go_a_way1
Old 08-11-2021, 01:48 AM   #5027
jflogerzi
jflogerzi's Avatar
Originally Posted by trakday View Post
Yeah I hate to admit it, but I pulled a typical rookie move and forgot to take hot pressures. I was at 28psi cool, but I completely forgot to grab pressures after I came off the track.
it happens... Also I would not try to daily drive these tires. Your really going to eat into the amount sessions you can run. If you need a full time tire IMO there are better and cheaper tires out there.
2013 Series 10 FRS #553
Old 08-11-2021, 07:54 AM   #5028
trakday
Drives: 2020 Subaru BRZ PP
Definitely! This is sort of a one time situation because I found them on clearance and I wasn't ready at that point to invest in a good set of track wheels. I made the decision that I was fine with a couple of track days and some street miles and they'd likely be dead at the end of the season.
FWIW, my car is technically a daily, but I average around 250-300mi a month because my wife and I both WFH and we mostly take her Durango everywhere.
trakday is offline   Reply With Quote
Old 08-11-2021, 09:34 AM   #5029
steverife
Drives: 2016 Scion FRS
I've autocrossed several sets of RE71R's. It isn't uncommon for them to groove like that early on. It tends to even out as the tire wears more.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (08-20-2021)
Old 08-20-2021, 02:38 PM   #5030
RedReplicant
Drives: None
Do people run the same pad compound front / rear on these cars, or is staggered the norm?
RedReplicant is offline   Reply With Quote
Old 08-20-2021, 03:38 PM   #5031
Front same/rear is common. A small handful run reverse stagger, but this is extremely situational.
Old 08-20-2021, 04:05 PM   #5032
RedReplicant
Drives: None
Thank you, I wasn't sure if there was anything specific that angered the electronics.
I'm coming from land of turbo Miata with R18/R12 on the big Trackspeed Engineering Wilwood front and Sport rears with a bias valve. E46 M3 ABS is currently going into it.
I don't intend to track the BRZ a lot but I figured I should have a set of pads for the occasional event where I don't need to run the Miata for TT.
Old 08-20-2021, 05:38 PM   #5033
Pedal dance, and you should be good to go.
Gloc pads are available for this platform, although based on your post, I suspect you'll find yourself wanting more.
Old 08-20-2021, 06:14 PM   #5034
RedReplicant
Drives: None
More in terms of heat range, or more in terms of energy capacity for rotor/pad longevity (bbk)?
Trying to keep it realistic when swapping between a competitive TT4 car versus a TT5 street car, but we both know how that goes.
Old 08-20-2021, 06:27 PM   #5035
Capacity. Based on your turbo Miata description, sounds like you're pretty quick, and will need the equipment to support your pace.
Old 08-20-2021, 06:35 PM   #5036
RedReplicant
Drives: None
Thank you, sounds like I have some reading to do. I appreciate it!
Old 08-22-2021, 12:19 AM   #5037
PM me when you're ready to make a move and we'll discuss to determine what's proper for you, and get you set up.
RedReplicant (08-23-2021)
Old 08-23-2021, 11:14 AM   #5038
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Did you buy Brock's car?
If you're going to track it, even a little bit, the BBK may be worth it if you're used to running a TT4 miata. On the stock brakes on these cars, depending on the track, you can eat up a set of pads in 2-3 weekends. If autocross only and occasional track use, get a compound you like and keep the calipers stock and you'll probably be fine for a while unless you decide that bolting 245 R7's on the car is fun (it is) and that you want to run TT5 some lol
Kelse92 is offline   Reply With Quote
Old 08-23-2021, 06:00 PM   #5039
RedReplicant
Drives: None
Haha, I did. I didn't bother replying to the RRAX Buy/Sell thread given the tone of some of the other people.
The Miata is the competitive car, but I still want to be able to take this thing out to a few casual events a year. I'm leaning towards buying a set of F/R pads and sticking to places like Chuckwalla that don't eat brakes (just tires).
Old 09-20-2021, 02:50 PM   #5040
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Considering a tire change...
I do about 6 HPDE's a year, just for fun, and run stock power levels.
I have TRD lowering springs and Pedders offset tophats so I am just about -2 camber all the way around.
I currently run Pilot 4s tires (225/45/17), however I find them a little slippery as my times have improved...
I am looking for recommendations on a compromise tire for dual use... is there something better than the 4s?
Price does not matter much, however I don't want to be buying new tires every year if I am only street driving under 5000 miles/year...
Is it practical/reasonable to street a 200 treadwear tire in a warm, dry climate (e.g. San Diego)?
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
