Old 01-23-2013, 11:15 PM   #15
iiviiystyle
Drives: White out Fr-s
Oh nice! is there anyway someone can put a pic of the buttons? I only see one button on the mirror lol. Thank You!
iiviiystyle is offline   Reply With Quote
Old 01-23-2013, 11:21 PM   #16
hostkiller
hostkiller's Avatar
Drives: 2013 Scion FR-S Asphalt 6MT
Nice DIY write up OP! I will be doing it when my work is not so busy......
If you are looking for the mirror with homelink function you should be looking at this: http://www.subarugenuineparts.com/pr...oducts_id=1880
hostkiller is offline   Reply With Quote
Old 01-24-2013, 02:13 AM   #17
CA2
Dusty Raven
Drives: FR-S MT
Nice write up - thanks!
CA2 is offline   Reply With Quote
Old 01-24-2013, 03:44 PM   #18
Lokutus
Drives: Scion FR-S AT Asphalt
Here's the photo showing the home link buttons and compass led.
Lokutus is offline   Reply With Quote
Old 01-26-2013, 11:39 AM   #19
Foobar
SLO NO MO
Foobar's Avatar
Just did this today, thanks for the writeup!
I had a problem with the mounting adapter screws though - it seems like they weren't getting all the way through the plate to grab on to the metal piece on the other side, so it wasn't tightening fully. I was afraid I was wearing out the threads that it connected to, so I just turned it enough that the mirror wouldn't fall off, but it is definitely not fully tightened.
Anyone else notice that?
Old 01-29-2013, 08:48 PM   #20
Longhorn248
Hook 'em
Longhorn248's Avatar
When I installed those screws they felt pretty secure to me. Did you install the adapter plate in the correct orientation?
Longhorn248 is offline   Reply With Quote
Old 01-29-2013, 09:37 PM   #21
Foobar
SLO NO MO
Foobar's Avatar
Definitely. I noticed the plate was a little loose though. That retaining clip wasn't tight against it. Think that might've been my problem? If anything, it felt like the plate was loose so the screws weren't getting a good grip on it - maybe it was too far away from the screws and I could only get a few threads to connect and it was stripping them? I took it apart again and tried fitting the screws directly into the plate and it seemed tight and snug so I dunno what's going on here.
Old 01-30-2013, 01:58 AM   #22
Longhorn248
Hook 'em
I guess it's possible...do the screws or threads in the plate look stripped? Is the "retainer clip" thingy inserted all the way?
Edit: You were sure to use the new retaining clip that came with the mirror and not the old one right? If I remember correctly they're different sizes and I could see the old one creating space between the new mirror mount and the plate the screw goes into.
Old 01-30-2013, 08:57 PM   #23
sid325
Drives: Ultramarine FR-S 6MT
Installed mine today, no issues. The write-up and photos were very nice to have. Thanks for posting the info.
Jacob
sid325 is offline   Reply With Quote
Old 04-09-2013, 10:00 PM   #24
BRZnut
Drives: BRZ DGM Limited
Does anyone notice that the mirror vibrates on rough road. Does not make any noise but the image in the mirror is shaking more that it should.
There seems to be a little play on the mounting section that is attached to the glass.
Anyone else have this???
Old 04-09-2013, 10:38 PM   #25
Imrac
Drives: 13 SWP BRZ Prem
I actually noticed less vibrating in mine after installing the AutoDimming. Previously had a lot more image distortion. Maybe it's not tightened enough?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 04-24-2013, 07:22 PM   #26
MrGen
Finally got my mirror in the mail and got it installed.
To make installation a little easier on my large hands I found disconnecting my dome light gave me a little more wiggle room.
Also the FR-S power cord in the overhead does not need to be cut loose to be utilized, just orient the plugs and bowling ball pinch them together. If you have issues finding the cord in the ceiling, just know it is tucked away on the passenger side of the hole. If you want to put eyes on it just push your steering column all the way in and pull your seat as far as you can forward.
The trick to reduce the vibrations of the mirror is not to crank down on the screws. You will feel them become snug and they will back out if you continue cranking on them. Just get them snug and leave them be.
MrGen is offline   Reply With Quote
Old 05-20-2013, 10:36 AM   #27
dd86
Drives: Asphalt FR-S MT
Just a quick note - when I installed mine, I found it pretty difficult to route the connector wire through the headliner. There's a hard plastic piece directly in ahead of dome light the that doesn't seem to give enough clearance for the plastic connector head (black head -> mirror) to fit through. Fortunately, about 5-6 inches to the right, there is more clearance and the connector head easily slips through. Then I just had to pull the wire through and straighten it out.
dd86 is offline   Reply With Quote
Old 05-31-2013, 03:46 PM   #28
Avo1789
Avo1789's Avatar
I too, am having slight vibrations on bumpy parts of the road. Its not terrible, but i do notice it. I also did not over tighten the screws... any advice?
Update: I realized that the bracket is self tapping, and after another look it was indeed stripped. I'm about get another mounting kit and try again!
Avo1789 is offline   Reply With Quote
Installed Auto Dimming/Homelink mirror DEC1 Cosmetic Modification (Interior/Exterior/Lighting) 71 09-10-2020 10:46 AM
Fuse Location for Auto Dimming Mirror Harness tonytduc Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2013 09:46 AM
auto-dimming mirror white devil Cosmetic Modification (Interior/Exterior/Lighting) 5 10-05-2012 01:05 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 01:19 PM
question about tinted windows with auto dimming mirror... Norcalmav23 BRZ First-Gen (2012+) — General Topics 13 04-06-2012 08:37 PM
