Old 09-25-2013, 07:04 AM   #127
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Originally Posted by jacobzking View Post
I used the kahtec module which was super simple. after I pulled the lower light unit out of the car, i just attached the kahtec unit to the light (on top near where the 10mm bolt is) with some 3m double sided tape. the blue wire from the kahtec went to the + side of the new light bulb. i fused the black wire and the - wire of the bulb with a 12" piece of black wire and grounded it to the car (right above the muffler is an easy to see, easy to access 10mm nut sticking out. i just found a 10mm bolt and screwed it on to the wire to ground it. then on the red wire from the kahtec, i ran that through the grommet in the trunk on the left side (where all the other wires go, by the spare tire tools), ran that up to the green wire on the 3rd brake light and tapped it in. i spent maybe 2 hours total between finding wire, a light socket, removing the unit, dremeling out the hole and notches, disassembling the trunk, etc. i could probably do it over in about 45 minutes now that i know what to do.
Which kahtec unit did you use? Great write up! PM sent as well.
Brzzee is offline   Reply With Quote
Old 09-25-2013, 10:47 AM   #128
STV3
Señor Member
STV3's Avatar
Installed mine over the weekend. Got lazy and bought the phasetek kit. Very happy with it though
STV3 is offline   Reply With Quote
Old 09-30-2013, 04:51 PM   #129
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
This maybe a dumb question, but when you remove the reflector do you have to undo the bumper and diffuser and take it out the bottom or can it be remove via the opening in the bumper that the reflector is in? I haven't seen this mentioned any of the searches I did.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 09-30-2013, 05:29 PM   #130
STV3
Señor Member
STV3's Avatar
you have to get under the car and remove the two push pins holding the supports for the rear bumper and then you can kinda just bend it outward to get in there and get the light housing out.
there are two 10mm bolts, 2 push pins, and a clip holding the housing in.
Old 09-30-2013, 05:47 PM   #131
FLYFISHR
FLYFISHR's Avatar
If I understand this correctly I get in under the car to remove the pins and undo the bolts and clip. Take out the backup lights and then it will come straight out the opening in the bumper?
Old 09-30-2013, 06:13 PM   #132
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
opposite which means you take it off forward to muffler. be careful! you might break plastic clip as i did. (even it breaks, don't need that much)
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
FLYFISHR (09-30-2013)
Old 09-30-2013, 11:49 PM   #133
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Is there a way to tap into the BRZ fog lights to do this? I know it can't be done with the FRS but the BRZ limited has fogs.
Sent from my iPhone using Tapatalk - now Free
milhouse is offline   Reply With Quote
Old 12-13-2013, 01:20 PM   #134
BRZ_son!
Drives: WRB BRZ
I have the NSIDIUS INDUSTRIES plug and play kit on mine! Love it!! Super easy to install and didnt have to cut into my OEM wires.
www.nsidiusindustries.com
BRZ_son! is offline   Reply With Quote
The Following User Says Thank You to BRZ_son! For This Useful Post:
tonystewart (12-13-2013)
Old 12-14-2013, 08:28 PM   #135
JOSI
JOSI's Avatar
Drives: Daihatsu
80 Dollars for that..?.. its never really a smart idea to add additional load onto existing wiring..I'm gonna start mass producing mine and make a killing.. This cost me 10 dollars to make it mostly consists of free parts from junkyard Hondas.
Real deal plug n play
JOSI is offline   Reply With Quote
Old 12-15-2013, 09:30 PM   #136
JFBRZ711
Drives: 13' BRZ Limited CBS
DIY Rear foglight
JOSI, what light are you plugging that 194 base in place of? I'm interested if less than what other kits are going for
JFBRZ711 is offline   Reply With Quote
Old 12-15-2013, 10:39 PM   #137
BRZ_son!
Drives: WRB BRZ
JOSI, I've had this kit installed for about a year now with no problems. Its still running the same amperage fuse for the rear taillight circuit and has never had a problem holding up. If using the correct gauge wire, it will not give much load to the existing circuit. Plus its a quality made harness made in the USA
Old 12-16-2013, 03:06 AM   #138
TheLaughingMan
TheLaughingMan's Avatar
FYI to people wanting to do this mod, the grey plastic housing is SUPER brittle. Be extremely careful with the tabs (as the OP mentioned), when tightening the bolts down, and drilling the hole. The tabs on mine broke off (and I thought I was being careful), my drill bit caught and torqued the plastic (breaking off a large piece), and the tab that the bolt goes against snapped when I was tightening everything back up. I managed to fix the housing using some special adhesive that melts the plastic and bonds it back together...but it would have been nice to not break it in the first place. Let this be a warning and learn from my mistakes!
Finished product:
TheLaughingMan is offline   Reply With Quote
The Following User Says Thank You to TheLaughingMan For This Useful Post:
Sc0ob_do0D (01-29-2014)
Old 12-16-2013, 06:56 PM   #139
JOSI
JOSI's Avatar
Drives: Daihatsu
I un did my tail light indicator light.. In Iowa I don't need them.. I know some places do legally require them. I have enough to make an additional harness... If your interested you can have it for free.. As long as I can get some feed back from you?. LMK
The Following User Says Thank You to JOSI For This Useful Post:
JFBRZ711 (12-17-2013)
Old 12-16-2013, 07:05 PM   #140
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Very nice
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
rear seats? EJ20 BRZ First-Gen (2012+) — General Topics 67 11-12-2012 08:15 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 01:47 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 03:08 PM
