Old 05-31-2013, 09:10 AM   #169
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by RAWR BRZ View Post
So apparently Subaru Corporate is aware of the issue and is working on a fix either ECU or new DI design (they have to fix it for 2014). However since there is no fix yet there is no TSB (bulletin) on it yet. They also pulled the cricket noise TSB because it temporarily fixes the issue and it comes right back. Theyre working on a solution that will fix both.
... first case of this issue recognized by Corporate Subaru was in South Africa (which is generally hotter than here in the states).
What evidence do you have that SOA has acknowledged the Injector seal issue and are working on a fix?
Also I need to correct you about South Africa. That was not Subaru, it was Toyota who released a service bulletin which included an ecu update that corrects the transient ignition retard tables.
Old 05-31-2013, 09:35 AM   #170
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Thats no where as bad as some cars have seen. I may even call yours just "more aggressive street driving"
I dont believe they are readily available since there is people waiting weeks for them to be shipped from Japan. They also seem pretty pricey.
Anything to do with power/engine is stock unless drop in air filter by HKS counts... Stock intake, stock engine (no pulleys etc.) stock headers all the way to the mufflers.
Ok update:
So apparently Subaru Corporate is aware of the issue and is working on a fix either ECU or new DI design (they have to fix it for 2014). However since there is no fix yet there is no TSB (bulletin) on it yet. They also pulled the cricket noise TSB because it temporarily fixes the issue and it comes right back. Theyre working on a solution that will fix both. Now the big problem for us is that since there is no TSB, Subaru Dealers dont know what is going on because they base everything off the TSB. So you have popping noise? Subaru Dealers check the TSB, no TSB for popping noise. Popping noise is considered "normal." Now we all know that isn't normal and they know it isnt too but the dealership can't really do anything unless your engine blows. IF your engine blows Subaru Corporate HAS to cover your engine because they are aware of the issue and dont have a fix for it yet. I find it very weird why they rather have engine's blow up and replaced rather than replacing the seals to "temporarily fix the issue." The latter seems like a cheaper alternative. Now I could pay out of pocket (150 quoted by my dealer) for a diagnostic fee. I dont know exactly what they will do but if they do find a leaking DI seal they will warranty it and refund the 150. Now the dealer can screw me over and say "oh its your drop in air filter and once we put in a stock one the popping noise stops." Then they make away with my 150 for what is essentially a BS diagnostic. It seems like if we dont want our engine to blow up or be replaced we need dealers and corporate Subaru to be aware that this issue isnt just a small population of owners. It seems as if Toyota is willing to replace the seals while Subaru isnt willing to do anything unless we pay for diagnostic or after our engine blows...
Personally I believe this issue isnt just because of tracking the car. I believe it is also heat related. The first case of this issue recognized by Corporate Subaru was in South Africa (which is generally hotter than here in the states). During that time we were facing Winter and Spring months. Now that it is Summer, this issue is all over the place now. It is appearing whether a person tracks their car or uses it as their daily driver.
With all that said I would really like Subaru to fix this issue rather than have me drive my car around until the engine blows. I really don't like the idea of having the dealer work on my car, or worse... swap out my engine.
So you saying that even Ud we fix this the issue will persist
Sent from my HTC One using Tapatalk 2
Old 05-31-2013, 10:57 AM   #171
Ok update:
http://www.ft86club.com/forums/showthread.php?t=37810
Old 05-31-2013, 11:28 AM   #172
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
CSG Mike has hit the exact issue.
Subaru denies there is an issue.
Engine eventually blows.
Subaru denies warranty because this issue is track related and track time = voided warranty.
I'm replacing my seals via a 3rd party mechanic and getting a software update via a 3rd party tuner.
I've dealt with many auto dealers over the years and Subaru is by far the worst.
Every issue I've hit with this vehicle has been diagnosed and repaired by me on my dime.
Subaru has provided no help what so ever.
romin is offline   Reply With Quote
Old 05-31-2013, 11:44 AM   #173
xjohnx
Grip>Slip
xjohnx's Avatar
Looks like their exact verbiage is:
Damage Caused Due to Use of Vehicle in Competitive Events
These warranties do not cover damage to any component that is the result of operating the vehicle in any competition or racing event.
https://www.subaru.com/my-subaru/warranties-2013.html
Old 05-31-2013, 11:51 AM   #174
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'd make the case it's an HPDE and is educational and not competitive.
vtmike is offline   Reply With Quote
The Following User Says Thank You to vtmike For This Useful Post:
ATL BRZ (05-31-2013)
Old 05-31-2013, 11:52 AM   #175
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by vtmike View Post
I'd make the case it's an HDPE and is educational and not competitive.
Yep, exactly my point. There is no winner in an HPDE, thus not a competition/racing event.
The Following User Says Thank You to xjohnx For This Useful Post:
Old 05-31-2013, 11:55 AM   #176
vtmike
vtmike's Avatar
Drives: Scion FR-S
Realized I put HDPE. Too accustomed to specking HDPE pipe.
Old 05-31-2013, 12:14 PM   #177
ATL BRZ
ATL BRZ's Avatar
"Damage Caused Due to Use of Vehicle in Competitive Events
These warranties do not cover damage to any component that is the result of operating the vehicle in any competition or racing event."
Seems pretty cut and dry to me as far as HPDE participation goes. The first and last thing that is stressed in every HPDE driver's meeting that I participate in is, "NO RACING, NO RACING, and NO RACING".
Nobody who participates in a (non-competitive, educational) HPDE should be denied warranty coverage of a failure due to a defect in the factory ECU programming causing detonation/mifiring and ultimately injector seal failure. Especially since now a number of completely stock, street-driven cars are having the same issue now in the summer heat and crappy gas we are stuck with in the US.
Since CSG_Mike participated in a track event that featured live timing and the participants were comparing times I think thats the scumbags at SOA are construing the event as "competitive", thus denying warranty coverage on his second motor. Doesn't mean its right since we all know he never abused either motors.
Old 05-31-2013, 12:38 PM   #178
I think it's safe to say that my driving mainly consists of cornering and braking, not somehow making the motor do something it can't. There are plenty of people here that have been in either the CSG BRZ with me, or have asked me to drive their cars, and know I don't sit on the rev limiter, and shift pretty slowly.
In fact, there's a lot of people I've advised to shift SLOWER to preserve their synchros, since the engine RPMs drop so slowly...
The engine itself is completely within the factory specification in virtually every car I drive.
Old 05-31-2013, 01:05 PM   #179
SkullWorks
Drives: SSM LT MT BRZ
I remember having to urge MR kang to actually Rev my SR20VET in my track car out,
He kept trying to shift at the (indicated) redline on the tach....instead of closer to the 8300 rpm actual or the 7800 hp peak
SkullWorks is offline   Reply With Quote
Old 06-01-2013, 05:25 AM   #180
d4m45cuz
Drives: Scion FRS, Raven
Just an update. Was able to order a new coil pack from Subaru for my FRS (cheaper than Toyota by a bunch, lol). Also something interesting while I run on my malfunctioning coil (might have already been said, but just confirming): Quick shifts seem to throw P0351 on Coil 1 quite consistently at anything above 4000 RPM from what I can tell. After clearing the code 2 or 3 times yesterday, decided to take it easy. Shifted slower today allowing the RPMs to fall naturally to the next gear, and no code was thrown. So if anything, this is good info for those who are currently experiencing this code. Take it easy until you can fix it.
On a side note, when the Toyota dealership gave me my car back on Thursday they told me they flashed it with an update to fix the idle issue. Wanted to check to see if they included transient retard timings, so sent a copy of my ROM to episoft to compare with what they have. The dealer flashed a completely STOCK ROM to my car! No changes whatsoever! More reasons to either do it yourself or go after-market.
d4m45cuz is offline   Reply With Quote
The Following User Says Thank You to d4m45cuz For This Useful Post:
romin (06-01-2013)
Old 06-01-2013, 06:22 AM   #181
ft_sjo
Drives: GT86
I would file a complaint.
Old 06-02-2013, 03:02 AM   #182
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Sorry if I said Subaru of South Africa, I know it is Toyota. It clearly shows on the pictures Drsutra posted. My source from a Subaru dealership told me that theyre researching the issue in Orange County. You can say this is speculations but they have to fix the issue for 2014. I am sure if it isnt resolved it will really hurt sales.
Yes because all the current fix does is replace the broken part with a new part but doesnt fix why the part breaks in the first place. It is more or less just a temporary fix. Just like the new DI pump for cricket noise.
RAWR BRZ is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
