Old 05-28-2019, 09:39 PM   #2409
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Originally Posted by Jive Turkey View Post
i don't want to be rude, but this has been beaten to fucking death in here. the entire first post is incredibly detailed for a reason, yet we get non-stop reposts of the same questions.
the rear bumper tab is the little corner of the bumper on the inside of the wheel well where it meets the quarter. if you don't do it it will simply trim itself, not a problem you'll just hear rubbing noises at times under compression....which is also a big difference. if you have shit BC suspension you have no suspension travel you won't rub.
You see my setup, the ONLY times i rubbed are full lock, and even then it was a maybe.
if you stick to a 40 offset and a 265/35 you'll be fine if not slammed.
an all you people in here worried about rubbing, think to yourself, how often do you go full lock, I hardly ever did/do.
Thanks for the answer!
I hate to break it to you, but you will continue to get re-posts of the same question no matter what you do. Each persons suspension will be different, hence the desire to get validation for their own vehicle from others who are way more experienced in this specific trade.
Not to mention I myself am a visual learner, so I am trying to picture where exactly this will happen and the long-term detriments of it. More-so I didn't fully understand why everyone was opting to go 2xx/35 vs 2xx/40 until the other shoe dropped for me.
But thanks for the advice nonetheless!
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 06-27-2019, 06:13 PM   #2410
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
totally understood, but i think its because most don't understand that most coilovers will give you same inner clearance.
the recipe doesn't change because the parts names change, thats why we post alignment and fitment specs.
as for the tires, i can understand where its confusing. just remember that the second number is an ASPECT of the first number. so a 265/35 will be smaller sidewall than a 265/40. (for example when i ran meaty fitment on my sti, a 275/35 had the same diameter/sidewall as a 245/40 due to the aspect ratio.
on these cars if you want meaty fitment on an 18' you should do 265/35 (or 255/35 if tires run meaty) or on a 17 i would do a 255/40 (for the super meaty sidewall look).
Jive Turkey is offline   Reply With Quote
Old 07-08-2019, 09:45 AM   #2411
Crystalwhitebrzsti
Drives: Crystal white brz
265/35r18 federal 595
Enkei rs05rr 18x9.5 square +42
Crystalwhitebrzsti is offline   Reply With Quote
Old 07-08-2019, 03:05 PM   #2412
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I am a fan of the RS05RR! That's going to look great!
I LIKE TIRES!
Old 07-08-2019, 09:36 PM   #2413
madpir8
madpir8's Avatar
Drives: Manual 86 GTS
265/35 MPSS
18 in x 9.5 Square Setup
Volk TE37's
MCA Coilovers
Some negative added on front and rears through lowering and alignment. No rear LCA or camber bolts etc upfront.
Would have loved to go lower but can't.
Full lock I have rubbing up front with the coilover but not the fender.
Rear right tyre is rubbing against fender on big dips at speed. Not rubbing the lining though.
I wonder if stiffening the dampers/springs would help?
Car handles extremely well on the ends. Very comfortable ride overall and still loses traction in first. (Car has FI)
madpir8 is offline   Reply With Quote
Old 07-10-2019, 05:11 PM   #2414
Crystalwhitebrzsti
@Leonardo thanks man! I have some more pics I need to upload, but I strugglz with that a little...here is one from our baby gender reveal..
Edit...got some pics!
Last edited by Crystalwhitebrzsti; 07-10-2019 at 10:56 PM. Reason: Uploading more pictures.
Old 07-21-2019, 08:33 PM   #2415
Iron_dookie
Drives: 13 BRZ
255/35 Achilles on XXR 527s 18x9.75 et35. All stock arms on Stance coilovers. Slight rub in the rear on the fender lip, nothing a roller cant fix.
Iron_dookie is offline   Reply With Quote
Old 07-29-2019, 09:46 AM   #2416
Daedex
That One Guy
Daedex's Avatar
Finally got it all together.
Specs:
Wheels: Titan 7 T-S5 18x9.5 +40 square setup
Tires: michelin pilot sport 4s 255/35r18
Suspension Parts needed for build:
Coilovers: Tein flex Z (at factory shipped height specs.)
LCA’s: SPC adjustable lower control arms
Rear Toe arms: SPC toe arms
I ended up needing rear toe arms to correct the toe as the factory specs didn’t allow me to. Just a heads up for anyone running this type of setup. The drop is approximately .8 inches all around, and there is no rubbing that has been noticed yet. Atleast none on full lock.
Shout out to @Leonardo, @Jive Turkey, @JoeC and @CSG Mike for being patient enough to work with me / help me understand.
Old 08-03-2019, 02:24 PM   #2417
gtpvette
Drives: 2015 FRS - FFR GTM
I've been following this thread a while,, thought I might post.
18x10 + 10 285/30 square. really dirty as it's been sitting a while LOL
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 08-03-2019, 05:04 PM   #2418
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Wow, looking great! Do the wheels have enough clearance from the PP Brembo calipers, or did you need any spacers?
timurrrr is offline   Reply With Quote
Old 08-03-2019, 05:45 PM   #2419
Daedex
That One Guy
Daedex's Avatar
no spacers. I didnt want to use spacers for a wheel, so I found these. plenty of clearance all around
Old 08-03-2019, 06:13 PM   #2420
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks! Added to https://www.ft86club.com/forums/showpost.php?p=3228874
Old 08-04-2019, 07:21 AM   #2421
new2subaru
Weight Weenie
Drives: 15 FR-S
Specs:
Why would you need to correct toe? Seems odd. What are your camber setting?
It looks great!
Old 08-07-2019, 10:11 AM   #2422
Daedex
That One Guy
Daedex's Avatar
It looks great!
camber settings are around -1.3 all around.
So the stock toe correction left me a difference of 1.5 degrees in the back, and I did not get the toe kit with the SPC LCA's.
However, the toe arms remediated the toe issues, and they are both at like .08 degrees.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
