#1429 | |
not playing cards
Basically, whatever was going to break did so within a thousand miles or two. It was an idiotic decision from the very beginning.
#1430 |
Drives: Raven black manual transmission
Gm. I'm sorry you guys have had that problem.. I have a 2013 scion frs that I've been driving for almost 7 straight years by July of 2020, I have put over 120,500 miles on my stock FA20 engine, and I haven't had any of those problems.. So far so good, this "valve spring recall defect" is definitely not happening to all 2013 models. I also tuned the engine with an openflash tablet getting over 260hp according to a fuel injector calculator website from where I had bought my "dw 300c" fuel pump.. I had to swap out the old oem pump, that fuel pump needed to be replaced around 92,000 miles, after driving it for like 5 straight years the oem pump began to fatigue.. Oem fuel pumps are expensive from the dealer, it can cost over $500.00.. I only payed approximately $190.00 for this aftermarket deep fuel pump from the www.ft86speedfactory.com website and the spec ratings of this fuel pump product are much higher in flow rate output, the flow rate of this aftermarket pump can supply turbocharged and super charged compressors.. Mind you my car is still running naturally aspirated. No force induction necessary for my alleged horse power gains..
#1431 |
Drives: brz 2017 hksv2
260hp...calculated from a fuel calculator.. yes, no.
If I put AFR 9 in a NA FR-S what does it give, 350hp? Neither a dyno number is reliable and you trust a website calculator? |
#1432 |
I meant swap out the old fuel pump. Not "pen" that was a typo error..
#1433 |
As for your question with a fuel pump calculator, there's a list of other things that go into this when sizing your fuel pump and knowing about static fuel injector flow rate. I'm sure their values are rather conservative.. . It's not that simple, any one can just plug in random numbers to arrive at a calculated solution, you have to be involved and familar with tunning the car's ecu to get a proper estimate..
#1434 |
Pro Couch surfer
Drives: 2019 BRZ Sport-tech RS.City car:GD3
#1435 |
You need to go read the rest of his stuff!
#1436 | |
I'm not saying your wrong, but if you are right then the lawsuit shouldn't be for the ones that failed, it should be from the stockholders of Subaru and Toyota.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1437 | |
then why not estimate your NA car at 295hp...maybe little more? |
#1438 | |
not playing cards
#1439 |
Drives:
#1440 |
not playing cards
#1441 | ||
Proud of BOXER
Drives: Subaru Boxer
My theory is that because they got in so much hot water because of the unintended acceleration stuff years back, that as soon as the Toyota lawyers saw "May cause the vehicle to stall [and lose control]", they shit the bed and screamed RECALL, RECALL, RECALL! However, it should have been a voluntary recall in all 50 states. Ticking the box for "emissions related" (which makes it mandatory if you want to actually drive it on the road) and fucking over everyone in CA was a big slap in the face. In no way is it in any way an "emissions related" recall. That part is 110% bullshit and only serves to highlight the bureaucracy and horseshit that takes place in CA perpetuated by CARB.
#1442 | |
Again, it isn't the recall itself that caused the failure, it was sloppy work on the part of a few mechanics. Had the work been done properly we wouldn't have anything to talk about, it would just be a footnote and we would all be telling folks that were looking at buying a used 2013 "make sure the recall for the valve spring is done on the car".
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
