#15 |
Drives: 2013 "AVO Orange" FR-S
Sadly, I think I'm the one that introduced grounding mods to north america on Nasioc, way back in the day. It was something that the Legacy twin turbo customers noted on the 2nd gen twin turbo's. Purely an accidental byproduct of them trying to get the ultimate sound quality from the McIntosh audio systems that were an option. It was a big thing then (the McIntosh), and in the process of grounding out the system for better audio, the Legacy bbs (in Japan) noticed that the car ran *much* better.
I tried it myself (did I ever mention I spent 15 years living in Japan?), and reluctantly had to agree with them. This was before any of the aftermarket companies had heard of it, so it was all backyard stuff - heading down to Akihabara and getting all the cables/connectors and doing it ourselves. Due to our experience with it, we went to Subaru of Japan and talked about it, and interestingly enough, on the S202 I tested a year or so later, they had actually beefed up the grounding 4x compared to the earlier model Impreza. But, that's pretty much the last time grounding kits ever had any major impact on a car. The issue was found and resolved at the manufacturer level, and hasn't popped up since then. It's just that it's a highly profitable and easy to sell product, so they keep selling them. |
| The Following User Says Thank You to AVOturboworld For This Useful Post: | CircuitJerk (04-04-2013) |
#16 | |
Drives: 2013 Scion FR-S AT Asphalt
I spent 8 years in Japan total. 2 1/2 years in Sasebo and 5 1/5 in Iwakuni, just south of Hiroshima. Sometimes I do really miss it. Scott Scott |
#17 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#18 |
Drives: '13 BRZ Ltd WRB
I totally agree. This was pretty much my point, tho I took a lot longer saying it.
#19 |
Drives: World Rally Blue BRZ
my .02 cents on grounding kits based on my previous experience (Civic Si) was that i did notice better response from the throttle. At the time when i bought it i believe it was $10 I didn't really feel like it provided any additional benefit to my car but since i had it installed already i just left it. I thought the throttle response was improved but i didn't want to believe it because many time its a physiological thing.
It wasn't till i was about to sell the car did i remove all the grounding kit, that as i was driving my shifts were all off (that day the only thing i removed was my grounding kit). In a way i had to adjust my driving to match the car again. I was planning to reinstall my old grounding wire kit to the BRZ this weekend just for kicks to see if it does help improve the throttle response. |
#20 |
I added my own grounding strap to the FI computer a week after I got my car. Why? It made my idle dip less. Not snake oil. They skimped on grounding the motor well for high RPM use. you can make a few cables for alot less tho cusco kit is neat and inclusive
| The Following User Says Thank You to gmookher For This Useful Post: | ill86 (12-02-2012) |
#21 |
Drives: Limited WRB AT6 BRZ
What gauge did you use?
#22 |
Kuruma Otaku
I had a DSport mag where they looked at all the grounding kits they tested over the years. It was hit or miss on which cars gains and which didn't. Don't think it even favoured the older cars. Very random. I'll see if I can find the magazine...
Edit: OK, this example isn't great because these are probably modded cars, and it is a mix of turbo and NA, but here it is: ![]() That Sun Grounding kit is 3 gauge, and the Apexi is 8 gauge. Neither are cheap.
Because titanium. Last edited by Dimman; 12-02-2012 at 01:20 PM. Reason: edit |
#23 |
Duplicate post.
#24 |
Good question, not really sure, the car is in California and I am in AZ..
it was 1 or 2 gauge leftover scrap from one of my other stereo installs, thickest wire I could find in the garage. Thicker IS better here. If I could find a braided grounding strap, thats would have been my choice. But quality OFC copper will do just fine. It goes from the chassis(bolt behind strut where a small factory battery to chassis ground exists}, to the threaded hole where the sound transducer gizmo was bolted in. That black painted bracket is what the denso FI computer sits on. Be sure to use a steel bolt, or a high grade bolt here, not a crappy zinc one. I thought about taking the bracket off, sanding it, but adding a ground strap did the trick for me, just one. The cusco kit is a bit overkill, but in order to sell it you need to make it seem 'worthy'. Adding a strap, or two goes a long way IMHO. Use a short and fat a cable run as you need is the name of that game. The car is grounded to the block and tranny in other ways from the factory. I will later redo the factory strap or augment it to a beefier gauge of cable next. It well worth the time if you ask me, and if you dont have time or skills, buy the cable set, it wont disappoint you. Again, ymmv, I am not posting this for an argument regarding its validation, it wouldnt be on my car under my hood if it didnt make a difference. If you think its snake oil, pass it by. Trust me, it works. Here is a pic of how simple it can be. |
| The Following User Says Thank You to gmookher For This Useful Post: | kwood9000 (12-02-2012) |
#25 |
Drives: BRZ Premium Black
I'm curious where the performance starts to lack when you have poor grounding?
Is it simply the reduction of combustion effeciency from the spark plug grounded on the block? Or does the voltage drop on components causing poor fuel delivery? Or is it maybe a power loss on the alternator from added resistance in the electrical system? |
#26 |
Drives: 2013 subaru brz
ya got to love that marketing
#27 |
Drives: waiting on a 2021...
Probably marketed to the same people that can "feel" that 3HP a $300 intake adds at 7000 RPM...
#28 |
Drives: 2013 Black FR-S
I couldn't stop laughing when I saw that dyno graph! LOL
| Cusco Zero 3s on the car | Spaztastik | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-02-2012 03:12 AM |
| New Cusco parts! ($$$$) | Thongpocket | BRZ First-Gen (2012+) — General Topics | 15 | 06-21-2012 06:43 PM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
| Installed my old grounding kit. | Fish | Electronics | Audio | NAV | Infotainment | 4 | 06-02-2012 12:14 PM |
