Old 08-02-2014, 03:37 PM   #29
wootwoot
Drives: FRS
Not this again!
I researched this feverishly a few months back. I started a similar thread that induced a lengthy debate. As always with this topic, no one agreed on anything.
Here is my opinion: Despite what others may say I believe the crank shaft pulley IS in fact a harmonic dampener (NOT a harmonic balancer). The debate over this will never be settled. What I think most of us can agree on, however, is that the performance benefits of a new crank pulley are marginal at best. When we weigh the possible costs against these marginal gains it seems apparent that a pulley simply isn't worth it. Despite what you believe why would you put your engine at risk (even if only perceived) for what amounts to very minimal benefit?
My 2 cents...
wootwoot is offline   Reply With Quote
The Following 6 Users Say Thank You to wootwoot For This Useful Post:
86-tundra (08-02-2014), Ammunition (09-12-2014), BlueDubbinTDI (08-02-2014), Boxer486 (08-03-2014), D_Thissen (08-02-2014), stugray (08-02-2014)
Old 08-02-2014, 04:32 PM   #30
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
What about a super damper? @wootwoot
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 08-02-2014, 05:07 PM   #31
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Biggest con seems to me is that your wallet is now lighter.
waste of $ imo
86-tundra is offline   Reply With Quote
Old 08-02-2014, 05:08 PM   #32
ZionsWrath
Thanks
ZionsWrath's Avatar
waste of $ imo
Part of the weight savings brah!
The Following 5 Users Say Thank You to ZionsWrath For This Useful Post:
86-tundra (08-02-2014), brandonblt2 (12-23-2014), jdubious (08-04-2014), kavanagh (09-11-2014), WallsAndFoundations (08-02-2014)
Old 08-02-2014, 05:12 PM   #33
86-tundra
Troll Hunter
86-tundra's Avatar
I should be a part of the weight gaining club. I'm not good at weight savings on the car
The Following User Says Thank You to 86-tundra For This Useful Post:
ZionsWrath (08-02-2014)
Old 08-02-2014, 05:13 PM   #34
ZionsWrath
Thanks
ZionsWrath's Avatar
Share the weight gains and put some of those benjamins in my pocket
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
86-tundra (08-03-2014), WallsAndFoundations (08-02-2014)
Old 08-02-2014, 05:43 PM   #35
Brinks
Brinks's Avatar
waste of $ imo
Marginal gains for marginal money, doesn't seem like that bad of a deal to me. Guess it all comes down to what you want to accomplish with your build. Going FI or staying stock, then ya it's kinda worthless. Trying to squeeze out every last bit of power from a NA setup in conjunction with a CF driveshaft, lightweight rotors and wheels then it might be worth it
Brinks is offline   Reply With Quote
Old 08-02-2014, 06:05 PM   #36
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Same ol' same ol'.
Yeah, I'm quoting myself.
This subject has already been done to death.
I will summarize it for you:
1/ OMG!! This mod has released at least 40 megaWatts and now I can beat Veyrons from the lights.
2/ This mod is a waste of money and you would be better off going on a diet.
A search on these forums of "light weight pulley" would have given you these results in addition to the link above. This is not the full list.
http://www.ft86club.com/forums/showthread.php?t=61709
http://www.ft86club.com/forums/showthread.php?t=56931
http://www.ft86club.com/forums/showthread.php?t=47079
http://www.ft86club.com/forums/showthread.php?t=13259
http://www.ft86club.com/forums/showthread.php?t=43556
http://www.ft86club.com/forums/showthread.php?t=12450
That's weird. I seem to have got the possible powa increase mixed up. 47GW or 40 megaWatts is still a metric truck load. You would be better off using imperial measurements because then you would have even more powa.
Old 08-02-2014, 06:38 PM   #37
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Originally Posted by WallsAndFoundations View Post
Gotcha. So me owning a manual I'll still feel a difference. . Just not as much as an auto.
In your opinion - as it seems you know your shit - is it worth it? Only 300 bucks or so and it seems to add a decent amount of performance.. and a possible MPG boost you say?
At $300 I hesitate. At $150 I buy. Pricing on FA pulleys is higher than EJ pulleys and it is a production numbers game. So, I would expect up to $250 for a FA pulley (for now).
On my own AT cars I run a LWCP. On my MT cars I run a LWFW.
Infamous Performance is offline   Reply With Quote
Old 08-02-2014, 06:42 PM   #38
Originally Posted by Akari View Post
Can you explain why this would be? 4lbs off the crank pulley saves you the same amount of rotational mass on both a MT and AT. From a physics standpoint the power gain from it has to be identical, why do you say this is felt more in a AT?
Also 1-2mpg seems like quite the overstatement. 4lbs less of rotational mass at the crank typically equates to more like a .1-.2mpg at most in my experience. Do you have any evidence to back this up?
Torque converter. AT's do not transfer power the same as MT's. Just as AT cars do not accelerate as fast as MT cars (from the factory).
Yes. My own AT cars. Due to electronic throttle and tuning there is always a sweet spot for cruising MPG. Find the sweet spot and with a LWCP you can gain 1-2 MPG cruising. Its not that easy to drive in the sweet spot (it takes some modulation) and its not any fun. So, 99.97% of owners never realize it. They are not putting go fast parts on the car and then not using the throttle.
The Following User Says Thank You to Infamous Performance For This Useful Post:
Old 08-02-2014, 07:03 PM   #39
Originally Posted by Brinks View Post
Seems like the other pulleys would be just as important. Don't they all share the same load? less weight less resistance......
The is so little to be had by replacing the alt and water pump pulleys it is not worth the expense. If it is a pure race car and you earn a living winning, it makes a difference.
On forced induction cars running all 3 LW pulleys we have seen issues with load changes that cause idle stumbles/stalls.
Old 08-02-2014, 07:09 PM   #40
Originally Posted by Malt View Post
As for Infamous Performance claims of issues with pulleys and lightened flywheels, I have yet to see anyone talk of problems with the FA20 motor. Infact I'm fairly certain there are several people running full raceseng S2 set, lightened flywheels, and carbon driveshafts with no problems. Sure there might have been issues with the EJ's (uggh, hello 02-03 WRX) but this is a completely new motor and I'm failing to see how the two are related.
The FA block is similar enough to the EJ. Neither motor has a harmonic balancer. Both motors rely on the small amount of rubber in the crank pulley to absorb vibration. We have already seen internal bearing damage from combining a LWCP and LWFW in the FA motor.
Old 08-02-2014, 07:10 PM   #41
Actually very nice. But a pain to install (initially). Some need to be pressed on.
carbonBLUE (08-03-2014)
Old 08-02-2014, 09:56 PM   #42
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Same ol' same ol'.
Sorry dude. I'm using tapatalk and the search function isn't very helpful honestly... I did search but it brings me back a bunch of threads completely not relevant
WallsAndFoundations is offline   Reply With Quote
The Following User Says Thank You to WallsAndFoundations For This Useful Post:
Captain Snooze (08-03-2014)
Light weight flywheel and crank pulley? wootwoot Engine, Exhaust, Transmission 133 06-23-2015 02:04 PM
Light Weight Pulley's exam2300 Engine, Exhaust, Transmission 18 02-08-2014 01:02 AM
FS:PERRIN Light weight pulley NEW $85 Shipped Amalgamo Engine, Exhaust, Bolt-Ons 1 05-01-2013 12:10 PM
FS - Agency Power Light Weight Pulley Kochinopride Engine, Exhaust, Bolt-Ons 3 11-12-2012 06:32 PM
