#15 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Good info |
#16 | |
| The Following User Says Thank You to wparsons For This Useful Post: | Leonardo (03-09-2018) |
#17 |
***** Lurker
Drives: 2015 BRZ
And ARP does have stock length studs, if you want the strength of ARP's without the extended length. I just installed these on the rear (front will be soon) without pulling the hub.
#18 |
When I replaced my stripped lug stud, I got the $3 Dorman lug bolt.
Got a replacement Dorman lug nut for $2 also. Used the washers, bolt, ball joint puller, and electric impact to pull it. Here’s how I got the lug stud pressed back on I got a bunch of M12 and M14 washers at HD for $2. I also got an M12x1.25 bolt for .50 cents. Better to use the open nut than a closed lug nut. M12-1.25 Zinc-Plated Metric Hex Nut https://www.homedepot.com/p/Everbilt...d=887480403183 14 mm Zinc-Plated Steel Flat Washer (3-Pack) https://www.homedepot.com/p/Everbilt...d=887480069587 12 mm Zinc-Plated Metric Flat Washer (5-Pack) https://www.homedepot.com/p/Everbilt...d=887480024784 Caliper slider bolts (14mm) torqued to 20 ft/lb Caliper mount bolts (17mm) torqued to 60 ft/lb |
#19 |
I replaced all of the studs on FR-S on my own with ARP standard-length units without pulling the hubs and found it to be super easy. You have to remove the rotors, drive the old studs out with a mallet, put the the new studs in from behind the hub, and then use a steel open-ended lug nut and impact wrench set to a relatively low torque setting to pull the new studs into position. It took about 15 minutes per corner and can easily be done in your garage.
| How to remove seat rail bolt after you've stripped it | protpibe | DIY (Do-It-Yourself) Guides | 33 | 02-01-2020 03:06 PM |
| Stripped bolt head at over pipe/front pipe connection, what now? :( | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-14-2019 07:13 PM |
| HELP! Lug nut and wheel stud stripped! | jaydee_do_work | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 07-26-2015 02:50 PM |
| Wheel bolt stripped | 2pointSLOW86 | Issues | Warranty | Recalls / TSB | 23 | 10-13-2014 03:29 AM |
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 07:04 PM |
