go_a_way1
Old 12-31-2014, 03:17 PM   #2311
Originally Posted by Fricke View Post
really interested to try a set
but would like to know the price.
You can pm me if you wish.
And Happy New Year everyone, hope 2015 will be a really good year on the track
Stock or AP Calipers? Send @CounterSpace Garage a PM to get a quote.
Old 12-31-2014, 03:20 PM   #2312
Originally Posted by Blizzard View Post
Revolution Performance RP400. This seems like such a great turbo kit. I have talked with the owner and he is way cool. However, I love to track my car and I do not want to invest in something that will prevent me from doing so. So, I am wondering if anyone has first hand experience/knowledge of a front mount turbo with thermal barrier coating, turbo blanket, and oil cooler running reliably at the track? Thanks.
You're gonna need a lot more than just the kit itself to keep the system cool. The turbo, due to location, will heat up everything downstream from it, and become a liability as you get faster. If you have any sort of front impact, the damage will be greater since you lack the foam. The Foam also works as an air guide to force all the air to go through the FMIC/ACC/Rad. Where would an oil cooler be placed?
The kit can work reliably if you put in the time and money, but if the owner and/or shop hasn't tracked their car, you will become the guinea pig.
The only turbo kits that are track tested by the manufacturers to what I consider a reasonable degree, are Greddy and Ptuning.
Blizzard (01-02-2015)
Old 01-01-2015, 01:21 PM   #2313
Fricke
Drives: Toyota GT86
Stock calipers.
PM sent
Fricke is offline   Reply With Quote
Old 01-01-2015, 04:37 PM   #2314
chriskory
Drives: 1991 honda civic si
How do these brake pads look? EBC yellow
I've just swapped the street pads back on after a track day, but these left some grooving on the rotors. Should I still do the same bedding process on an imperfect rotor? Also, any noticeable difference in pedal quality between two person bleeding and using a motive pressure bleeder?
Thanks
chriskory is offline   Reply With Quote
Old 01-01-2015, 06:07 PM   #2315
Thanks
You totally cooked those pads. The material in between the grooves is melted pad that resolidified there...
Step up the pads to a race compound. EBC compounds, in my experience, are not very well suited for spirited driving.
Old 01-01-2015, 06:58 PM   #2316
M23
Drives: 86
That 240 has some mega suspension issues... fix that and braking and its easily a 1:21 car.
We ran a 1:23 on R-comps; 1:24 is what we ran with street tires.
NA or JRSC tho?
M23 is offline   Reply With Quote
Old 01-01-2015, 09:03 PM   #2317
troek
troek's Avatar
Drives: 2012 Toyota 86
I dont think the jrsc was around in 2012
Old 01-02-2015, 03:34 AM   #2318
Originally Posted by M23 View Post
NA or JRSC tho?
NA. Completely stock drivetrain, down to the (bad) factory tune (that cost us multiple engines).
M23 (01-02-2015)
Old 01-02-2015, 03:33 PM   #2319
M23
Drives: 86
Nice! Was this with the SRC COs and other suspension bits?
What times are you getting at SWOS with the JRSC in place?
Old 01-02-2015, 04:08 PM   #2320
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Left foot braking: When would we use it?
I've been trying to read up on it since my driving school instructor suggested it as a way to improve (he also drove a FRS).
Most of what I've read suggests LFB is best for countering FWD (and to a lesser extent, AWD) cars' understeering tendencies.
For RWD cars, when would this be useful? Particularly for manual drivers?
Would I use this to try and cancel out understeer (as opposed to trying to use the throttle to power out)?
daiheadjai is offline   Reply With Quote
Old 01-02-2015, 04:48 PM   #2321
ddeflyer
Left foot braking is a very powerful but tricky to learn technique with alot of potential applications. Among them (and I am sure there are more):
very heavy trail braking to speed rotation
decreasing effective rear brake bias
changing weight distribution without letting off throttle
Essentially it is another tool to control what the car is doing but it is a very difficult one to learn. Most people have a club left foot compared to their right and where left foot braking really can help is when you really need fine inputs.
And FYI I am not a left foot braker yet, though I am trying to get there.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following 2 Users Say Thank You to ddeflyer For This Useful Post:
daiheadjai (01-02-2015), fstlane (01-02-2015)
Old 01-02-2015, 05:00 PM   #2322
daiheadjai
daiheadjai's Avatar
I hear you... I'm trying to practice with simple straight line stops (when there are no other cars in front or behind me).
I'll know I've arrived when my wife doesn't shoot me a dirty look after the car stops.
The Following User Says Thank You to daiheadjai For This Useful Post:
Campo (01-06-2015)
Old 01-02-2015, 08:59 PM   #2323
Just SRCs. Zero other suspension components, except camber bolts (which are moot since the SRCs already have camber/caster plates).
I haven't attempted any record laps with the JRSC on.
M23 (01-05-2015)
Old 01-02-2015, 09:00 PM   #2324
LFB is used to "drag" the rear on those cars to force rotation.
It depends on the application, but I don't LFB at all. It's just not a skill I've come to need yet, since I almost exclusively drive RWD, or AWD cars with proper balance.
daiheadjai (01-04-2015)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
