Old 09-05-2020, 08:39 PM   #1541
ka-t_240
Originally Posted by gravitylover View Post
Well it looks like I found a 64k mile short block from a 14 FRS. Does anyone know if there is anything that will need to be changed other than new head gaskets and bolts? ECU is the same, etc?
If you are going to go the fix it your self route, I highly suggest skipping a used short block in favor of finding a fully assembled long block/pull out.
If you drove your car with a bearing failure/knocking, it is likely that anything oil touched could be toast. You would potentially need heads/cams, oil pump, and all that to go into the used short lock. This will cost you much more than just buying a pull out.
ka-t_240 is offline   Reply With Quote
Old 09-05-2020, 09:40 PM   #1542
TommyW
TommyW's Avatar
Drives: '13 Whiteout
i even had to replace my new oil cooler. Metal in the motor and the whole lower end and any relative parts are toast.
Old 09-06-2020, 07:05 AM   #1543
gravitylover
I pretty much came to the same conclusion and have stopped looking at short blocks. I've found some nice looking reman, 0 mile long blocks but I'm not sure that's the best way to go either. It certainly isn't the easiest or least expensive. Thankfully I can be kind of patient with this so I can keep looking for a low mileage, used, complete motor. I have a line on one from a side impact wreck so we'll see how that goes. I had a mobile mechanic here at the house yesterday helping me put a band aid on my Durango so I can drive that for a few weeks and he quoted me 7 hours to pull the old motor and install the "new" one right in my driveway so I'm leaning in that direction.
Old 09-06-2020, 11:09 AM   #1544
TommyW
TommyW's Avatar
Good luck. I wish you the best and that it all works out for you
Old 09-07-2020, 10:06 AM   #1545
ka-t_240
Yup, very common on the EJ motors for people "fixing" them to have no idea to replace their factory oil cooler after an engine failure, then have a second engine failure. Have seen it many times by shops/people that have 0 idea what they are doing.
Old 09-12-2020, 09:26 AM   #1546
gravitylover
Is there a difference between manual and auto motors that would make install more challenging? I keep seeing them advertised as for manual or auto.
Old 09-12-2020, 12:08 PM   #1547
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
There is. If you’re doing a swap it’s ideal to get a same model year/transmission engine.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 09-12-2020, 12:33 PM   #1548
gravitylover
I think I want to avoid 13's
Old 09-22-2020, 11:34 AM   #1549
Teseo
Drives: frs
Try to avoid 13' with recall performed
Old 09-22-2020, 01:42 PM   #1550
gravitylover
Those seem to cost a lot more than 14-16 motors, the difference is as much as $1k.
Old 10-02-2020, 04:30 AM   #1551
alan.chalkley
Drives: 4wd zooks
I traded in my 2013 at a local dealer and a few weeks later it was sold to somebody else.
Somehow i still received another recall letter.
It seems that everyone is avoiding the recall the recall!
alan.chalkley is offline   Reply With Quote
Old 10-02-2020, 04:45 PM   #1552
cnk
Drives: '13 DGM BRZ Limited
Yeah, they call me about once every 2-3 weeks and send me an email a month to remind me to get the recall done. Just not going to do it. Not worth the risk at this point in time. Especially since my state doesn't require it for re-inspection.
cnk is offline   Reply With Quote
Old 10-13-2020, 03:44 PM   #1553
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Had the recall done early May. Last week the engine began knocking as I headed to Yosemite. Got it towed yesterday and they will begin teardown Friday it sounds like. They have already agreed to cover repairs and a rental car if its due to excessive sealant. Will update next week hopefully
I was around 3500 miles post recall.
Old 10-13-2020, 03:57 PM   #1554
humfrz
Well, THAT sucks -
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
