#897 |
Drives: Scion FR-S
Will 255/40/17 fit with RCE Yellow springs? Or, will it rub on the spring perch?
My build thread:
http://www.ft86club.com/forums/showthread.php?t=63292 |
#898 |
Drives: a fast N/A BRZ
anyone running 17x9 Mach V Awesome with 255's?
#899 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
#900 |
Fiebru
Drives: Scion FR-S and Integra Type R
I will buy new tires for my FRS and I am considering to get 265/35 for the rears but still haven't decided for the fronts.
Which one you guys recommend? My wheels are 18x8.5 +44 and I'm on FA coil overs.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#901 |
Drives: Vortech Supercharged FR-S
255/35R18 DW on 18X9.5 +40
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#902 |
Drives: BRZZZ
#903 |
The Angry Brit
Drives: 1991 E30 318iS
Thanks man! I'm running ISC coilovers, the wheels fit with stock struts and oem springs, and also with eibach sportlines too on 235/45's, not sure the 255's would fit on a regular strut set up with the +45 RPF1s
#904 |
Drives: FR-S Whiteout
On the +45 wheels and 245/40/17 tires mounted, it still rubs a little with 5mm spacer in the front (total of +40 offset -2.5 camber). Although you might get away with 255's if you run little or no negative camber on the stock struts. Then again, what's the point if you can't dial in some much needed camber?
#905 |
Drives: BRZZZ
#906 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#907 |
Drives: 2014 Firestorm FR-S 6MT
#908 |
My FR-S has 5 gears
Omar GC
#909 |
Drives: Olive Drab/Army FRS
Soon to join this thread. Swapped my AME Tracer TM02 (18x9.5 +22) for some Gram Lights 57Xtreme in Winning Blue (18x9.5 +40) and bought some 255/35/18 Hankook Ventus V12 Evo2 yesterday. Excited to get some meat under this car.
QUALITY OVER QUANTITY |
#910 |
Drives: bucket
wheel and tire specs?
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
