Old 03-16-2018, 01:31 AM   #1639
Hurricanehank
Drives: Oceanic 86
I just installed mine a couple months ago looks like it was a vibrant gasket that I had. I say still get the oem metal one �� .
Hurricanehank is offline   Reply With Quote
Old 03-16-2018, 01:38 AM   #1640
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Good to know, thanks.
I'm really surprised to read that using an aftermarket OP is all but required to avoid strange sounds and higher likelihood of leaking. I really wish I'd known that before ordering.
mistople is offline   Reply With Quote
Old 03-16-2018, 01:47 AM   #1641
Hurricanehank
Drives: Oceanic 86
Mine sounds real nice and aside from swapping the op gasket everything fit great. Jdl catless uel + stock op and fp + hks legamax premium catback. Im in seattle too so if you want to hear it or ride in it let me know.
Old 03-16-2018, 12:21 PM   #1642
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Don't waste your time using the stock gasket on the JDL header. It WILL leak eventually.
Use a Remflex gasket or some other nice gasket that has enough area to cover the 2.5" pipe of the JDL and also the ~2 1/8" pipe of the stock OP.
DocWalt is online now   Reply With Quote
Old 03-16-2018, 01:23 PM   #1643
mistople
mistople's Avatar
Do you agree that the Vibrant gasket supplied by JDL wouldn't work for the stock OP? It would seem strange to me that JDL would include a part that has known issues.
Old 03-16-2018, 10:51 PM   #1644
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have no clue what gasket JDL is supplying with their parts these days, sorry.
The Subaru OEM gasket won't work well though. It has a compression seal that won't seal properly because the JDL pipe is much larger.
Old 03-17-2018, 01:07 PM   #1645
mistople
mistople's Avatar
Ok, thanks for the heads up. I ended up using a different Vibrant gasket that was similar to a Grimmspeed style. Can’t really tell if there any leaks yet. We’ll see!
Not as easy as I thought it would be to install the headers! One of the engine mount bolts is nearly impossible to reach, even with special tools.
Old 03-22-2018, 07:58 PM   #1646
mistople
mistople's Avatar
So I've installed my catless UEL and am almost done with the Delicious tune revisions.
I've noticed a very obvious intake-esque sound under any close to moderate load. I don't believe I have any leaks that I can find at this point. It sounds like air is getting sucked in, not necessarily leaked out. Is this a known sound? Any ideas as to what causes it?
Setup: 2017 LH-drive MT BRZ, Catless ti-coated UEL, Stock FP/OP/CBE. Grimmspeed gaskets on motor mounts, and a metal Vibrant gasket (not the one included with the JDL UEL) between the headers and OP.
Old 03-22-2018, 11:20 PM   #1647
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Fluttery sound at part throttle? Welcome to owning a header on the 86 with stock catback. When you add a catback you can't hear it anymore. I changed OP/FP and could still hear the fluttery noise. Catback covered it up unless I was driving next to other cars or in a city.
Old 03-22-2018, 11:49 PM   #1648
mistople
mistople's Avatar
Yeah, it sounds a little fluttery and a bit like an intake sans-growl.
I have a Perrin 2.5" resonated sitting on my floor right now. Hopefully that will help! I'm still gonna check the OP connection regardless.
The Following User Says Thank You to mistople For This Useful Post:
DocWalt (03-27-2018)
Old 03-28-2018, 10:53 AM   #1649
Teseo
Drives: frs
If i put heat wrap on my JDL header, will void my warranty?
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
