View Poll Results: Best power increase option for GT86
Hybrid GT86 16 9.25%
2.5L Boxer 64 36.99%
2.0L Turbo 60 34.68%
FA20 is fine with me 33 19.08%
Voters: 173. You may not vote on this poll
Old 09-15-2013, 01:10 PM   #57
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by Suberman View Post
Manual gearboxes are going to disappear.
Originally Posted by chulooz View Post
How can you say that when 80% of this cars sales have been in MT?
Because manual gearboxes are disappearing.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-15-2013, 04:54 PM   #58
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
The point was that they are found in a majority of average performance cars and are popular; yes they are nearly gone in the vanilla car world, but performance cars show the opposite.
chulooz is offline   Reply With Quote
Old 09-15-2013, 05:19 PM   #59
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Actually most performance brands, Porsche, Ferrari, etc. are going exclusively to paddle shift automatics. Its well known the 911 automatic transmission is better than the manual. This GT3, Turbo, and the now Nuremberg record holding 918 all only come with automatics. Also the Ferrari 458 is only available with auto.
FYI I love manual transmissions.
mwjcyber is offline   Reply With Quote
Old 09-15-2013, 05:49 PM   #60
chulooz
Registered you sir
chulooz's Avatar
Originally Posted by mwjcyber View Post
Actually most performance brands, Porsche, Ferrari, etc. are going exclusively to paddle shift automatics. Its well known the 911 automatic transmission is better than the manual. This GT3, Turbo, and the now Nuremberg record holding 918 (CVT) all only come with automatics. Also the Ferrari 458 is only available with auto.
I said average performance cars; speaking of porsche, they spent the time to make a 7 spd MT, why? Because thats what paying customers wanted.
Lots and lots of people think that faster=better, but for many manual lovers that isnt true. The pressure of the clutch, the switch of the lever, and a blip of a throttle is something that millions cannot live without. Those who think MTs will disappear fail to see the economics behind offering the standard transmission.
The Following 2 Users Say Thank You to chulooz For This Useful Post:
mwjcyber (09-15-2013), WolfpackS2k (09-16-2013)
Old 09-15-2013, 05:50 PM   #61
onefitz
Drives: 13 GBS BRZ
Those are all using dual clutch transmissions. Not the torque convertor style automatic that Toyota is using in the GT86. And last I heard the 918 was using a PDK variant. A CVT wouldn't be able to handle the torque from the 918.
onefitz is offline   Reply With Quote
The Following User Says Thank You to onefitz For This Useful Post:
strat61caster (09-16-2013)
Old 09-15-2013, 07:42 PM   #62
mwjcyber
mwjcyber's Avatar
I mean PDK, not CVT, thank you for the correction.
Old 09-15-2013, 07:46 PM   #63
Suberman
Drives: Subaru BRZ Sport Tech Satin White
How can you say that when 80% of this cars sales have been in MT? The consumers have spoken.
Because Subaru/Toyota deliberately fit an automatic with inappropriate gear ratios. Fit a shorter final drive to a BTZ automatic to correct this and very few drivers would want a manual.
Also, the manual shift would be unpopular if a DCT were offered instead.
Manual shift cars are SLOW.
Suberman is offline   Reply With Quote
Old 09-15-2013, 07:49 PM   #64
Suberman
Originally Posted by smbrm View Post
I don't get the negative weight argument for hybrid vs. the support for 6 cylinder? Last time I thought about it, a V6 weighed more than a 4 cylinder! The extra weight on the front would have a significant impact on the weight distribution, that would probably require a rear transaxle to adjust. Both of which would add substantially to cost! Maybe for a supra version, but it would not be light!
Besides, I believe they are talking about capacitors which should be lighter than even the 67lb battery of the Prius C. Granted you do have weight from the electric motor(s), but packaged properly and producing a higher torque to weight ratio, then why couldn't the car still be fun to to drive?
The new hybrid design replaces the starter, the alternator and the torque converter and should run at least at 42 volts which is much more efficient than 12 volts.
The magic of the next gen hybrids includes seamless stop start, electric only range within urban areas, push to pass acceleration and KERS. All this with a nominal weight penalty, if any. Why would you turn it down?
Old 09-15-2013, 07:52 PM   #65
onefitz
Drives: 13 GBS BRZ
Sure the DCT is faster, but I'd bet the sales of a DCT vs the MT would stay about where they are now with the traditional automatic.
Hell look at the uproar over Porsche only offering the PDK in the new GT3.
Old 09-15-2013, 07:53 PM   #66
chulooz
Registered you sir
chulooz's Avatar
Now you are just trolling.
Some people dont understand that people love dumping their own clutch and shift their own gears, even if it costs them .3 seconds on their drive down the street. You are in the 20% minority sorry, gear ratios isnt going to change that.
onefitz (09-15-2013), WolfpackS2k (09-16-2013)
Old 09-15-2013, 07:54 PM   #67
Suberman
Actually the PDK of the same weight as an equivalent torque converter planetary transmission has less than half the torque capability.
Planetary transmissions are more efficient than DCT.
Mercedes Benz has a planetary transmission with a wet plate clutch instead if the torque converter, for example.
DCT are for lighter and less powerful cars where the weight disadvantage isn't as significant.
The Bugatti Veyron DCT is a specially designed and built, bespoke transmission supplied by Ricardo engineering in the UK. Very expensive.
The Following User Says Thank You to Suberman For This Useful Post:
Old 09-15-2013, 07:58 PM   #68
Suberman
Not trolling. I am correcting irrational prejudice against automatic transmissions.
Torque converter automatics are ALSO faster than manual shift.
BMW supplies all of their cars with 8 spd torque converter automatics or DCT type transmissions except in the US.
It is absolutely incorrect to suggest a manual transmission is technically superior in any way to a modern automatic. They are inferior.
The ONLY reason to spec a manual transmission is for historical curiosity, which is why my BRZ has one.
Dumping your clutch is also dumb and slow.
Old 09-15-2013, 08:00 PM   #69
chulooz
Registered you sir
chulooz's Avatar
Historical curiosity??? How about driver engagement; kinda goes with the theme of the car.
What prejudice did I claim about ATs?
The Following User Says Thank You to chulooz For This Useful Post:
Old 09-15-2013, 10:17 PM   #70
onefitz
Drives: 13 GBS BRZ
Or if you plan on modifying the car immensely. Or you don't want a computer doing everything for you.
I don't see where 'dumb and slow' plays into a good hard launch.
fat epic fail, huntergreen gif sig
Toyota 86 hybrid proposed plasma06 Scion FR-S / Toyota 86 GT86 General Forum 2 03-13-2013 08:10 AM
Faster Toyota 86 could be a hybrid Crewzern AFRICA 1 03-12-2013 07:21 AM
Toyota working on a sedan version of the 86/FR-S? Toyota Furia Concept vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 40 01-14-2013 11:45 PM
Toyota TS030 Hybrid lightspeedracer Other Vehicles & General Automotive Discussions 2 06-19-2012 03:56 PM
