#4313 |
Could someone take a look at this and let me know if everything looks good. I see the AFR dip when I go WOT but that's about all I know to look for. Thanks
http://www.datazap.me/u/joeyman15/es...log=0&data=1-6 |
#4314 | |
Plus the added cost really drives down the affordability of the ESC. Sent from my HTC One using Tapatalk |
#4315 | |
Drives: Fiat Abarth
#4316 |
Drives: 2013 Asphalt 6spd
I am mainly interested with the factory battery. I doubt it is sealed, but it is a working battery and seems a waste of money to buy a whole new one. I just wasn't sure about needing to be vented. I googled it, but some people said the newer batteries only give off hydrogen, insted of acid vapor(rust causing) like the older batteries. and that the trunk isn't completely sealed, so there shouldn't be a problem with buildup.
#4317 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I'm sure Hindenburg thought something similar. I would add a vent.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#4318 |
#4319 |
Drives: Fiat Abarth
I'm sure 12's is still considered safe. Assuming you're using the OFT map from Shiv? I'm intrigued more than anything as 11.2 vs 12.6 at the same RPM is a pretty good difference, considering its the same tune.
#4320 |
I'm using the OFT map. I'll log my trip to work tomorrow and see if anything different happens.
#4321 |
@shiv@vishnu do you think you can comment on some of these catalogs that people are posting. Is there a way we can filter them to you to see if everything is as expected?
It seems most are in the low 11s but some are in the 12s. What should we expect to see? Also what about the couple of people that have posted logs that show a quick shot to lean at about 2500 and then a taper down to 11s? Thanks for any assistance you can provide. Sent from my HTC One using Tapatalk |
#4322 | |
Drives: Fiat Abarth
http://datazap.me/u/jac/brz-oft-phan...om=11918-11980 |
#4323 |
Drives: FR-S 10 #103 AT
How about doing the classic diode isolated dedicated to the stereo battery in the trunk?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#4324 |
@ Robftss
I can`t be the only one who blinked and missed something. Can you please summarize the differences between the three levels of dump packs?
#4325 | |
Drives: small
Replacing the stock starter battery is one of the easiest weight reductions you can do in any car. Well worth the price. |
#4326 | |
One of the reasons . I saw that myth busters too.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
