orthojoe
Old 01-06-2014, 01:02 AM   #183
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Just did this today after trying for a few times in the parking lot. Love how we can do cool stuff like this with our cars. Just driving around town didn't notice any difference obviously, but glad that I can do it if I want.
dave77 is offline   Reply With Quote
Old 01-06-2014, 05:07 PM   #184
brianL.
brianL.'s Avatar
Drives: BRZ/1J Supra
Thanks for the great tip.I had no idea that this was a option.I will be using this when I get to the track this year.How do you enable the drives aids when your done racing?
brianL. is offline   Reply With Quote
Old 01-06-2014, 05:35 PM   #185
onefitz
Drives: 13 GBS BRZ
Should be able to just turn it off and then back on.
onefitz is offline   Reply With Quote
Old 01-06-2014, 05:53 PM   #186
Turn your car off, and then back on, and everything is back to normal.
You have to do the pedal dance every time you want it, as soon as you turn on the car.
Old 01-17-2014, 12:26 PM   #187
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Back at the track in a couple weeks so I thought I would actually practice the "pedal dance" in advance and commit the process to memory. Good news is "I got it" and should not have any issues activating before sessions.
Afterwards I was messing around with the buttons and found out that you can activate the VSC mode and the trac off simultaneously. Any idea what this configuration would yield??
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 01-17-2014, 12:32 PM   #188
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the "track off" will disappear once you break 30kph, so it's not a "combination" per se
and in the above picture vsc is not off, i'ts just in sport mode, which is rather poor
The Following User Says Thank You to 7thgear For This Useful Post:
CSG Mike (01-17-2014)
Old 01-21-2014, 07:44 AM   #189
troek
troek's Avatar
Drives: 2012 Toyota 86
i was losing my rear end (recoverable) when trying to trail brake last weekend at fuji speedway(just holding traction for x seconds, im going to try this next time and see if that fixes it, or its just my skill level, lol.
Old 01-25-2014, 03:54 AM   #190
Bushman7140
Drives: 2013 FRS M/T Firestorm
Originally Posted by JiB View Post
This reminds me of the cheat for the old sega console game Mortal Kombat 1 for blood mode, ahhh the good old days
ABACABB!!!!
Bushman7140 is offline   Reply With Quote
The Following User Says Thank You to Bushman7140 For This Useful Post:
DanoFA20 (01-27-2014)
Old 01-25-2014, 08:34 PM   #191
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The sequence is as follows:
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car.
- Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull.
- Press the brake pedal 3 times. Hold it down the third time.
- Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull
- Press the brake pedal 2 more times.
- On the last press of the brake pedal, two yellow lights should have come on.
Mike, I found on my car the sequence is much shorter once the engine is warmed up.
Prerequisites:
- engine must be warm (coolant temp gauge at middle of "warm" area, actual temp reading IIRC must be above 170F)
- idle must be normal at ~650-750. Once the engine is warm, this can be sped up by revving the engine once or twice and the idle will settle after throttle is disengaged.
The sequence above is still the same, except I end up only doing following:
- Pump the brake pedal 3 times. Hold the brake pedal down on the 3rd press
- Pull the hand brake 3 times. Hold/lock the hand brake on the 3rd pull
- Pump the brake pedal 2 more times.
- On the last pump of the brake pedal, two yellow lights should have come on.
Short version would be 3x foot brake, 3x hand brake, ~2x foot brake.
I'll see if I have time to make a short video to document the pedal dance.
Hope this helps.
-alex
Old 01-26-2014, 01:36 AM   #192
Prerequisites:
Hope this helps.
-alex
If you start the car with the e-brake up, that works
DriftEm (01-26-2014)
Old 01-27-2014, 09:13 PM   #193
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
I don't remember the original post (and a quick search didn't find it...), but someone had posted up a sequence to turn off additional electronics in the car. The sequence is as follows:
I purposely used staggered brake compounds to test whether the brake dance does anything; here are my conclusions.
- The pedal dance eliminates electronic brake force distribution.
- The pedal dance also eliminates the "panic brake" function.
- I tried trail braking mid-turn with the "normal" electronic aids off, but without the pedal dance. This resulted in a spin; the car literally locked up the rear brakes. My speculation is that the car recognized the fronts locking up, and put additional force on the rear brakes. The problem here, is that I had purposely put a much lower friction pad in the back, so it kept sending more and more brake pressure to the back, until it just locked. Once it locked, it stayed locked, even though I was not stepping on the brakes.
- I tried this again a few more times. Same result.
- I then tried again, but with a rear brake bias. This time, pressing on the brakes mid-turn or trail braking always resulted in the car straightening out and/or plowing.
- With the pedal dance, I can trail brake or brake in the middle of a turn for rotation just fine, regardless of pad setup.
Moral of the story: if you're driving on a track or at an autocross, do the pedal dance! (Remember, ALL aids will be off)
All testing was done on a closed course, at the "Balcony", courtesy of Willow Springs Raceway.
*edit*
From another post:
i might have missed it durring my reading but, does the pedal dance deactivate ABS? or just the EBD? it also deactivates obviously TCS and STAB right? thanks much for your safe testing
DanoFA20 is offline   Reply With Quote
Old 01-27-2014, 10:05 PM   #194
troek
troek's Avatar
it leaves the ABS on. Disables everything else.
The Following 2 Users Say Thank You to troek For This Useful Post:
bestwheelbase (04-28-2014), CSG Mike (01-27-2014)
Old 02-14-2014, 01:37 PM   #195
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Anyone have any thoughts on using the pedal dance on snow? I've been plowing snow since yesterday since my street doesn't get plowed at all and we have well over a foot. Turning off traction control (hold for 5 seconds method) is 100% mandatory (yes, I have snow tires). Will this dance change the car for the better or worse in snow?
xxBrun0xx is offline   Reply With Quote
Old 02-14-2014, 01:49 PM   #196
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'd do it in the snow but too cold to activate :/
so i just makde due with the 5-second option
although i can feel the VSC kick in when i'm running over surfaces with extreme grip differences left to right.
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
