#3011 | |
Drives: WR Blue BRZ, 240Z
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#3012 | |
Drives: 2013 Asphalt 6spd
Let me try to explain what I am talking about. OP in the first post talks about this Quote: DRAG REDUCTION Next lets talk about DR. My car has the most aggressive version of DR. DR's intention is to look for a loss in power due to high vacuum and equalize that with a pulse of the compressor. The fact of the matter is DR is not used in the way we used it today, you would never go with DR only all the way to redline. DR give you a nice shot of boost to get you going down low. With that said here are the DR results with both stock and charger disabled on the same graph. Its plain to see from the graph that it does work, and works well especially at the top end. Yes there is some oscillation however Rob is now working on turning up the frequency/sample rate. solenoid on an old throttle body could be used as well /quote from my understanding, this is about the engine having a loss of power due to engine having to suck through the ESC when it is not powered, creating a restriction. I would assume this would mainly be at partial throttle and at higher rpm, the dyno shows the power loss is about 5 hp at mid range, and 20hp at top end. This of course has been remedied electronically, by having the ESC kick on in spurts under heavy vacuum. I don't know how often this would occur, or what kind of drain on the batteries. But this solution would also mean that the batteries are almost constantly charging/discharging even when you are not hitting the WOT switch under the pedal. I do not know the particulars but it seems like the ESC would be partially working all the time and not "just" when you hit the WOT switch. So If for any reason you didn't want it working all the time, or only want it working when you floor it. I suppose you could do as Gary suggested, and unhook the vacuum line to the controller, this however still leaves you with the intake restriction, and a loss of power over stock. Please don't take this as anything more than a curiosity on my part, The above solution may work wonderfully and never cause any issues, and from the look of it, give more power all the time which would probably make everyone happy. But, on the rare occasion someone might want want another option... My thought was to have an alternate way for the engine to get air, so it didn't have to suck through the ESC when not in use. With two Y connectors, one at the throttle body, and one at the filter box, you could hook up the ESC on one, and a strait pipe with a one way valve on the other. Now as the ESC is a restriction when not powered, the natural vacuum of the engine would pull through the path of least resistance, which should be the valve side. However when the WOT switch is tripped and the ESC starts to kick on, it will equalize the pressure in the intake. Now that the ESC is spinning it will be the main intake for the engine, so with no vacuum on the valve side, to hold the flapper open, the spring or gravity would close it so no boost would be lost. It is possible that without the intake air constant spooling up the turbine, there might be some extra spool up time. It's all just a thought experiment so I don't know. this is only an example, just the first thing that popped up on google: I have seen pvc ones for $10, or any number of other workable valves, I'm not saying it's a good idea, but for what it's worth. ![]() In the picture above, the air would be moving from the intake box on the right, through the valve and out the left side to the throttle body. the spring would only need to be strong enough to hold the valve closed at no vacuum, gravity might be enough for the above example. As the ESC is extremely close to both the throttle body, and the Air Box, It would have to be moved a few inches back from the TB, and to the left, or a different Intake filter arrangement made. Last edited by Target70; 01-03-2014 at 05:03 AM. |
#3013 |
Drag reduction works very well. The pulse lasts about a second and after it' has pulsed it reviews the MP and if necessary, pulses again. I find it will engage when starting up a hill or when accelerating in high gear at low rpm. If you don't see the voltage drop on the indicator, you would never know that it engaged. It's that seamless.
In practice/reality, the compressor is NEVER a restriction. When you have part-time boost like the ESC the tendency is to engage the ESC/boost when you want power. For example, if I'm climbing up a hill and the car feels lethargic, I just engage the ESC until I'm at the speed that I was trying to achieve and then I back off the throttle. It's not something I give a lot of thought to, but when I need power I'll go to 75% throttle. The valve that you presented seems like a solution for a problem that doesn't exist.
#3014 | |
Drives: 2013 FR-S Argento
#3015 | |
In reality DR is not used that much so to try and incorporate all the extra stuff is more work for little gain. Fuel economy is not affected with or without DR. Power above 5000 rpm is affected....the compressor does not create a measurable restriction below 4000 rpm. From experience the power drawn from DR is very negligible as it pulses short burst. Sent from my HTC One using Tapatalk |
#3016 |
Drives: 2013 Black FR-S
#3017 | |
In the real world a bypass is just something you will "pass through" on your way to boost. An unnecessary step and complication.
#3018 | |
It's not magic, just physics.
#3019 | |
You have to remember the JR does make 240(@7300) on the carb legal tune but ever time he shifts it drops to 150 to 175hp(@5000rpm) or so and has to build back up. This 240hp isn't fully utilized until 4th gear when he is above 7000 rpm for longer periods of time. This was not meant to knock anyone or say something is better than something else just as a simple comparison. Thanks. Sent from my HTC One using Tapatalk |
| The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (01-03-2014) |
#3020 | |
Drives: VW
To a degree all can be sorted using scientific fact, not my opinion. Restriction: Requires flow and constriction, it is exponential and only occurs when enough airflow is present to effect velocity thru the constriction. Ex. Water flowing through a 1" dia hose that is 1/2 filled flows the same as a 2", 3", 4" dia hose, only when the 1" dia hose is completely full does it become a restriction. The TQ250 flows ~60-70 HP worth of air with little restriction. Fuel economy: Fuel is injected as per metered air not pedal postiion. Power loss: This is what the DR does @ ~ +50% throttle, or you could just push the pedal to 55% and have the same result. DR restores pedal expectations and tip in responds. By-pass: no spring required on flapper valve delta P's take care of that. Now...back to my CNC.
| The Following 3 Users Say Thank You to Robftss For This Useful Post: |
#3021 | |
#3022 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#3023 | |
Drives: 93'Camry, 82'Corolla, 76' Celica
The real fun is definetly in the gains to be found for the investment (which I believe is a pretty honest number so far), and the fact that you can probably do this without having a finicky, breaky car. Had a talk with the TRD, and enthusiast Sales guys at my local Toyota dealer today.... right now the are "fixing" a local guys FRS. He figured he could adapt a Suby turbo system to the car (with 16lbs of boost). Now he is nursing the car through a $12,000, engine replacement. I walked out and looked, and it was messy!Makes this option look quite reasonable for the fun quotient. ![]() -Country Hills Toyota, Calgary Alberta, was where I talked to the guys fixing this poor little busted FRS, by the way. Last edited by silent runner; 01-03-2014 at 10:25 PM. Reason: more info |
#3024 | |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
