine I can say that 12.5 hours for this job is really tight. This isn’t my profession and it was my first time tearing an FA20 apart but 12.5 still sounds extremely tight. I have no doubt that they rushing this job. I also have no doubt that as time passes they will get better at this job and the problems will diminish. Even then I think I’ll skip this recall. |
#372 | |
A friend of mine was a tech and said there is a lot of politics too with regards to who gets what job. Some jobs are allotted way more time than needed and you can bank a lot of time on them but if no one likes you then you get the shit jobs that you break even on all the time. |
#373 | |
#374 | |
What Tcoat said. There is a grove around the cover and the bead needs to be on the top of this grove. If it is inside the grove (which photos around here have been showing) then most of the packing would push inside which is bad. I think I would be more concerned if I didn’t see any packing on the outside. |
#375 | ||
Benz Tech
Lots of games, this whole profession is a game. You can grab any RO from the stack, no one is really watching. Or know where the next good RO is, sandbag on the job you have, then magically be done as soon as the good RO comes up. It's all a gamble, grab the 12 hour recall, upsell some work while your there and be busy for a few days, or take that 4 hour service, upsell nothing, and be done in 2 hours. Quote:
#376 |
My friend at the Toyota dealership says they have quoted just shy of 13 hours (makes sense with what everyone else seems to be quoting here). He also says you need at least 4-6 hours just to remove the old sealant. Thats not including the other parts of the job. Sounds like Toyota set these techs up to fail. Anyone got any estimates of what Subaru stated for the same job, just for comparison sake?
#377 | |
Benz Tech
You win some you lose some. Young guys want to win on every single job and throw a fit when they can't. We have hourly guys that get pissed over it, makes zero sense to me. I've made 400 hours in a month, one time. I'm not mad I don't make that every month, I just smile and bust ass to make the next dollar. |
#378 |
Maybe the techs should be salaried - ??
humfrz
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
