Old 07-26-2016, 10:21 AM   #4103
ka-t_240
Thinking I am needing more camber in the front of my car, RCE T2s current setting is near -2.5 degrees. Camber only set via "lowering" and OEM crash bolts. Camber plates are looking to be the best option, but not sure on which to get with out spending $600. Any other options I am missing?
Have used Whiteline Com-C on previous cars, but seem to have issues on the brz chassis.
ka-t_240 is offline   Reply With Quote
Old 07-26-2016, 10:39 AM   #4104
gramicci101
Off Topic
RaceSeng is the go-to, but you're right that they're kind of pricey. RCE just came out with theirs for about $420 and Velox is $330. Neither are caster adjustable like RaceSeng, but RCE's adds 0.8 deg caster.
Old 07-26-2016, 10:43 AM   #4105
RaceSeng is the best option. PM me to order; we can help you out a bit.
Old 07-26-2016, 10:55 AM   #4106
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
It's easier to extract a quick time out of an understeery car, but the fastest state of cornering is a mild state of oversteer, where both the front and rear tires simultaneously are at the limit of adhesion. Understeer means you still have untapped rear grip. Oversteer means you have untapped front grip.
Definitely. I'm not a good enough of a driver to extract the additional grip through mild oversteer consistently for an entire lap yet
infinity21 is offline   Reply With Quote
Old 07-26-2016, 11:08 AM   #4107
You'll get there soon enough. You have the right mentality, and I think we'd agree that seat time is king.
Don't get too comfortable with an understeer setup. The more comfortable you get, the more uncomfortable you will be if/when you decide you learn a balanced or oversteery setup.
Old 07-26-2016, 12:39 PM   #4108
Racecomp Engineering
RCE T2 are designed to understeer.
They were designed just for you Mikey.
- Andrew
Old 07-26-2016, 02:25 PM   #4109
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I recommend you go with a pad with a non-corrosive brake dust.
Recommendations? I was thinking about the cobalt xr2 front and xr4 in back. The only reason I would like to go with hawk is for their NASA contingency program.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-26-2016, 02:36 PM   #4110
The XR2 is also corrosive.
The most neutral brake dust I've seen is from Carbotech/G-loc. Endless also makes some neutral pads, but they get up there in $$$$...
Old 07-26-2016, 04:04 PM   #4111
OkieSnuffBox
Drives: '23 BRZ Limited
I can attest to the easiness of Carbotech's.
In my Miata, I left XP10/8 dust on the wheels for MONTHS after a track weekend and some rain. It easily washed off with the normal amount of effort and didn't damage the wheels.
Old 07-26-2016, 05:05 PM   #4112
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I'd love to know your secret. I had Carbotech XP12 dust I left on my ZO6 for a while and it's absolutely BAKED on there. Iv'e scrubbed and tried numerous products and it isn't coming off...
I haven't had an issue yet with the BRZ Enkei wheels, but the Vette OEM front wheels are beyond saving so far.
Apex_BRZ is offline   Reply With Quote
Old 07-26-2016, 05:34 PM   #4113
strat61caster
strat61caster's Avatar
Maybe XP12 is where they sacrificed paint friendliness for performance?
My XP10's have been similarly mild and washes away easily even after being left on through the rain and wet.
ineedyourdiddly
Old 07-26-2016, 05:59 PM   #4114
If you get the wheels wet and/or expose heavily caked dust to extreme heat, you're effectively baking the dust onto your wheels...
Old 07-26-2016, 07:14 PM   #4115
ka-t_240
I use Iron-X to clean my wheels. Typically will try and clean them fairly often with normal car wash soap. Prior to using iron-x.
Old 07-26-2016, 10:32 PM   #4116
Apex_BRZ
I generally don't use the car hard enough to bake it on there, but that's definitely what's happened. I've only done 2 track days, and that's when I was learning a few years back before I bought the BRZ. They were painfully slow paced before I decided it was an awful car to learn with (it's boosted). Otherwise, it's been relegated to 1/2 mile racing so maybe that's what did it trying to shut it down at the other end? Who knows...gave up on getting them clean a while back.
I'm all ears if anyone has ideas. I had just planned on having them blasted and powdercoated some day. Anyway, different car so...trying to be more careful with the BRZ.
I use XP12's on the BRZ now, but I've only used them once so far at Road America. Seem to have washed off fine.
