#3515 |
Drives: 2015 AOZORA EDITION
question if i run a type 1s do i really need to add a front splitter?
#3516 |
#3517 |
I'm currently on kw 2 way clubs sport and running 255 re71r . Got people telling me I need a splitter but I'm not too sure. I know it's better to have just not sure if it's nessceray
#3518 |
What spring rates are you on? Do you think your car understeers, oversteers, or is perfectly neutral?
#3519 |
Drives: 2016 BRZ
The track wheels I bought are 17x8 with an offset of 50mm. I was going to add a 20mm spacer/adapter front and 30mm in the rear. Is there any disadvantage of using spacers on the track?
#3520 | |
In my mind, bolt on spacers just make one more thing you need to worry about and check. I like simple. Some say spacers bring more stress to your wheel bearings as well, not sure if the spacer cause it or if the total offset of the wheel is the impact. |
#3521 | |
I recommend ARP extended studs, and blank spacers. You can stack spacers as you see fit this way. |
#3522 | |
Drives: '13 FRS - STX
#3523 |
Drives: '22 BRZ
It's definitely not the spacer itself causing the wheel bearing stress, it's the resulting change in total offset.
I personally wouldn't run spacers on track because I like to keep things pretty simple, but if you don't mind doing a nut and bolt check on them before and after every event, go for it. A lot of people will argue about the hub centric rings and they're 100% right that they don't support the wheel once the lugs are tight. I've had enough bad experiences trying to make wheels actually seat properly on the hub without them that I'll never run without them again. Wheels should self-center as you tighten the lugs but even a couple of thousandths of run-out can be noticeable and if you're not really careful to gradually tighten each lug nut using your fingertips to ensure it's seated a little bit at a time to let the conical seats do their job you're going to have a bad time. |
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#3524 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | DocWalt (02-23-2016), strat61caster (02-23-2016) |
#3526 |
Ooops @DocWalt beat me to the punch. I get a lot of notifications so i open all of them and then answer them sequentially.... and sometimes that happens lol.
#3527 | |
#3528 | |
Drives: 2023 BRZ
| The Following 2 Users Say Thank You to Pat For This Useful Post: | CSG Mike (02-23-2016), strat61caster (02-23-2016) |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
